admin
Administrator
Staff member
New VCE created by RunePup.
Many thanks to all the contributors especially RunePup who created the file and helped the community!
IMPORTANT INFORMATION:
Please consider this Dump as a tool to help and improve lack areas.
Never must be considered as a replacement for the experience and formal study.
Microsoft always update their exams, the accuracy of the information provided here is not warranted
For Internal use only.
Zippyshare.com - 70-412 RunePup.zip
To edit and improve this file check the below tutorial
http://www.certifychat.com/tutorials-how-to/639-create-vce-files-visual-cert-exam.html
IT IS REALLY IMPORTANT FOR THE COMMUNITY TO SHARE YOUR EXPERIENCE AFTER YOUR EXAM SO WE CAN DO THE NECESSARY AMENDMENTS AND KEEP THE FILE UP TO DATE AND ACCURATE
Good luck to everyone
RunePup
Make sure when you download the share that you do not update the program or it will stop working
leon24
Thank you very much
Thank you all for the great Work! Is here anyone who could be so nice to convert this file in a pdf format for me? Thank you very much in advance! Leon
Heisenberg
Hello guys,
Is this the most accurate (at the moment) dump or should I use the old one first and after that use this one? I am asking because I've been studying until now, and from today I will start using dumps to confirm the knowledge and practice more. Thanks
RunePup
Hello guys,
Never hurts to use both.
I know people personally who used this material to pass and some on this board, and people who used the other material and this material as well me included. So combining the two couldn't hurt at all. I gathered all of the material for this exam from a source that someone on the forums used over at aiotestking and said they passed using. I put it together as a vce and corrected the answers via aiotestking users. Good luck
Heisenberg
Thanks a bunch! I was wondering because there are 246 questions I think, while in the previous dump (as far as I remember) there are like 400 questions. Also I was asking because I bet that in the last dump if there were wrong questions, here they would've been corrected. This is why I would prefer to use this one instead but was wondering if it is enough maybe. But yes, I'll check the old one as well but probably at the end. I'll focus on this one more and hope by the end of the month to pass it. Thank you for the help you're providing here. People like you make this forum so awesome, not rookies like me
RunePup
I have updated this VCE folks. I have added the questions from the other VCE that's listed on this site. I have also corrected some of the Hot spots that were not working correctly.
I have provided the link below.
https://drive.google.com/open?id=0BwAaR97BTX2EdFBhVjVKYWRLbUU
If the admin could update the zippy share link for me with this file thanks.
Again remember do not update the program when you open it or it will stop working.
adamus
Hi RunePup,
I am going to exam in next week. Can you be kind and upload also pdf version of this vce?
I will be very grateful.
regards,
adamus
andre2015
Hi Runepup,
It contains some wrong answers.
Like this one
You need to ensure that the Include all folders that store the following kinds of data list displays an
entry named Corporate Data.
A.
Modify the properties of the System Files file group.
B.
Create a new classification property.
C.
Create a new file group.
D.
Modify the Folder Usage classification property.
Your answer is B but it should be D
adamus
Hi andre2015,
If you are sure which questions have a incorrect answers please write in this topic. Maybe RunePup or I will be able to correct it.
adamus
Hi
In my opinion question Q2 of exam J has bad answer. I think that should be C ? Anybody can check it?
Heisenberg
Exam D, Q10 is wrong I think. In the explanation it shows me that it is wrong. It should be Add-CauClusterRole, but the correct answer in the dump is Invoke-CauScan
RunePup
There may be some, not many wrong answers however that's why I put in a designer file as well. Now for the most part the file should be fine. I have also compared it to the previous file Sas put on the forums earlier last year. .
Heisenberg
you did a great job and we are all thankful for your help and time spent to make this dump. I am practicing and I believe I will pass the next week because of your help. A few wrong questions are not a problem at all, we all need to research and practice and not learn only dumps...which I sadly do with 412 but the time puts a pressure on me a lot!
raggy561
All dumps usually have wrong answers. Just use google and research it yourself. Even, better test it out and implement it in an environment to see if it is correct.
Anyways, thank you RunePup. I'm sure I will pass with this and learn a lot from this dump.
