70-413 November 2015 VCE
Discussion in '70 - 413 Exam Files' started by trouble4k, Nov 15, 2015.
  1. ju
    junk01 Member
    Dec 28, 2015
    39
    On page 154 QUESTION 101 is incomplete because the right boxes are not visible.
    Your network contains an Active Directory forest name fabrikam.com. The forest contains two domains named fabrikam.com and contoso.com. All servers run Windows Server 2012 R2. The forest contains a DHCP server named Server1 and a DNS server named Server2.
    You need to recommend a solution to ensure that any computers that are neither members of contoso.com nor fabrikam.com receive a DNS suffix of guest.fabrikam.com.
    What two commands should you run? To answer, select the appropriate options in the answer area.
    In the two boxes on the left: In the two boxes on the right:
    Set-DHCPserverv4policisettings / fqdn NE-afrikan.com
    Set-DHCPserverv4dnssettings / computer name: server1 African.com / Polici name- foreign devices.
    Page 170 question24 its the same thing.
    I got the answer 95% for NPS01
    5 % for NPS02
    0% for NPS03 and 04.
    #181 junk01, Jan 2, 2016
  2. dm
    dmitry Member
    Dec 30, 2015
    A,C it's the same answer in other dump and u don't need AD
  3. ju
    junk01 Member
    Dec 28, 2015
    39
    I found a new question for the Case Study 3 - Litware, Inc
    Your company has a remote office that contains 1,600 client computers on a single subnet.
    You need to select a subnet mask for the network that will support all of the client computers.
    The solution must minimize the number of unused addresses.
    Which subnet mask should you select?
    A. 255.255.248.0
    B. 255.255.252.0
    C. 255.255.254.0
    D. 255.255.240.0
    Case Study 4 - Northwind Traders
    You need to recommend a solution for the sales reports.
    What should you include in the recommendation?
    A. BranchCache in distributed cache mode
    B. Offline files
    C. BranchCache in hosted cache mode
    D. Distributed File System (DFS)
    It should be answer A.
    DFS Namespaces (DFSN or DFS-N) and DFS Replication (DFSR or DFS-R) are role services in the Windows Server 2012 File and Storage Services role.
    The technical requirement states:
    - If a WAN link fails, users must be able to access all of the sales reports.
    This means you need a copy of the sales reports locally and that can be done with BranchCache in distributed cache mode.
  4. ti
    time2go Member
    Dec 26, 2015
    42
    A. 255.255.248.0
    B. 255.255.252.0
    C. 255.255.254.0
    D. 255.255.240.0
    B. Offline files
    We appreciate for your work friend. Thank you & god bles you..
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    You need to plan the expansion of the Los Angeles office.
    A. Install a read-only domain controller in Los Angeles.
    B. Install a domain controller in Los Angeles.
    C. Create and apply a filtered attribute set to the Los Angeles site.
    D. Create and apply a Group Policy object to the Los Angeles site.
    I think this is wrong, and answer is D.
  • ju
    junk01 Member
    Dec 28, 2015
    39
    This is from the case studie 5 Alpine Ski.
    The studie says:
    An additional sales office is located in Los Angeles. This office has client devices only and there is no IT staff.
    All servers in each office run Windows Server 2012 R2. All client devices in each office run Windows 8.1.
    Any server placed in the Los Angeles office must not contain cached passwords.
    And you do that with a GPO.
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    I think so
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    I think so
    B. Offline files
    Answer:A
  • Ca
    CaptainSA007 Member
    Nov 13, 2015
    hi guys. I will be writing 70-413 in the next few days. is there any new material that I must look out for ?
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    Thanks in the name of all us!!!!
  • je
    jerseyyo Member
    Dec 14, 2015
    @Emiort
    After doing some other research online I believe the answer is:
    WEB01
    http/webapp1.contoso.net
    WAP01
    WEB01
    SPN formatting does not include HTTPS, it only needs http service class defined:
    The HTTP service class The HTTP service class differs from the HTTP protocol. Both the HTTP protocol and the HTTPS protocol use the HTTP service class. The service class is the string that identifies the general class of service. Well-known service class names include "www" for a Web service and "ldap" for a directory service. Generally, the service class name can be any string that is unique to the service class. Be aware that the SPN syntax uses a forward slash character (/) to separate elements. Therefore, the forward slash character (/) cannot appear in a service class name.
