Well done mate!!!
Did you get that question?
And if yes, how did you answer?Click to expand...
70-413 November 2015 VCE
Discussion in '70 - 413 Exam Files' started by trouble4k, Nov 15, 2015.
Tags:
Page 1 of 12
i ll try to update & recall & post here abt exam
You are the administrator for a large company.
You plan to implement servers in the environment that do not use local hard drives.
You need to recommend a supported storage solution.
Which technology should you recommend?
A. Clustered NAS B. SMB C. ****forget
I choose D. iSCSISAN
Case Study 1 - Proseware Came in Exam
\You need to recommend a trust model.
What should you include in the recommendation?
A. A one-way, forest trust that has selective authentication. B. A one-way, external trust C. A two-way, external trust D. A one-way, forest trust that has domain-wide authentication
You need to recommend a configuration for the DHCP infrastructure.
What should you recommend? To answer, select the appropriate options in the answer area.
Drag and Drop Question
You need to recommend the VPN protocols for Proseware.
What should you recommend? To answer, drag the appropriate VPN protocols to the correct offices. Each protocol may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content,
You need to recommend a solution for the remote access servers.
A. Network address translation (NAT) B. Logging levels C. Packet filtering D. Packet tracing
Came in Exam
You need to ensure that external users can authenticate by using client certificates.
What should you do? More than one answer choice may achieve the goal. Select the BEST answer.
A. Enable Kerberos constrained delegation in litware.com.
B. To the perimeter network, add an Exchange server that has the Client Access server role installed.
C. Enable Kerberos delegation in litware.com.
D. Deploy UAG to contoso.com.
Your network contains an Active Directory domain named contoso.com. Your company has 100 users in the sales department. Each sales user has a domain-joined laptop computer that runs either Windows 7 or Windows 8.
The sales users rarely travel to the company's offices to connect directly to the corporate network.
You need to recommend a solution to ensure that you can manage the sales users' laptop computers when the users are working remotely.
What solution should you include in the recommendation?
A. Deploy a Microsoft System Center 2012 Service Manager infrastructure.
B. Deploy the Remote Access server role on a server on the internal network.
C. Deploy the Network Policy and Access Services server role on a server on the internal network.
I got 6 YES/NO Question in PAir of 2 Each
mostly New & they Changed wat we have got in YES or NO
You need to configure DNS for the Dublin office.
Which three actions should you perform in sequence?
To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
Thats same wat in file u can search
ONe totally NEw Question wth Screen shot
SRVR has IPAM Server role Install
Q : slection Select from tabs below to view the Mac-address of DHCP-Assigned IP Address
You manage a Network Policy Server (NPS) infrastructure that contains four servers named NPSPRX01,
NPS01, NPS02, and NPS03. All servers run Microsoft Windows Server 2012 R2.
NPSPRX01 is configured as an NPS proxy. NPS01, NPS02, and NPS03 are members of a remote RADIUS
server group named GR01. GR01 is configured as shown below
IMPORT % Question
Very Simple RUle
NPS01: weight 30, priority: 5
NPS02: weight 50, priority: 90
NPS03: weight 20, priority: 5
if any of high priority give it 100%
like if
%NPS01 in casee 02 is Down then 100%
%NPS02 if NPS03 is down in 0%
%NPS03 if NPS01 is down 100%
%NPS02 if NPS01 Down 0%
Case Study 5 - Alpine Ski
You need to perform the directory synchronization with Office 365.
What should you do first?
A. Set the domain functional level to Windows Server 2012. B. Upgrade the Office 365 licenses to Enterprise E4. C. Set the forest functional level to Windows Server 2012. D. Create a site-to-site VPN. E. Install the DirSync utility in the on-premises environment
You need to configure the connection between the new remote branch office and the existing branch offices.
What should you create?
A. SMTP site link B. Forest trust C. Certification authority D. IP subnet
You need to plan the expansion of the Los Angeles office.
A. Install a read-only domain controller in Los Angeles. B. Install a domain controller in Los Angeles. C. Create and apply a filtered attribute set to the Los Angeles site. D. Create and apply a Group Policy object to the Los Angeles site.
Case Study 7 - Line-of-business applications
You have an IP Address Management (IPAM) server that runs Windows Server 2012 SP1.
You need to integrate the IPAM server with System Center Virtual Machine Manager (SCVMM).
Solution: You Add IPAM SRV to SCVMM and run as dedicated user account named IPAM_svc
They Changed this Question answers
Link GPO6 to OU4 and configure loopback processing in GPO6.
B. Link GPO6 to OU1 and configure WMI filtering on GPO3.
C. Link GPO6 to OU1 and configure loopback processing in GPO6.
D. Link GPO6 to OU1 and configure loopback processing in GPO5.
Link GPO6 to OU4 and configure Security Setting in GPO6.
Link GPO6 to OU4 and configure loopback processing in GPO3.
these two options came i choose Secuirty Setting
