70-331/332 SharePoint Exams?
Discussion in 'Microsoft Certifications General' started by examtestsforfree, Feb 3, 2016.
  1. ex
    Jan 23, 2016
    Has anyone recently taken 331, and if so, do you have any test dumps you would recommend to assist in preparing for it? Getting ready to take mine soon and would be great to build my confidence I I can find a dump that is at least somewhat valid. This goes for the 332 as well. Thanks in advance
  2. ex
    Jan 23, 2016
    Passed my 70-331!
    Well, took my 70-331 test today using the Exam Collection premium dump, and passed with a 817 today.
    However, some of the mixed questions have the wrong answers on the dump, a few new questions on the test, but the Case Studies where exactly the same as on the dump as far as questions go.
    Also, there are a few questions on the test that appear exactly as on the dump, except they changed one line, so it required you to change one portion of the answer.
    I recommend if you use the dump, study it and verify all the answers via Technet or other Microsoft source, and be sure to read the details of each question before selecting your answer on the test.
  3. Naruc
    Naruc Member
    Dec 19, 2015
    70
    Can you post the vce file
  4. ex
    Jan 23, 2016
    VCE File
    Should let you download it from there.
  5. Naruc
    Naruc Member
    Dec 19, 2015
    70
    Tanks. I hope I will take the exam asap.
  6. ke
    kettex Member
    Mar 1, 2016
    Hi, would it be possible to share the 331 dump once again?
    Have you taken the 332 also?
  7. de
    demiengineer Member
    Mar 8, 2016
    227
    Took my 70-331 test yesterday, passed with 976/1000 in US!
    Thanks God!
    Guys, there are many new questions added in the 2016 test....
    headache....
    If someone want the 70-331 exam questions i had in my test, please tell me...
    I will share with you:cool:
  8. Ho
    Hotte Member
    Jan 2, 2016
    i would gladly take them... need to prepare for that soon.
  9. la
    lab4tech Member
    Feb 5, 2016
    Hi there,
    can you possibly provide the exam 331 to me ? please :D
  10. Ca
    Cameron Member
    Feb 22, 2016
    please do share :)
  11. de
    demiengineer Member
    Mar 8, 2016
    227
    Hi Guys,
    Okay, many people want my 70-331 questions:D....
    I will share some 2016 new 70-331 exam questions with you:cool:
    some people ask me personally for 70-331 pdf dumps, i will try my best to send it to you personal mail.
    QUESTION
    Drag and Drop Question
    An organization uses Microsoft SharePoint 2013 to host content on an intranet.
    You need to configure the firewalls to open the ports for SharePoint.
    Which firewall ports should you open? To answer, drag the appropriate port to the correct services. Each port may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
    * 443 TCP (HTTPS/SSL)
    Encrypted client to SharePoint web server traffic (Encrypted SharePoint ?Office Web Apps communication)
    * TCP, 32844 -Communication between Web servers and service applications
    * 25 TCP/UDP - Simple Mail Transfer Protocol (SMTP)--used for e-mail routing between mail servers
    * Workflow Manager Management Port: Set port 12290 to use an SSL encrypted connection
    * TCP, 22233-22236 - Ports required for the AppFabric Caching Service Incorrect answer:
    Not TCP 80, http, Client to SharePoint web server traffic (SharePoint Office Web Apps communication)
    QUESTION
    You have a SharePoint farm.
    You need to configure Active Directory Federation Services (AD FS).
    Which three actions should you perform in sequence? (To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.)
    Phase 0: Install and configure an AD FS server (we can assume that this has already been done here).
    Phase 1: Configure AD FS with the web application as a relying party
    Phase 2: Configure SharePoint 2013 to trust AD FS as an identity provider
    Phase 3: Configure web applications to use claims-based authentication and AD FS as the trusted identity provider
    Incorrect answers:
    * the web application is they relying party, not ADFS
    * We should not configure SharePoint to trust AD FS as an identity provider, instead the web applications should trust AD FS as an identity provider.
    QUESTION
    A company is upgrading to SharePoint Server 2013.
    You plan to migrate an existing PHP eCommerce site to SharePoint Server 2013.
    The ecommerce site has the following requirements:
    - Users must be able to browse all products available.
    - Users must be able to drill down on specific product attributes.
    - Product attributes must be stored as managed metadata.
    You need to determine which components you should implement.
    Which components are required? To answer, select the appropriate option from each list in the answer area.
    * Cross Site Publishing is required as metadata will be used as product attributes. You can use cross-site publishing to create an Internet business site that contains a catalog that shows products to customers, based on metadata. Users view pages that are created dynamically based on navigation, and filter results based on additional refinements. The site may also show content such as a company contact page, shipping and handling rates, and job openings. Content is authored internally, and is made available to anonymous users outside the firewall. You can use cross-site publishing to create a knowledge base that is available to internal and external users in an extranet site. Content authors tag pages with metadata to categorize articles so that users can search or browse for specific information, such as troubleshooting articles, support issues, and service packs.
    * Managed metadata service is required as product attributes must be stored as managed metadata.
    * Search Web Parts is required as users must be able to browse (search) the products.
    * Secure Store Service is not required as single-sign on is not required. The Secure Store Service replaces the Microsoft Office SharePoint Server 2007 Single Sign On feature. Secure Store Service is a shared service that provides storage and mapping of credentials such as account names and passwords. It enables you to securely store data that provides credentials required for connecting to external systems and associating those credentials to a specific identity or group of identities.
    * Device Channels is not required as there is no requirement that the web pages should be rendered in different devices (such as mobile phones, tablets).
    A device channel is part of the SharePoint 2013 publishing infrastructure that enables you to render certain site content, style your content, and even change images--while maintaining the same URL across a pool of different devices.
    sorry,,,,just can attach 5 pics in the post,,,,so the last pic cannot be uploaded:rolleyes:
  12. de
    demiengineer Member
    Mar 8, 2016
    227
    Okay, someone ask me to share my 70-331 and 70-332 study materials.....
    I will paste one good Google Drive study materials share i found online with you:
    70-331:
    70-332:
  13. ke
    kettex Member
    Mar 1, 2016
    Thanks a lot! Great :D
  14. ro
    rosu555 Member
    Jun 17, 2016
    hi could you please advise me for the preparation for this sharepoint exam. Which dump is recommended to follow,
  15. ca
    cabesacortisa Member
    Jun 3, 2016
    Some vce or pdf premium file for share ?
    thanks.
  16. cu
    cupdance Member
    Dec 13, 2015
    Any who took this recently give an insight to how man drag and drops they had etc?
  17. ga
    gareth12468 Member
    Jan 9, 2016
    Any comments for the 70-331 exam?
    Scheduled to take it this month.....
    #17 gareth12468, Aug 9, 2016
  18. ga
    gareth12468 Member
    Jan 9, 2016
    Passed 70-331 last Saturday with 843..... 10 new questions and at least 2 rephrased questions or answers..... Case studies OK.....
  19. Sa
    May 28, 2016
    17
    Very nice
    I think this one MB2-712 is latest and cheapest too.
  20. jo
    john_bel19 Member
    Oct 10, 2016
    Hello. Does some one have dump or pdf that is still valid for 70-332 exam ? Thank you
