Zaixkingg
Self-Study materials are useful study tools that only works when you have short time like me. 1Y0-240 dumps pdf of is one of the best study material I ever use. Because most of Citrix NetScaler Essentials and Traffic Management Exam questions are from this valid 1Y0-240 braindumps.
I share some questions from 1Y0-240 dumps pdf which I also see in real Citrix 1Y0-240 exam:
Which command should a Citrix Administrator use to configure a Content Switching virtual server for implementing the Secure Web Gateway in the transparent
proxy mode?
A. add cs vserver swgVS PROXY 192.168.10.1 80 Authn401 on authnVsName explicit-auth-vs
B. add cs vserver swgVS PROXY ** Authn401 on authnVsName explicit-auth-vs
C. add cs vserver swgVS PROXY 192.168.10.1 Authn401 on authnVsName transparent-auth-vs
D. add cs vserver swgVS PROXY * 21 Authn401 on authnVsName transparent-auth-vs
Users are experiencing resets from the Intranet server website, which is load-balanced through the NetScaler.
Which NetScaler tool can a Citrix Administrator use to troubleshoot the reset issue?
A. Take a packet trace with nstrace and analyze with WireShark.
B. View the new nslog from the command-line interface (CLI) to look for packet resets from the NetScaler.
C. Look in the Event Viewer for packet resets from the NetScaler.
D. Use the nslog to look for packet resets on the NetScaler.
Which policy will allow a Citrix Administrator to modify all the URLs in the response body from http:// to https:// in an SSL offload deployment?
A. add rewrite action Act1 replace_all HTTP.RES.BODY(200000) \http://\" pattern https://
add rewrite policy Pol1 true Act1 NOREWRITE
B. add rewrite action Act1 replace_all HTTP.RES.BODY(200000) \http:\" pattern https://\
C. add rewrite action Act1 replace_all HTTP.RES.BODY(200000) \https://\" pattern http://
D. add rewrite action Act1 replace_all HTTP.RES.BODY(200000) \https:\" pattern http://
