70-246 vce
Discussion in '70-246 Exam Files' started by Sacriestory, Oct 24, 2015.
Thread Status:
Not open for further replies.
  1. Doyle
    Doyle Member
    Dec 5, 2015
    26
    Update on the mixed questions :
    1:B
    2:Server 1: VMM
    Server 2:VMM
    Server 3:Config Manager
    Server 4:Config Manager
    Server 5:Config Manager
    3: A & C I believe, got to do some testing on this
    4:Server 1: Synthetic transaction
    Create a Run as Account
    Modify a run as profile (two created as default for synthetic transactions)
    Distribute a run as profile (ie. to the watcher node)
    Thoughts are welcome on that question source:
    5: OM1 and SQL 2 (standard SPF without usage would require VMM console )
    6:A
    7: B as you can assign an agents management server based upon an LDAP query
    Any thoughts on my answers are welcome!
    I am agree except Q3. Creating a recovery point for online just takes last local recovery point and replicate it to Azure. To be sure that it consist most resent files you should make new recovery point or (after synchronization) or to synchronize already existed recovery point. So C and E are correct answers. There is no Incremental backup option at all for file servers.
    I had some doubts about Q4 ("Distribute run as Account" was my choice for last line) and Q7 but it seems that you are right
  • metro
    metro Well-Known Member
    Supplier Contributor Member
    228
    Hey guys,
    I posted Relecloud here:
    Lets answer the case study together
  • metro
    228
    Hey try this link.
    I bought the dump (oh well, just need to pass now) may as well share it.
    Hello aoades
    Thanks for sharing, do you have the latest passleader with 204 questions?
  • Doyle
    Doyle Member
    Dec 5, 2015
    26
    Hello aoades
    This is the latest 189 + 15
  • metro
    228
    oh!! Ok great thank you very much for sharing!
  • wggut1
    wggut1 Member
    Jan 2, 2016
    Hi all, there are more new mixed questions for this exam. I took this exam and failed in December. I had also a couple of other questions I do not see on this forum. one I remember was to choose for local backup or online backup(azure) or a combination of this in some scenario: keep daily backups one year, weekly backups for 5 years etc...
    Some of you guys have more mixed questions or remember some on the exam?
    cheers
  • Doyle
    Doyle Member
    Dec 5, 2015
    26
    Hi, I just passed - total 50Q including 22 mixed and 4-5 from each test case. 5-6 was new or modified- I remembered only two which were totally new.
    First one was related to Analysis Management Objects (AMO) - 1 Install AMO on VMM, 2. Install SSRS on SCOM and 3. Configure connection to SQL on SCOM. More info here http://blogs.msdn.com/b/scstr/archive/2015/11/22/step-by-step-tutorial-how-to-integrate-scom-2012-r2-with-scvmm-2012-r2.aspx
    Second one asked how to ping monitored computer related to incident from SCSM. There are tree pull down tabs and you must choose between Configuration Items - Create computer - Related items (filter by) or Work Items - Create View ....
    I realized question about Server11111QUESTION 14NOTE THAT QUESTION OF SERVER 11111
    DROP DOWN QUESTION
    YOU CHOSE 1,2,2,2
    SERVER 1
    SERVER 2
    SERVER 2
    SERVER 2
    It is from Relecloud case and it is related to creating and deploying Runbook automation - what you must do from where. Beware - here Server2 is Server Manager but also an Authoring Tool.
    One more question was related to DPM backup on two data centers. You must have 365 daily backups, monthly backups for 2 years and yearly backups for 7 years and you must have option to restore backup if both of data centers fail. Different choices are available including Azure and tape backup. I choose Azure because of last requirement but I am not sure about that.
  • metro
    228
    Well done!! What was your score? 7** or 8*** ?
    Did you change any of the answers from passleader VCE?
  • Doyle
    Doyle Member
    Dec 5, 2015
    26
    775 - it could be better but still enough
    There are several mistake that I found in last Passleader
    Q64 and Q158 which we already discussed
    Northwind traders Q5
    Q185
    Q186
    Q50 - it is OK in PDF but wrong in VCE
    Ant one thing more - I had modified version of Q94 - instead "Create and synchronize an Orchestrator connector" it was just "Synchonize bla bla ..."
  • metro
    228
    That is really useful mate, i will modify the file and upload it here so that other users can pass as well!!
    Congrats again!!
    Are you taking 247 soon?
  • O-o
    O-o Member
    Congratz Doyle!
    Looking forward to it Metro.
    Will go through it as well to see if we missed anything.
  • lawchellie
    lawchellie Member
    Dec 28, 2015
    Hello folks, just passed 246. My sincere thanks to all you especially Doyle, Metro. passleader and yumper were really helpful as well. Looking forward to more participation on this forum.
    Thank you all once again. Moving ahead with 247
  • wggut1
    wggut1 Member
    Jan 2, 2016
    Hi guys congrat to the ones who passed the exam.
    Iam confused about three questions. who can help
    3.
    question 3 of examcollection:
    You have a system center 2012 R2 Operations Manager deployment. The Operations Manager agent is deployed to all servers in your environment. Your company has a Microsoft Azure subscription. You need to ensure you can identify which servers comply with Microsoft best practices by using an azure-based services. Choose appropriate options below:
    Tool to use - The System Advisor Webpage
    -? <<>> But was Concerning Azure--
    -? <<>>Was Concerning Dpm--
    Action to Perform -Download the windows agent and deploy it to the servers
    - Download the gateway and the agent and deploy them to the servers
    -Register to azure operational insights and add the servers
    thanks in advance for all who helped with all the questions for this exam 70-264
  • aoades
    aoades Member
    Dec 1, 2015
    Hello all! Just passed today, 4/5 relecloud questions were new for me, all very similar to other question from other cases though! Scored 800 with the use of passleader + doyle and others contributions!
    Onwards to 70-247 hope to speak you over on that thread
  • jcololo
    jcololo Member
    Jan 18, 2016
    Hello all, passed 70-246 today, >700 was my second attempt, Beware!!! You will not get the same questions as in your 1st attempt. Microsoft reshuffles the questions making it quite a tough task to pass. Moving to 70-247 Thanks goes to doyle and others.
  • Sacriestory
    Sacriestory Well-Known Member
    Contributor Member
    61
    How valid is this VCE?
    #76 Sacriestory, Jan 26, 2016
  • mbongeni
    mbongeni Member
    Jan 18, 2016
    Please email me your "246 Update" that is withthe correct asnwers thank you
  • Superman
    Superman Member
    Dec 14, 2015
    Do we have an updated 246 vce file yet, or is the best way to proceed to take the original one and edit that to add/change the questions from the thread?
  • Chuck
    Chuck Member
    Jan 25, 2016
    16
    Who can verify a valid VCE? I have lost the overview.
  • trouble4k
    trouble4k Administrator
    Staff Member
    164
    Wait a few more days. A new file has been prepared by Sacriestory and will be shared in the coming days.
  • Thread Status:
