70-413 February 2016 VCE
Discussion in '70 - 413 Exam Files' started by kwnl031, Jan 31, 2016.
  1. Joker4U
    Joker4U Member
    Dec 9, 2015
    47
    Follow the February VCE WRONG ANSWER CORRECTION POST I SHARED IT.
  2. ahmed
    ahmed Member
    Dec 27, 2015
    Can you buplish the link here for certkingdom dump please
  3. MrSkiaa
    MrSkiaa Member
    Feb 16, 2016
    32
    first case study
    proserve..
    i have a doubt...
    QUESTION:
    you need to recommend a configuration for the DHCP infrastructure
    what should you recommend? to answer, select the appropriate options in the answer area
    vce february ANSWER:
    first box: DC02
    second box: load-balanced
    third box: state switchover interval
    i think that the second box is wrong
    the case study says (technical requirements)
    Only ONE dhcp server in each site must lease ip addresses at any given time
    so i think that the right answer (for the second box) is hot standby.
    does somebody agree with me?
    #83 MrSkiaa, Apr 11, 2016
  4. Joker4U
    Joker4U Member
    Dec 9, 2015
    47
    first case study
    proserve..
    i have a doubt...
    QUESTION:
    first box: DC02
    Yes you are right I can agree with you. Later I ll send the explanation
  • Certify-Chat
    Certify-Chat Member
    Mar 23, 2016
    Like This one. It was on the exam but with differend names and numbers.
    If you know the theory you wi lbe able to answer the question no matter what they change
  • Meena
    Meena Member
    Mar 19, 2016
    37
    Passed with 850...the dump is still valid..
  • MrSkiaa
    MrSkiaa Member
    Feb 16, 2016
    32
    passed with 9XX
    about 20% of new or modified questions
  • robin5188
    robin5188 Member
    Apr 18, 2016
    I passed with 775 on 4/23, thanks so much, this vce is sitll vaild. I met around 5~7 new questions, fortunate, I passed it.
  • micleong
    micleong Member
    Mar 16, 2016
    I passed with 8XX, the vce is still valid, thank you so much, I had around 3 to 4 new questions...
  • j0ngmoi
    j0ngmoi Member
    Apr 27, 2016
    thank you brother
  • Poorna
    Poorna Member
    Apr 27, 2016
    Hello guys,
    Anyone did the exam for the last few days using this question bank?
    Regards
  • orangejulius
    orangejulius Member
    Apr 20, 2016
    first case study
    proserve..
    i have a doubt...
    QUESTION:
    first box: DC02
    I think I agree with you too. When I first saw this question and the answer, it didn't make any sense to me. Load balanced would simply try to spread the DHCP load between both servers.
  • shinzor
    shinzor Member
    May 22, 2016
    Thanks kwnl031, junk01 and certifychat. Had the exam today passed with 9xx.
    Total of 50 questions, 35 mixed and 15 from cases.
    I think 2 or 3 new questions. And like 7-8 with adjusted either introduction, context or answers. Like some mentioned before.
    A Question about server 1 has been changed to file 1, context is still the same.
    (Not sure if i remember it correctly, but 1 new question):
    Windows 7 and Windows 2012 clients.
    Clients connect through VPN, but when they disconnect they have to manually reconnect.
    Which protocol should you include in the recommendation, so clients will automatically reconnect.
    1. SSTP
    1. PPTP
    1. L2TP/IPSec
    2. IKEv2
    I am not sure, but answered IKEv2 (source:
    Same question, but different values in the answer.
    * From the exhibit we have:
    NPS01: weight 30, priority: 5
    NPS02: weight 50, priority: 90
    NPS03: weight 20, priority: 5
    I've filled in:
    Percentage of NPS01 services if NPS03 is unavailable 100%
    Percentage of NPS02 services if NPS03 is unavailable 0%
    Percentage of NPS02 services if NPS01 is unavailable 0%
    Percentage of NPS03 services if NPS01 is unavailable 100%
    My advice follow the discussion topics and try to get your own correct answer. Read the questions and context.
    Good luck all.
  • shinzor
    shinzor Member
    May 22, 2016
    Thanks a lot, passed today with 9xx!
  • hokalinux
    hokalinux Member
    May 4, 2016
    congratulations bro this dump is still valid ???
  • hokalinux
    hokalinux Member
    May 4, 2016
  • Poorna
    Poorna Member
    Apr 27, 2016
    Hello there,
    Congrats on passing the exam, what was the dump you practiced for this?
    Feb VCE?
    Regards
  • shinzor
    shinzor Member
    May 22, 2016
    I used the adjusted Feb VCE (adjusted by junk01,kwnl) as a base. I also verified some questions on aiotestking.com and the newer dumps on examcollections.com and read the comments from Enya on this forum. In the Exam (50 questions, 35 mixed and 3 cases each 5 questions). There were like 7 questions that had adjustments (different question, different answer), but the context is the same. So my advice is to carefully read it. There were like 3 or 4 questions that is completely new.
    I had for example "When VPN disconnects users have to manually reconnect, which protocol can make auto reconnect possible". I answered IKEv2. For example the VCE had a question about servicing. The VCE answer is 100%, 0%, 0%, 0%, but in the exam it was 100%, 0%, 0%, 100%. Understand how this works.
    Be aware that this may differe for you. If you understand the questions, i am pretty sure you can make 8xx with the adjusted feb vce dump.
    Good luck!
  • omarovic
    omarovic Member
    Mar 15, 2016
    today i pass 70-413. i only studied feb 2016 docx.
    all the questions where from the docx
  • armbox
    armbox Member
    May 16, 2016
    Passed 900, 80% valid.
