deenjhon
Choose a sure shot way towards your success in CCNP Data Center Cisco Certified Network Professional Data Center certification exam with Cisco 300-180 dumps of (Pass4surekey). We guarantee your Cisco Certified Network Professional Data Center success with 100% money back assurance. An exclusive collection of valid and most updated 300-180 Questions Answers is the secret behind this assurance. So feel free to get benefits from such valuable 300-180 Exam Dumps and enjoy brilliant success in Cisco Certified Network Professional Data Center exam. Get huge discount 30% off on all products by using this coupon code “PASS”. Visit us for more information https://www.pass4surekey.com/exam/300-180.html
Smith Lee
Thanks for sharing accurated material in your post.
Favor Chaussée
The new CCNP 300-180 DCIT dumps (Sep/2019 Updated) now are available, here are part of 300-180 exam questions (FYI):
NEW QUESTION 459
Multicast packets enter a leaf switch from a front panel interface and the leaf switch finds a route for the multicast packets. Which two additional components does the leaf switch provide? (Choose two.)
A. EPG of the destination subnet prefix
B. local interfaces of the local receivers
C. VTEP IP address of the local interface
D. outer destination IP address to use in the VXLAN encapsulation across the fabric
E. VTEP IP address of the remote leaf switch where the destination endpoint is present
NEW QUESTION 460
The service profile for a vSphere host has been migrated from a B200 M3 blade to a B200 M4 blade. After booting, the host is not accessible from vCenter. What is the root cause?
A. Firmware on the blade is incompatible with the service profile.
B. The service profile did not have a vNIC placement policy.
C. The operating system must be reinstalled on new hardware.
D. The service profile association process has failed.
NEW QUESTION 461
A server administrator creates a new vNIC template to use when creating service profiles. The administrator uses this template as part of a service profile template to create eight service profiles. Then the administrator adds an additional VLAN, but the service profiles do not reflect this change. What happened?
A. The server created the VLAN on the wrong fabric.
B. The server administrator used an updating service profile template.
C. The server administrator used an initial vNIC template.
D. The domain has disjoint L2 and cannot find an uplink to pin the new VLAN.
NEW QUESTION 462
A Cisco ACI leaf connected to an external bridged network fails to receive traffic for the correct VLANs. Which two actions do you take to resolve the issue? (Choose two.)
A. Ensure that the EPG is bound to a port correctly.
B. Confirm that all the Cisco APICs are online an in quorum.
C. Ensure that the correct context is assigned to the BD.
D. Check the port channel to the leaf switch.
E. Ensure that the correct contract is assigned.
NEW QUESTION 463
Which command can you run to verify that new images are healthy and compatible for an upgrade or a downgrade?
A. show install all impact
B. show incompatibility system
C. show incompatibility-all system
D. show module all
NEW QUESTION 464
You have a Cisco Nexus 1000V Series Switch that fails to connect to its VEMs. Which reason could cause this issue?
A. The standby VSM is offline.
B. The packet and control interfaces use the same VLAN.
C. The VMware vCenter firewall allows ports 80 and 443 only.
D. The capability I3control command is set on the packet interface.
NEW QUESTION 465
You are troubleshooting Cisco AVS by using the CLI of the VMware ESXi host. You must get this information. Dvs name, Remote IP, Port, and Switching Mode. Which command do you run?
A. vemcmd show port
B. vem status
C. vemcmd show openflex
D. vemcmd show sod
NEW QUESTION 466
In end-host mode, for which type of port are MAC addresses stored in a forwarding table?
A. monitoring
B. cluster
C. uplink
D. server
NEW QUESTION 467
After an IP address pool is deleted from Cisco UCS Manager, none of the assigned addresses are reallocated. Which action reallocates the previously assigned IP addresses?
A. Delete the associated service profiles.
B. Reboot the servers associated with the service profile.
C. Delete and recreate the Ip address pool.
D. Enable the vNIC that was previously assigned an address.
NEW QUESTION 468
You are performing a software upgrade and want to see the progress. Which command do you run?
A. show install all status
B. show log | include error
C. show system internal log install history
D. show system internal log install details
NEW QUESTION 469
A customer has a Cisco Nexus switch that has an FEX in an offline state. Which statement do you tell the customer?
A. The FEX is online currently.
B. The FEX is offline currently.
C. The FEX can be switched to an online state.
D. The state does not indicate the actual state or presence of the FEX on the switch port.
NEW QUESTION 470
When troubleshooting a VXLAN on a Cisco Nexus 9000 Series Switch, which information can you verify by running the show nve vni command?
