70-410 Valid Dump
Discussion in '70-410 Exam files' started by Sacriestory, Oct 25, 2015.
  1. iamreal
    iamreal Member
    Jul 27, 2016
    What is the correct answer to this question. Please explain. I appreciate it.
    You have a server named Server1 that runs Windows Server 2012 R2.
    You plan to create a storage pool that will contain a new volume.
    You need to create a new 600-GB volume by using thin provisioning. The new volume must use the
    parity layout.
    What is the minimum number of 256-GB disks required for the storage pool?
  2. djzirconium
    djzirconium Member
    Aug 21, 2016
    Hi IAMREAL I use this site for most vce questions and answers, just put the question in the search and you'll get the correct answer and explanation .For you specific question here is the link to the answer:
  3. iamreal
    iamreal Member
    Jul 27, 2016
    And this..
    The domain contains two domain controllers named DC1 and DC2 that run Windows Server 2012 R2.
    The domain contains a user named User1 and a global security group named Group1.
    You reconfigure DC2 as a member server in the domain.
    You need to add DC2 as the first domain controller in a new domain in the forest.
    Which cmdlet should you run?
    A. Add-AdPrincipalGroupMembership
    B. Install-AddsDomainController
    C. Install WindowsFeature
    D. Install AddsDomain
    E. Rename-AdObject
    F. Set-AdAccountControl
    G. Set-AdGroup
    H. Set-User
    Is it C or D?
  4. djzirconium
    djzirconium Member
    Aug 21, 2016
    Answer C, Explanation:
    Since a member server does not have Active Directory Domain Services installed, you must install
    this role before you can configure the new Domain Controller (which would require you to run
    Install-ADDSForest).
  5. djzirconium
    djzirconium Member
    Aug 21, 2016
    Please see
    for the answer
  6. iamreal
    iamreal Member
    Jul 27, 2016
    Thanks djzirconium!
  7. micleong
    micleong Member
    Mar 16, 2016
    I study Sacriestory...i think i only encounter 2 or 3 new questions..
  8. Mouratov
    Mouratov Member
    Jan 27, 2016
    188
    22
    Thanks for share!
    It was 42 questions? Sacriestory is good to go right?
  • trouble4k
    trouble4k Administrator
    Staff Member
    164
    Thanks for share!
    Its the best option right now
    Mouratov likes this.
  • Fakerofthewest
    Sep 11, 2016
    From USA ,
    Took 70-410 Monday afternoon used sacriestory to study as well as read a few books + 5 years of professional experience.
    49 questions , Around 20 questions were similar from the dump , names had been changed , port numbers changed , similar question structures but the dump answer would be wrong in the context asked. Encountered around 7 new questions with exhibits not even remotely close to the rip. The rest were completely new questions.
    I had around 6 questions focusing on IPv6. Make sure you know how to subnet to determine number of networks and hosts . 2 of the IPv6 questions were from the rip but had their questions and answers modified such as changes to host requirements and order.
    Passed with a 791 but I felt comfortable with the material since I learned how to solve the questions and not just memorized the answers .
    If I had just memorized the questions on the rip and filled in the blanks I believe I would have scored around a 300 ...
    trouble4k likes this.
  • roger8080
    roger8080 Member
    Aug 16, 2016
    Sorry for the Delay Guys and Girls but is very heavy dump.
    This is the Lasted Version. Valid and tested
    Thanks to Enya and hokalinux
    IMPORTANT INFORMATION:
    Please consider this Dump as a tool to help and improve lack areas.
    Never must be considered as a replacement for the experience and formal study.
    Microsoft always update their exams, the accuracy of the information provided here is not warranted
    For Internal use only.
    VCE
    Microsoft-70-410-Sacriestory_MCSA_FreeForums.vce
    PDF
    Microsoft-70-410-Sacriestory_MCSA_FreeForums.pdf
    Thanks a lot really appreciate
  • Mouratov
    Mouratov Member
    Jan 27, 2016
    188
    22
    Hello guys
    I can confirm that sacerstory file still valid.
    About 4 maybe 5 new questions.
    Remember one that is to configure reverse lookup zone in powershell IPV4
    skater_7 likes this.
  • skater_7
    skater_7 Member
    Feb 2, 2016
    46
    Did you take an exam?
  • Mouratov
    Mouratov Member
    Jan 27, 2016
    188
    22
    Yes
    And sacerstory is valid
  • skater_7
    skater_7 Member
    Feb 2, 2016
    46
    thank you buddy.will go for next month. :)
  • BCAA7
    BCAA7 Member
    Jul 10, 2016
    MY exam is coming up pretty soon. I will have to get this done quick. Now the VCE how would I play that ? is there a free tool I could use?
  • skater_7
    skater_7 Member
    Feb 2, 2016
    46
    A+VCE player. Use android emulator(Andy,Bluestacks...)
  • phool4fool
    phool4fool Member
    Sep 5, 2016
    44
    Can you please share updated version of 70-410 Sacriestory 2.0
    I've downloaded current vce file but it show v1.0
    Please share v2.0 of 70-410 Sacriestory 2.0 file
  • skater_7
    skater_7 Member
    Feb 2, 2016
    46
    the only file that i have is one on this page. i dont know is there any 70-410 Sacriestory 2.0?
  • BCAA7
    BCAA7 Member
    Jul 10, 2016
    Oh great there's a V2 ugh! I been going over the first version one. Hopefully the version on here 'v1' is the most current one.
