70-345: Topic 1, Fabrikam inc. Discussion and Corrections
Hadzi
Here will be posts all corrections from this topic (when we are finished I'll post complete vce and pdf)
Topic break down
Topic No. of Questions
Topic 1: Fabrikam inc. 7
Topic 2: Relecloud. 8
Topic 3: Contoso Ltd, 7
Topic 4: Mix Questions 97
Corrections:
Hadzi
- (Topic 1)
You need to recommend changes to the messaging infrastructure. The changes must meet the connectivity requirements
after the planned upgrade.
Which two actions should you recommend? Each correct answer presents part of the solution.
A. From the Mailbox servers, import the Edge Subscription file.
B. On the Edge Transport Servers, start Edge Synchronization.
C. On the Edge Transport servers, import the Edge Subscription file.
D. On the Edge Transport servers, create an Edge Subscription file.
E. On the Mailbox servers, restart the Microsoft Exchange Transport service.
Correct Answer: AE
Section: Topic 1: Fabrikam inc.
- (Topic 1)
You begin to implement the Exchange Server 2016 servers and plan to decommission the Exchange Server 2013 servers
during the next six months.
You need to recommend which actions must be performed to support the planned changes for document collaboration.
You install Microsoft Office Online Server on a new server.
Which two cmdlets should you recommend running next? Each correct answer presents part of the solution.
A. New-OfficeWebAppsFarm
B. Set-PartnerApplication
C. Set-MailboxServer
D. New-OfficeWebAppsHost
E. Set-OrganizationConfig
Correct Answer: AC
- (Topic 1)
You need to recommend a solution for the users involved in the legal disputes.
What should you include in the recommendation?
A. a journal rule
B. an Outlook protection rule
C. an in-place Hold
D. a Litigation Hold
- (Topic 1)
You deploy Layer 7 load balancers to the New York and London offices.
You are planning the namespace configuration that will be used once you complete the planned upgrade to Exchange
Server 2016.
You need to recommend a solution to meet the connectivity requirements for the namespaces.
What should you recommend?
A. On the New York office servers, change the internal URLs to mail.fabrikam.com.
B. On all of the branch office servers, change the external URLs to Snull.
C. On all of the branch office servers, change the external URLs to mail.fabnkam.com.
D. On the New York office servers, change the internal URLs to Snull.
- (Topic 1)
You need to recommend changes to the existing environment to meet the high-availability requirements for the mailbox
databases.
A. Run the Suspend-MailboxDatabaseCopy cmdlet
B. Run the Update-MailboxDatabaseCopy cmdlet.
C. Deploy a file share witness to a branch office.
D. Modify the cluster resource properties.
QUESTION 6
- (Topic 1)
databases.
A. Run TheSet-MailBoxDatabasecmdlet.
B. Run theSet-DatabaseAvailabilityGroupcmdlet
C. Run theSet-MailBoxServercmdlet.
D. Run theSet-MailBoxDatabaseCopycmdlet.
QUESTION 7
HOTSPOT - (Topic 1)
You need to configure a data loss prevention (DLP) policy to meet the compliance and security requirements.
How should you configure the policy rule? To answer, select the appropriate options in the answer area.
Hot Area:
Correct Answer:
astrixco
- (Topic 1)
Correct Answer: AE
- (Topic 1)
Correct Answer: AC
- (Topic 1)
A. a journal rule
C. an in-place Hold
- (Topic 1)
Server 2016.
- (Topic 1)
databases.
QUESTION 6
- (Topic 1)
databases.
QUESTION 7
HOTSPOT - (Topic 1)
Hot Area:
Correct Answer:
Question 4) should be B) to be proxied
"All external client connections from the branch office users must be proxied from the New York office to
the branch offices."
question 6) should be C)
Set-MailboxServer -Identity -DatabaseCopyAutoActivationPolicy IntrasiteOnly
Dac
Hi Hadzi,
Do you have vce od pdf with 120 q&a?
If you do, could you share it?
Thanks,
Dac
Yalcin80
Yes a PDF would be usefull, then we all could offer possible answers or include new additional questions we might have found somewhere else. So sharing it via Zippyshare (or similar) would be great.
Yalcin80
This looks exactly like all the versions which are currently offered on various sites (where you can buy dumps). I have exactly the same version but payed 49 Euro for it. The bad part is that the sites fake the date, the version you and I have seamed to be from December 2016 / Januar 2017 and all what the sites do currently is to change the date to face a "hey this is a up to date dump". Where did you got your version from?
Dac
These questions were also bought from a dumps site.
I compared the Q&A with demos from TestKing, Pass4Sure and CertKiller and none of the questions were from 120 Q i have.
Are you planning to take the exam soon?
Yalcin80
Ah ok, that explains why i then have the same version. I did the same comparison and didn´t found a difference here... yes i plan the exam in 14-21 days. Based on that i can give you some feedback if the dump is still valid if you like.
Dac
Ok, if i find some update with the Q&A i will keep you informed.
jhonaddison
Validate your 70-345 Exam learning and preparation with our most updated 70-345 dumps. (Dumpspedia.com) has experienced IT experts who gather and approve a huge range of Microsoft 70-345 Questions Answers for MCSE Certification seekers. Practicing our 100% updated 70-345 Practice Tests is a guaranteed way towards your success in Microsoft 70-345 Braindumps.
jvdn1990
Guys I will also lookout for an updated Q&A also planning to take this exam, if one of you passes please let know the score
astrixco
I found this question related to fabrikam., suggested answer is 4 and 2, But i think 2 namespaces and 2 DAGs should be enough, any suggestions?
You need to recommend how many database availability groups (DAGs) and how many namespaces
must be added to the site resilience solution to meet the availability requirements.
How many namespaces and DAGs should you recommend adding? To answer, select the appropriate
NOTE: Each correct selection is worth one point.
