20696 - Administering System Center Configuration Manager and Intune
Discussion in 'Administering and Deploying System Center' started by ovidiu_viper, Mar 31, 2017.
  1. ovidiu_viper
    ovidiu_viper Member
    Nov 24, 2015
    I have created this thread to discuss about the 20696 MOC and I'm looking forward to start learning this product. This is a new course and I could not find any relevant materials on CBT Nuggets or Pluralsight.
    Best regards,
    Viper
  2. UncleB
    UncleB Member
    Mar 18, 2017
    64
    What about:
    3 separate exams there.
  3. UncleB
    UncleB Member
    Mar 18, 2017
    64
    If you need training material, then start at the exam blueprint:
    The course you specify is part of the training toward this exam, but the training blueprint is here:
    Next follow up with reading up some relevant ebooks to find out more about the subjects:
    Some video training is available:
    Microsoft virtual academy is also a great place to find material to help:
    I notice the Microsoft book is from 3 years ago so won't help much:
    or download it from:
    I can't vouch for the legality of the source, but if you are unsure then don't download it (I checked and it is the correct file).
    You are going to have to put in some hard work to pull it all together but the bits you need are all online and free.
    If you get the chance, please put together a guide on how you did it and share it here to give something back to the community :)
  4. UncleB
    UncleB Member
    Mar 18, 2017
    64
    There is a more detailed breakdown of the current course content here:
    Between the links above and this, you should have all you need.
  5. UncleB
    UncleB Member
    Mar 18, 2017
    64
    I had a look at the Microsoft site and the student course material is available there:
    What you can't download are the virtual machines needed to create the lab environment for the course, but these are gigabytes of data so are not normally available online. These are only available to certified trainers normally.
  6. ovidiu_viper
    ovidiu_viper Member
    Nov 24, 2015
    Thank you for all the material you have provided I have started with the MOC manual (
    ). Once I will get more familiar with the content (read the book at least twice) I will continue with the sources provided by you.
  7. walls
    walls Member
    Mar 25, 2017
    81
    I have this premium file and i share to all.
    nilah likes this.
  8. planetork
    planetork Member
    Apr 23, 2017
    Im looking for the premium files,planetork@gmail.com
  • planetork
    planetork Member
    Apr 23, 2017
    why did you say you had the premium ? , you know the had changed
    nilah likes this.
  • planetork
    planetork Member
    Apr 23, 2017
    Does anyone have the lastest version of this exam which includes windows 10 & case studies of recloud & adatum , please no fake replies from dump companies, you dump is out of date
  • ovidiu_viper
    ovidiu_viper Member
    Nov 24, 2015
    You have a Microsoft System Center 2012 R2 Configuration Manager primary site named ST1.
    To all client computers, you deploy the Endpoint Protection client from Configuration Manager and
    an antimalware policy named Policy1.
    You need to ensure that the Endpoint Protection status is updated every 10 minutes in the
    Monitoring workspace. What should you do?
    A. Run the Set-CMClientStatusUpdateSchedule cmdlet.
    B. Modify the Endpoint Protection status schedule summarization.
    C. Modify the Policy1 Advanced settings.
    D. Run the Set-CMClientStatusSettings cmdlet.
    Is B the correct answer?
  • ovidiu_viper
    ovidiu_viper Member
    Nov 24, 2015
    I would say it's B: Information that is displayed in the Endpoint Protection Status node is based on the last data that was summarized from the Configuration Manager database and might not be current. If you want to retrieve the latest data, on the Home tab, click Run Summarization, or click Schedule Summarization to adjust the summarization interval.
  • Cozy
    Cozy Member
    May 15, 2017
    Hi
    Any have an updated exam for 70-696
