70-413 February 2016 VCE
Discussion in '70 - 413 Exam Files' started by kwnl031, Jan 31, 2016.
  1. kwnl031
    kwnl031 Member
    Nov 23, 2015
    21
    Thanks to Junk01 for all is work to gather all the question and correct answers together.
    Updated: 09 june 2016:
    Please let me know if there are errors in the VCE. It's was a hell of a job to create the file. So it's possible....
    Let me know, and I will fix it.
    If you think there are questions missing, post them in the thread so we can include them.
    IMPORTANT INFORMATION:
    Please consider this Dump as a tool to help and improve lack areas.
    Never must be considered as a replacement for the experience and formal study.
    Microsoft always update their exams, the accuracy of the information provided here is not warranted
    For Internal use only.
    #1 kwnl031, Jan 31, 2016
  2. clevie
    clevie Member
    Jan 25, 2016
    Thanks for the great work on the files.
    In the case study for Prosware, Q6 & Q8 hot areas keep coming up as incorrect even though the correct answers were selected. When I click on show answer, the images on the answer page doesn't show which one is the correct answer as how it is shown in the pdf file.
    edit:
    scratch what i said earlier. was looking at the other file downloaded from the site...thanks
    #2 clevie, Feb 1, 2016
  3. zolti
    zolti Member
    Dec 15, 2015
    28
    kwnl031, great, thank you!
    but your vce file have a lot of mistakes. some questions didnt show image, some have not any correct answers. try to finish all questions of your vce and you see that.
  4. kwnl031
    kwnl031 Member
    Nov 23, 2015
    21
    Strange, I will take a look this evening...
  5. trouble4k
    trouble4k Administrator
    Staff Member
    164
    Hello mate,
    PM me the link so i can polish it up for you!
    I will not change any of your answers.
  • kwnl031
    kwnl031 Member
    Nov 23, 2015
    21
    Well, it seems like the VCE wasn't safe correctly last time. I recreate the VCE file and had tested it. Please let me know if there are problems.
  • trouble4k
    Staff Member
    164
    Good job creating an updated version for 413!
    I have checked your VCE file and also pm'ed you. Can you please let me know which VCE you used as your base file?
    It doesn't look like the one i published here on the forum...
  • Zahurcilla
    Zahurcilla Member
    Dec 18, 2015
    Hello!!
    Q6 in Proseware. Which is the correct? in VCE or in DOC
  • kwnl031
    kwnl031 Member
    Nov 23, 2015
    21
    Hello!!
    The DOC is leading! I will update the VCE.
  • Zahurcilla
    Zahurcilla Member
    Dec 18, 2015
    ok, ok. thank you!!
  • mcharalambous
    mcharalambous Member
    Jan 11, 2016
    44
    Is there any updated file?
    I would like to have it.
    Is it possible in pdf?
  • kwnl031
    kwnl031 Member
    Nov 23, 2015
    21
    The current link is the updated file. In the ZIP is also a .docx file.
  • olaf81
    olaf81 Member
    Dec 13, 2015
    You guys rock here!
    Thank you everyone who is contributing.
    Alpine-Sky.
    Q1. You need to perform the directory synchronization with Office 365.
    What should you do first?
    The answer should be Install the DirSync utility, imho.
    But the answer is Site -To_Site VPN.
    Q4. Expansion of LA office.
    The answer should be Install RODC- Answer A.
    There answer is D- Create GPO and apply to the LA site.
    The "Growth" area states: "Any server placed in LA office must not contain cached passwords",
    imho- gives you an idea that RODC cached passwords can be controlled by modifying "denied password groups" or "allowed password goups".
    Correct me if I am wrong.
    #13 olaf81, Feb 2, 2016
  • kwnl031
    kwnl031 Member
    Nov 23, 2015
    21
    Hi Olaf81,
    No, you should first setup a VPN. The DirSync utility must be installed in Azure.
    This is the requirement:
    Office 365
    Alpine Ski House must use Microsoft Azure to facilitate directory synchronization (DirSync) with Office 365. The DirSync utility must be installed on a virtual machine in Microsoft Azure.
  • jctech
    jctech Member
    Thank you very much for the vce! I believe the Proseware case study question number 6 is wrong, the fail over mode should be Hot Standby. It is stated at the requirements that "Only one DHCP server in each site must lease IP addresses at any given time." so no Load balancing is allowed for DHCP.
  • mcharalambous
    Jan 11, 2016
    44
    Thank you
  • olaf81
    olaf81 Member
    Dec 13, 2015
    Thank you kwnl031.
    Agreed on this. You are right.
    Any suggestion about Q4?
  • cino75
    cino75 Member
    Jan 18, 2016
    Hoi, Zou je een PDF van de VCE kunnen mailen naar mijn PM?
  • zolti
    zolti Member
    Dec 15, 2015
    28
    Contoso Ltd, Case B
    Question 6 in Word File and Vce file has different answer. Which is correct?
  • zolti
    zolti Member
    Dec 15, 2015
    28
    Drag'n'Drop question 5
    Image with answer is correct but Explanation did not.
