70-410 Valid Dump
Discussion in '70-410 Exam files' started by Sacriestory, Oct 25, 2015.
  1. Sacriestory
    Sacriestory Well-Known Member
    Contributor Member
    65
    20
    Sorry for the Delay Guys and Girls but is very heavy dump.
    This is the Lasted Version. Valid and tested
    Thanks to Enya and hokalinux
    IMPORTANT INFORMATION:
    Please consider this Dump as a tool to help and improve lack areas.
    Never must be considered as a replacement for the experience and formal study.
    Microsoft always update their exams, the accuracy of the information provided here is not warranted
    For Internal use only.
    VCE
    Microsoft-70-410-Sacriestory_MCSA_FreeForums.vce
    PDF
    Microsoft-70-410-Sacriestory_MCSA_FreeForums.pdf
    #1 Sacriestory, Oct 25, 2015
  2. Hussie
    Hussie Member
    Shortly i will retake this exam and will use your dump.
    I will let you know how it ends
  3. trouble4k
    trouble4k Administrator
    Staff Member
    166
    Best of luck! share any new questions you might find with us after the exam!
  4. RunePup
    RunePup Member
    Oct 30, 2015
    104
    30
    VCE
    PDF
    Okay so I previously asked for the password to the file and I received no response. If you are not going to give out the password could you please break it down into 30 question sections for me please.
  • trouble4k
    Staff Member
    166
    PM Sacriestory, he might be able to assist.....
  • Yuriy.Yulian
    Yuriy.Yulian Member
    Nov 4, 2015
    This is Valid as today (USA), took the test, scored 800+
  • RunePup
    RunePup Member
    Oct 30, 2015
    104
    30
    Congrats buddy. Did you by any chance remember any of the differences of the test you took and file?
  • mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    can get the exam pdf here for 410 400+ question all u need remeber them all & hit the exam ;)
  • Yuriy.Yulian
    Yuriy.Yulian Member
    Nov 4, 2015
    I didn't have any thing different that I remember
    #9 Yuriy.Yulian, Nov 5, 2015
  • Chrispy
    Chrispy Member
    Nov 6, 2015
    I found a question I believe is incorrect in the vce. Exam A, Q130
    ........You need to ensure that DHCP clients in both subnets can connect to any other DHCP client by using a FQDN.
    What should you add?
    Says that answer should be "The 006 DNS Servers option to Subnet2". My teacher and I researched and believe it should be "The 015 DNS Domain Name option to Subnet2."
    There was a technet source provided in the explanation, I think just the wrong answer was chosen as the right one accidentally. Let me know if we are definitely wrong.
    Thanks!
    #10 Chrispy, Nov 6, 2015
  • RunePup
    RunePup Member
    Oct 30, 2015
    104
    30
    You and your Teacher are correct.
    Here is a picture that may help.
    #11 RunePup, Nov 6, 2015
  • stoka
    stoka Member
    Nov 8, 2015
    It's valid, took the test today, scored 8xx.
    Two new questions:
    Your network contains one Active Directory domain named contoso.com. The domain contains 10 domain controllers and a read-only domain controller (RODC) named RODC01.
    You plan to deploy a child domain for contoso.com in Microsoft Azure.
    To the Azure subscription, you add several virtual machines that have a Server Core installation of Windows Server 2012 R2.
    You need to create the new domain on one of the virtual machines.
    Which tool should you use?
    A. the ntdsutil command
    B. the Set-ADDomain cmdlet
    C. the Install-ADDSDomain cmdlet
    D. the dsadd command
    E. the dsamain command
    F. the dsmgmt command
    G. the net user command
    H. the Set-ADForest cmdlet
    Your directory contains one AD domain named contoso.com. The domain contains 10 domain controllers that run Windows Server 2012 R2. 8 domain controllers are writable domain controllers.
    You need to deploy several read-only DC in contoso.com by using pre-staged computer accounts.
    Which two tasks should you perform? Each correct answer presents part of solution.
    A. run the Install-AddsDomainControler cmdlet
    B. create an authentication policy
    C. join the servers to contoso.com
    D. run the Add-AddsReadOnlyDomainControllerAccount cmdlet
    E. create an authentication policy silo
    F. run the adprep /rodcprep command
  • Halim
    Halim Member
    Oct 31, 2015
    Thanks Sacriestory your dumps was very Helpful i pass with 800
  • enya
    enya Well-Known Member
    Contributor Member
    254
  • elusive926
    elusive926 Member
    Nov 23, 2015
    Thank you guys I will test these out next week.
  • 7ijjawi
    7ijjawi Member
    22
    hello guys , i failed this exam 3 times , I'm gonna write it again tomorrow , please confirm if this dump is valid , thanks
  • 7ijjawi
    7ijjawi Member
    22
    PAAAAAAAASSSSSSSSSSSS , 816 , 95% questions from here , thanks alot , finally MCSA after 3 fails on 410 , and one fail in 411
  • trouble4k
    Staff Member
    166
    Well done!!! A lot of people passed this days !!
  • 7ijjawi
    7ijjawi Member
    22
    thanks , I'm looking to have ITIL dump now
  • Trystar1
    Trystar1 Member
    Nov 9, 2015
    Pass, 833.
    Thanks a lot !
