Elsa Kong
January/2019 Braindump2go AZ-101 Exam Dumps with PDF and VCE New Updated Today! Following are some new AZ-101 Real Exam Questions:
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet the stated goals. Some question sets might have more than one correct solution, while others might not have a correct solution.
After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
You have an Azure web app named App1. App1 runs in an Azure App Service plan named Plan1. Plan1 is associated to the Free pricing tier.
You discover that App1 stops each day after running continuously for 60 minutes.
You need to ensure that App1 can run continuously for the entire day.
Solution: You change the pricing tier of Plan1 to Basic.
Solution: You add a triggered WebJob to App1.
Solution: You change the pricing tier of Plan1 to Shared.
You have an Azure Active Directory (Azure AD) tenant named Adatum and an Azure Subscription named Subscription1. Adatum contains a group named Developers. Subscription1 contains a resource group named Dev.
You need to provide the Developers group with the ability to create Azure logic apps in the Dev resource group.
Solution: On Dev, you assign the Logic App Contributor role to the Developers group.
Solution: On Subscription1, you assign the Logic App Operator role to the Developers group.
QUESTION 6
Solution: On Subscription1, you assign the DevTest Labs User role to the Developers group.
QUESTION 9
You manage a virtual network named VNet1 that is hosted in the West US Azure region.
VNet1 hosts two virtual machines named VM1 and VM2 that run Windows Server.
You need to inspect all the network traffic from VM1 to VM2 for a period of three hours.
Solution: From Azure Monitor, you create a metric on Network In and Network Out.
QUESTION 10
A web developer creates a web application that you plan to deploy as an Azure web app.
Users must enter credentials to access the web application.
You create a new web app named WebApp1 and deploy the web application to WebApp1.
You need to disable anonymous access to WebApp1.
What should you configure?
A. Advanced Tools
B. Authentication/Authorization
C. Access control (IAM)
D. Deployment credentials
QUESTION 11
You are building a custom Azure function app to connect to Azure Event Grid.
You need to ensure that resources are allocated dynamically to the function app. Billing must be based on the executions of the app.
What should you configure when you create the function app?
A. the Windows operating system and the Consumption plan hosting plan
B. the Windows operating system and the App Service plan hosting plan
C. the Docker container and an App Service plan that uses the B1 pricing tier
D. the Docker container and an App Service plan that uses the S1 pricing tier
1.|2019 Latest AZ-101 Exam Dumps (PDF & VCE) 70Q&As Download:
https://www.braindump2go.com/az-101.html
2.|2019 Latest AZ-101 Exam Questions & Answers Download:
https://drive.google.com/drive/folders/1KoBQez_BqgPlnBE-cCoz8OkAoozD-2g9?usp=sharing
brackdeen
Passing the AZ-101 exam is no more difficult, with latest AZ-101 dumps pdf anyone can easily pass the AZ-101 exam on the first attempt! The best thing is 100% success rate & money back assurance.
Note:- New Questions has been added to the AZ-101 PDF.
Get the complete Microsoft AZ-101 Question Answers PDF & Start preparation:- AZ-101 Dumps 2019
https://www.realdumpspdf.com/exam/az-101-dumps-pdf/
Product Features:
1) 100% Success Rate
2) Money Back Assurance
3) Up-to-date Questions
4) Instant Download
5) Free Updates for 3 months