A. the VxLAN VNI status
B. the VXLAN to VLAN mapping
C. the MAC Address table
D. the Overlay Peer
NEW QUESTION 471
Download more NEW Pass Leader 300-180 PDF dumps from Google Drive here:
Read the newest Pass Leader 300-180 exam questions from this Blog:
Erika Jacobs
TheExamCerts provide latest and updated 300-180 exam material for your future. To get updated 300-180 Troubleshooting Cisco Data Center Infrastructure exam dumps visit our site. Boost your career with TheExamCerts. In recent days, the IT Certification has become a global standard for many successful IT companies we have 100% trusted Cisco 300-180 exam dumps material. After the inspection of our Cisco experts, we are here to help you by providing a latest and updated Cisco 300180 exam material.So Use our most latest 27%off by using this coupon 27%OFF2019. We give 100% money back guarantee in case of failure for further study visit our guarantee page. If you want to achieve your goal within a limited time, hurry to join us. You can also study our free Cisco 300-180 exam demo before purchase. Visit the link below and get updated Cisco 300-180 Exam Dumps Material and Pass in First Try: https://www.theexamcerts.com/Cisco/300-180-pdf-exam-dumps
Favor Chaussée
The new CCNP 300-180 DCIT dumps (Nov/2019 Updated) now are available, here are part of 300-180 exam questions (FYI):
NEW QUESTION 477
You deploy a multiple FCoE network. What must you consider when you configure the VFC ports?
A. All of the switches in the paths must supported vFC Type NL ports.
B. All of the switches in the paths must have the same FC-MAP.
C. All of the switches in the paths must supported vFC type E ports.
D. All of the switches must have the same VSAN list.
NEW QUESTION 478
You configure your network to extend the Layer 2 domain beyond the Cisco ACI fabric. You nobce that the interfaces that connect to external devices are in a down state. What should you do?
A. Reboot the Cisco ACI fabric.
B. Configure the fabric node polices for the correct connectivity group.
C. Configure the interface policies to match the peer device.
D. Manually push the policies of the shared services to the node devices.
NEW QUESTION 479
Which statement about SAN port channels is true?
A. The port VSAN on both ends must be set to 1 always.
B. The port VSAN on both ends must match.
C. The port VSAN on both ends must be different.
D. The port VSAN on both ends must be on the allowed VSAN list.
NEW QUESTION 480
Which credentials must you have to download firmware for Cisco UCS B-Series Servers?
A. a cisco.com account associated with a valid service account
B. a service account
C. a cisco engineering account
D. a CEC account
NEW QUESTION 481
Which action do you take to recover a Cisco UCS Director password?
A. Use SSH to log in to the device, and then reset the password.
B. Mount the Cisco UCS Director image on a KVM, reload the device, and then reset the password.
C. Log into the Cisco UCS Director appliance as root, and then run the admin password reset script.
D. Press CTRL-Break when the system boots, and then configure the config-register command to ignore the current configuration.
NEW QUESTION 482
When does unicast RFP drop a packet?
A. when there is no reverse path route on the receiving interface
B. when the packet comes from an RFC1918 address
C. when the destination address is not in the routing table
D. when the source address is not in the routing table
NEW QUESTION 483
When you attempt to allocate an interface from an N7K-M132XP-12 card to a VDC, you receive this error message:
“VDC-MGR-2-VDC-BAD: vdc_mgr: There has been a failure at gim (port-affected_list)”
Which is a possible cause of the error?
A. You are not logged in to Admin VDC.
B. The line card does not have any free ports.
C. The interface is part of a dedicated port group.
D. There are not enough system resources.
NEW QUESTION 484
Which statement about port channels is true?
A. All member ports should be in up state for the port channel to be up.
B. All member ports in a port channel need not use the same speed and duplex.
C. It is recommended to make changes in the individual member ports that are part of the port channel.
D. Each port can be in only one port channel.
NEW QUESTION 485
You must check the status of the configuration synchronization of a peer switch. Which command do you run?
A. Show peer status
B. Show switch peer
C. Show synch peer
D. Show switch-profile peer
NEW QUESTION 486
Which two commands or tools must you use to recover from a zone merge failure in VSAN 10? (Choose two.)
A. switch# zoneset import interface fc 1/3 vsan 10
B. Fabric Manager > Zone > Merge Analysis
C. switch(config)# import zoneset interface fc 1/3 vsan 10
D. Fabric Manager > Zone > Merge Fail Recovery
E. switch# import zoneset interface fc 1/3 vsan 10
F. switch(config)# zoneset import interface fc 1/3 vsan 10
NEW QUESTION 487
Which can cause a failure of a Cisco UCS Fabric Interconnect uplink to the upstream switch?
A. a speed mismatch
B. a CDP version mismatch
C. a duplex mismatch at a speed of 10 Gbps
D. an IP address mismatch
NEW QUESTION 488
The customer has a Cisco UCS Central cluster. An external CA server is configured which uses a third-party certificate in addition to keys LQAP authentication fails and has a certificate status of Failed to Verify with Private Key. What could cause the failure?
A. The contents of the certificate do not match the certificate request that was created.
B. The certificate was not issued from a trusted point.
C. The certificate box is empty.
D. There is a time skew between Cisco UCS Central and the CA server.
NEW QUESTION 489
A. The capability control command is set on the packet interface.
D. The standby VSM is offline.
NEW QUESTION 490
When configuring an FCoE host connection, you discover that interface vfc1 fails to come up: vfc1 is bound to interface eth1/10. Which cannot you run to check that the connected host supports FIP?
A. Show platform software fcoe-mgr into interface eth1/10
B. Show system internal dcbx info interface vfc1
C. Show platform software dcbx internal info interface vfc1
D. Show platform software fcoe-mgr info interface vfc1
NEW QUESTION 491
