2018 Cisco CCNP 300-101 Braindumps
Discussion in 'General Certification' started by ammyjhon, Nov 6, 2018.
  1. ammyjhon
    ammyjhon Member
    Jul 10, 2018
    503
    22
    I passed the Cisco Certified Network Professional Routing and Switching with 300-101 dumps pdf!!!! I am so happy I used the Cisco 300-101 exam dumps on realdumpspdf.com to study. I have never been so nervous in my life but I knew I was prepared. It was definitely worth every penny. I’m now a step closer to Cisco certified, thank you!!!
  2. tinamark
    tinamark Member
    Oct 31, 2018
    109
    Friends I pass my cisco 300-101 exam. And according to my opinion Pass4surekey is best because I prepared from there. For the relevant and latest
    visit Pass4surekey. Pass4surekey will provide you the 300-101new questions which will be asked from you in the 300-101real exam. So, as far as my concern Pass4surekey is best for you if you want to pass 300-101in just first attempt with good grades. Here is an opportunity for you to buy Cisco 300-101pdf dumps with 100% guaranteed success. For more detail you can visit:
    Some important questions that you must prepared before exam:
    A network engineer notices that transmission rates of senders of TCP traffic sharply increase and decrease simultaneously during periods of congestion. Which condition causes this?
    A. global synchronization
    B. tail drop
    C. random early detection
    D. queue management algorithm
    Which three problems result from application mixing of UDP and TCP streams within a network with no QoS? (Choose three.)
    A. starvation
    B. jitter
    C. latency
    D. windowing
    E. lower throughput
    Correct Answer: ACE
    Which method allows IPv4 and IPv6 to work together without requiring both to be used for a single connection during the migration process?
    A. dual-stack method
    B. 6to4 tunneling
    C. GRE tunneling
    D. NAT-PT
    A network administrator executes the command clear ip route. Which two tables does this command clear and rebuild? (Choose two.)
    A. IP routing
    B. FIB
    C. ARP cache
    D. MAC address table
    E. Cisco Express Forwarding table
    F. topology table
    Correct Answer: AB
    Which two actions must you perform to enable and use window scaling on a router? (Choose two.)
    A. Execute the command ip tcp window-size 65536.
    B. Set window scaling to be used on the remote host.
    C. Execute the command ip tcp queuemax.
    D. Set TCP options to "enabled" on the remote host.
    E. Execute the command ip tcp adjust-mss.
    Correct Answer: AB
    markalan037 likes this.
  3. markalan037
    markalan037 Member
    Sep 5, 2018
    1,034
    238
    B. tail drop
    A. starvation
    B. jitter
    C. latency
    D. windowing
    E. lower throughput
    Correct Answer: ACE
    B. 6to4 tunneling
    C. GRE tunneling
    D. NAT-PT
    A. IP routing
    B. FIB
    C. ARP cache
    F. topology table
    Correct Answer: AB
    Correct Answer: AB
    Thanks tinamark for sharing this valid study material.
  • Smith Lee
    Smith Lee Member
    Oct 23, 2018
    507
    Thank you for providing the solid and dependable
    material. The way the guides are organized really helped me study and the practice test questions helped me to take the test and pass. Remarkable thanks to braindumpskey.
