100% Valid 70-743 Dumps for Free [PDF and VCE]
Discussion in 'Microsoft Certifications General' started by Warqaa Huriyyah Haik, Nov 12, 2016.
  1. Warqaa Huriyyah Haik
    Aug 24, 2016
    You need to create highly available storage spaces that connect to directly attached storage on the hosts Which cmdlet should you use?
    A. Enable-Cluster Storage Spaces Dired
    B. Set-Storage Pool
    C. Add-Cluster Disk
    D. Update-Cluster Virtual Machine Configuration
    You have a server named Served that runs Windows Server 2016. Server1 has the Windows Application Proxy role service installed. You are publishing an application named App1 that will use Integrated Windows authentication as shown in the following graphic.
    [​IMG]
    Use the drop-down menus to select the answer choice that completes each statement based on the information presented in the graphic.
    [​IMG]
    [​IMG]
    You have an application named App1. App1 is distributed to multiple Hyper-V virtual machines in a multitenant environment. You need to ensure that the traffic is distributed evenly among the virtual machines that host App1. What should you include in the environment?
    A. Network Controller and Windows Server Network Load Balancing (NLB) nodes
    B. Network Controller and Windows Server Software Load Balancing (SLB) nodes
    C. an RAS Gateway and Windows Server Network Load Balancing (NLB) nodes
    D. an RAS Gateway and Windows Server Software Load Balancing (SLB) nodes
    Your company has 10 offices. Each office has a local network that contains several Hyper-V hosts that run Windows Server 2016. All of the offices are connected by high speed, low latency WAN links. You need to ensure that you can use QoS policies for Live Migration traffic between the offices. Which component should you install?
    A. the Multipath I/O feature
    B. the Routing role service
    C. the Network Controller server role
    D. the Canary Network Diagnostics feature
    E. the Data Center Bridging feature
    Answer: CE
    You have a server named Server1 that runs Windows Server 2016 Server1 is a Hyper-V host You have two network adapter cards on Server1 that are Remote Direct Memory Access (RDMA) - capable. You need to aggregate the bandwidth of the network adapter cards for a virtual machine on Server1. The solution must ensure that the virtual machine can use the RDMA capabilities of the network adapter cards. Which command should you run first? To answer, select the appropriate options in the answer area.
    [​IMG]
    [​IMG]
    You have a server named Server1 that runs Windows Server 2016. You need to configure Server1 as a multitenant RAS Gateway. What should you install on Server1?
    A. the Network Policy and Access Services server role
    B. the Remote Access server rote
    C. the Data Center Bridging feature
    D. the Network Controller server role
    You need to modify the GPO prefix by IPAM. What should you do?
    A. Run the Set-lpam Configuration cmdlet
    B. Click Provision the IPAM server in Server Manager
    C. Click Configure server discovery in Server Manager
    D. Run the lnvoke-lpam Gpo Provisioning cmdlet
    P.S. Free 70-743 Exam Dumps shared by passleader.com On Google Drive:
  2. giddygiddy
    giddygiddy Member
    Jan 26, 2016
    Thank you for this
    please has anyone confirmed the validity of this?