    Further proven here:
    "A string that identifies the general class of service; for example, "SqlServer". There are well-known service class names, such as "www" for a Web service or "ldap" for a directory service. In general, this can be any string that is unique to the service class. Be aware that the SPN syntax uses a forward slash (/) to separate elements, so this character cannot appear in a service class name."
    If you scroll down you'll see this example: "Examples of SPN registrations: HTTP/www.contoso.com – Any page on the Web site on the default TCP port 80 for
    , that is
    Another forum source that states same thing:
  • ag
    agent-orange Member
    Dec 9, 2015
    Does someone has an updated VCE-file for this exam? The original file is from November.
  • ju
    junk01 Member
    Dec 28, 2015
    39
    @Emiort
    WEB01
    WAP01
    WEB01
    , that is
    Thank you for figuring it out.
    This is page 168 Question 23.
    It would be nice if people use a page and question number. This would make it easier for others to find and correct the answer in there PDF file.
  • ju
    junk01 Member
    Dec 28, 2015
    39
    @Emiort
    WEB01
    WAP01
    WEB01
    , that is
    This is question 23 on page 168.
    Thank you Jerseyyo.
    I would advice people to ad the question and page number. This would make it easier for people to find it and correct it in there own PDF file..
  • ju
    junk01 Member
    Dec 28, 2015
    39
    Lets hope the moderator approves my post now as its the second post that's needs approval.
  • s350z
    s350z Member
    Nov 3, 2015
    Does any one know if the dump in this thread (70-413 November 15 VCE) is still valid? if not, where to find an updated dump? intending to take 70-413 exam in few days! appreciate your kind reply.
  • lu
    lukasz162 Member
    Nov 5, 2015
    Today I passed my exam with 793/1000. Thank you for help.
    I had 3 new questions:
    - Yes/No. Integration IPAM and SCVMM
    - Simulation. There were IPAM diagram. I was asking about configuration DHCP and static MAC addresses
    - Drag and Drop. I had 4 physical disks and I had to create one logical volume and create shared folder
    It's all which I still remember.
    Good luck for everybody.
  • jeday1
    jeday1 Member
    831 / 45q
    Few scenarios all from dump, also yes/no questions ( some were a bit different, and i think i had same question twice )
    Great Thanks to all who helped with dump
    below are those changed questions / answers
    thanks, and good luck to all ;)
  • On
    OnOnOn Member
    Dec 20, 2015
    Question still Valid. Pass with 75x score. But please check the ans
    Some questions has little bit change "BEWARE"
    1.You are the administrator for a large company.
    You plan to implement servers in the environment that do not use local hard drives.
    You need to recommend a supported storage solution.
    A. Clustered NAS
    B. SMB ScaleOut-File Server
    C. DVD
    D. iSCSI SAN
    2. DD-Hoports Q24
    Drag the correct ans
    Percentage of authentication request that NPS01 services if NPS03 is unavailable:______%
    Percentage of authentication request that NPS02 services if NPS03 is unavailable:______%
    Percentage of authentication request that NPS02 services if NPS01 is unavailable:______%
    Percentage of authentication request that NPS03 services if NPS01 is unavailable:______%
    Ans selection: 100% / 0% / 5% / 10% / 50% / 90% / 95%
    Question 3
    DD-Hostsports, Q5. Dump is asking Server 1 migrate to Server 2. The actual question may be ask migrate Server 2 to Server 1. Please BEWARE!!!
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    A. Clustered NAS
    C. DVD
    D. iSCSI SAN
    2. DD-Hoports Q24
    Question 3
    I think answer is ISCSI SAN correct and in this qustion.
    I dont see what another can bee or ISCSI
