70-410 Valid Dump
Discussion in '70-410 Exam files' started by Sacriestory, Oct 25, 2015.
  1. mycertifychataccount
    Oct 30, 2015
    Is there a version 2 of Sacriestory 70-410?
  2. ansn26
    ansn26 Member
    Jan 24, 2016
    I passed today with about 800. Good dumb. It were 49 questions.The dumb is still valid. Only few new questions were there. 1 Ipv6 question, 1 RODC, 1 Azure question from the dumb. Anybody know if its allowed to get MCSA passing 70 410, 70 411 and 74 409 exept 70 412?
  3. Esylos
    Esylos Member
    Sep 23, 2016
    Passed today, dump is still valid. Like ansn26 said i counted 3 questions who were not in this dump. Only remember one that was about RODC. But no worries, if you study this dump and use some common sense, you are good to go.
    Thanks for all the effort!
  4. phool4fool
    phool4fool Member
    Sep 5, 2016
    44
    can anyone mention questions with wrong answers in Sacriestory dump file????
  5. BCAA7
    BCAA7 Member
    Jul 10, 2016
    I know there's one question that has to do with resize the vhd...
    VM1 uses a fixed size virtual hard disk (VHD) named Disk1.vhD. Disk1.vhd is 200 GB.
    You shut down VM1.
    You need to reduce the size of disk1.vhd.
    Which action should you select from the Edit Virtual Hard Disk Wizard?
    A. Merge
    B. Compact
    C. Shrink
    D. Convert
    but some other site is saying is 'convert'
    so what is the correct answer?
  • Dido
    Dido Member
    Oct 11, 2016
    Hello ,
    ready for download?
  • phool4fool
    phool4fool Member
    Sep 5, 2016
    44
    You shut down VM1.
    A. Merge
    B. Compact
    C. Shrink
    D. Convert
    D: Convert is Correct Answer
  • phool4fool
    phool4fool Member
    Sep 5, 2016
    44
    Hello ,
    ready for download?
    May be someone has v2 of Scriestory 70-410 as in valid dumps section, it is mentioned v2 but after you download; it's v1
  • skater_7
    skater_7 Member
    Feb 2, 2016
    46
    there is no 20.sacriestory but i have also new vce that has corrected answers and also new one that are not in sacriestory.
    here is the link to download all vce and the best one with corect answers is john
  • RunePup
    RunePup Member
    Oct 30, 2015
    104
    30
    I know 4 people who passed the exam very very recently using this material. So it is still valid.
  • skater_7
    skater_7 Member
    Feb 2, 2016
    46
    i didnt say that it isnt valid, just saying that it has a few wrong answers and some of them that are new and not in the vce. I shared the link to everyone to download with new questions (latest)
  • Nash
    Nash Member
    Nov 1, 2016
    Hi
    Looking for current 70-410 exam dumps - Where can i find them ?
  • nicky
    nicky Member
    Dec 6, 2015
    Hi, does anybody have the VCE player or know where to find it. Appreciate it.
  • BCAA7
    BCAA7 Member
    Jul 10, 2016
    Exam i coming up pretty soon. I been looking over some question but I started towards the end of the PDF to review since I believe those are the most current questions. Seems like it's going along good but checking some what the questions to make sure they are correct. Very nervous about the exam coming up. Don't feel like failing again ... Hopefully some of the verbiage is still the same and they haven't changed it like other user mention on here.
  • ismail halim
    ismail halim Member
    Nov 28, 2016
    It's valid, took the test today, scored 8xx.
    Two new questions:
    Your network contains one Active Directory domain named contoso.com. The domain contains 10 domain controllers and a read-only domain controller (RODC) named RODC01.
    You plan to deploy a child domain for contoso.com in Microsoft Azure.
    To the Azure subscription, you add several virtual machines that have a Server Core installation of Windows Server 2012 R2.
    You need to create the new domain on one of the virtual machines.
    Which tool should you use?
    A. the ntdsutil command
    B. the Set-ADDomain cmdlet
    C. the Install-ADDSDomain cmdlet
    D. the dsadd command
    E. the dsamain command
    F. the dsmgmt command
    G. the net user command
    H. the Set-ADForest cmdlet
    Your directory contains one AD domain named contoso.com. The domain contains 10 domain controllers that run Windows Server 2012 R2. 8 domain controllers are writable domain controllers.
    You need to deploy several read-only DC in contoso.com by using pre-staged computer accounts.
    Which two tasks should you perform? Each correct answer presents part of solution.
    A. run the Install-AddsDomainControler cmdlet
    B. create an authentication policy
    C. join the servers to contoso.com
    D. run the Add-AddsReadOnlyDomainControllerAccount cmdlet
    E. create an authentication policy silo
    F. run the adprep /rodcprep command
  • obama2016
    obama2016 Member
    Jun 2, 2016
    Hi everyone..... I would like to know if this dump is still valid ...
  • Mansur
    Mansur Member
    Nov 8, 2016
    Hi All,
    Dump is still valid:) successfully passed today with almost 900.
  • Julian Matuc
    Julian Matuc Member
    Dec 2, 2016
    37
    Thanks!
  • obama2016
    obama2016 Member
    Jun 2, 2016
    Thanks Mansur !!!
  • BCAA7
    BCAA7 Member
    Jul 10, 2016
    Question for you guys. Did you guy study all the question on the dump ? Some of the questions I seen on the exam last week I didn't see in the pdf file that comes with it?
    How did you guys study for the exam? Did you go over all the questions or some of f them? What is your study habit?
