70-413 November 2015 VCE
Discussion in '70 - 413 Exam Files' started by trouble4k, Nov 15, 2015.
  1. jo
    john Member
    Nov 4, 2015
    Just like others are saying, dump still completely valid. Passed >850. Some questions "modified."
  2. ri
    rickyrosski1 Member
    Dec 31, 2015
    Hi I passed Thursday UK 7/1/16 score of 793 used trouble 4k and premium vce file on exam collection but trouble 4k / enya was the better vce plus check out discussion on some wrong answered on here. I also use ms press book and cbt nuggets. Exam as tough few questions I never seen. 4 case studies conoso, parmell, northwind and litware I think plus 24 multiple choice and select questions and then 4 other questions. Good luck and thanks trouble 4 k.
  3. kw
    kwnl031 Member
    Nov 23, 2015
    25
    Jeday1, thanks for your photo's. I think some answers where wrong. Like the VPN solution. Windows XP don't have DirectAccess. And notice the "can be managed" part, manage a client remotely is almost always DirectAccess.
    I doubt if the answer on the IPAM question is correct. Because IPAM can't support cross forest. Only solution is to migrate Contoso to the Fabrikam domain.
  4. ju
    junk01 Member
    Dec 28, 2015
    39
    Thanks Yeday1 for the photos.
    I think the first question is C.
    The second question is D.
    The third question is
    Sales: SSTP.
    Research: Direct access.
    Finance: PPTP.
    Fourth question:
    The required disk space for a Ipam server in 2012 is a minimum of 10 GB but recommended: 80 GB or greater* IPAM stores 3 years of forensics data (IP address leases, host MAC addresses, user login/logoff information) for 100,000 users in a Windows Internal Database. There is no database purge policy provided, and the administrator must purge data manually as needed.
    There are 5000 user and you need to store the IP utilization data for 6 years and eight months of event catalog data so I would go for answer A.
  5. revanger81
    revanger81 Member
    Nov 5, 2015
    100
    Sales: SSTP.
    Finance: PPTP.
    Fourth question:
    This fourth question is confused have lot theories about correct answer and most difrent answer in this and many other sites
  • th
    thinx Member
    Jan 5, 2016
    Hi, does anyone already have a new dump? As i can see there are many new questions and i'll be taking the exam in a few days. Thanks in advance.
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    I will take to this exam to after 10-15 days.
  • Ca
    CaptainSA007 Member
    Nov 13, 2015
    hi everyone. I hope that you'll are well. I am going to be writing 70-413 either tomorrow or on Thursday. do I have enough to pass this exam ? since if I pass I will become an MCSE
  • ju
    junk01 Member
    Dec 28, 2015
    39
    Hello Revanger.
    The fourth question.
    A company has a single forest and a single active directory (AD DS) domain named Farbrikam.com that runs server 2012. The Ad DC functional level and the domain functional level are both set at server 2012. You use IP address management (ipam) as the IP management solution. You have 2 DHCP servers named DHCP 1 and DHCP 2 and one IPAM server named IPAM1.
    The company plans to acquire a company called Contoso LTD witch has a single forest and a single active directory (AD DS) domain named contoso.com that is set at server 2008. All servers at contoso run windows server 2008.The IP management solution is based on a single DHCP server named server 3.
    server name operating system diskspace.
    DHCP1 server 2012 30gb.
    DHCP2 server 2012 30gb.
    IPAM1 server 2012 30gb.
    Server3 server 2012 30gb.
    The total amount of users is 5000.
    You have the following requirements:
    * the solution must be able to allocate 3 IP addresses for each user.
    * All the IP leases must be renewed every 2 days.
    You need to ensure that the corresponding servers will have enough capacity to store 6 years of IP utilization and 8 months of event catalog data.
    What should you recommend?
    A: add at least 40 gb of storage to the Ipam server.
    B: Migrate contoso.com to Farbrikam.com.
    C: add at least 20 gb of storage to the Ipam server.
    D: establish a forest trust between contoso.com and Farbrikam.com.
    B and D will do nothing to the size of the internal storage space of the ipam server.
    So there is A and C left.
    To calculate overall disk space requirements, use the following formula:Disk space = Base database size + Utilization data +
    Event catalog data
    According to the question there are 5000 users that need to allocate 3 IP addresses = 7500 ip addresses a day. This means according to the formula on TechNet site you need 2 GB / month = 12 x 6 years = 144 GB of disk space for the Utilization data if you don't purge regular and purging is not mentioned in the question. The base size is 1 gb. For the Event Catalog Data you should need a other 20 GB of disk space. Brings the total to 165 GB.
    So either my calculations are rubbish or the question it self has a fault in it or isn't very clear and you have to guess the best answer. Its not the first question I see in the MCSA/MCSE server 2012 exams that are very unclear or has a fault in it. I got a feeling that the team responsible for the exam questions is just throwing some questions together to get the questions pool bigger and bigger to make the exams harder to pass.
  • ju
    junk01 Member
    Dec 28, 2015
    39
    If you look in the pdf file on page 129/130 question 109 you find exactly the same question but only 1 of the answers is different.
    A. Add at least 20 GB of storage to the IPAM server.
    B. Migrate Contoso.com to Fabrikam.com.
    C. Establish a forest trust between Contoso.com and Fabrikam.com.
    D. Upgrade SERVER3 to Windows Server 2012.
    The file says : Correct Answer: D
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    Thanks Junk01
    Some of 2 answers is correct 20 or 40gb is correct
    Ipam server i think 40 gb in this qestion.
    Another qestion is definitly -Upgrade SERVER3 to Windows Server 2012
  • Tr
    Travis92 Member
    Jan 13, 2016
    Thank You
    Hi All,
    New to the thread, gona take my exam first thing tomorrow Morning, just want to say thank you for the dump, been studying it the whole day, i am very optimistic about it. Thank you everyone posting new questions. Beautiful people!!!
    I will surely share my outcome, any new questions etc...the least i can do:)
  • kw
    kwnl031 Member
    Nov 23, 2015
    25
    Hi All,
    Do you passed the exam?
  • sh
    Dec 30, 2015
    Hi Travis,
    Have you take this exam??
  • ju
    junk01 Member
    Dec 28, 2015
    39
    Hello Revanger.
    Event catalog data
    There now seems to be a 3e version of this question.
    C: add at least 60 gb of storage to the Ipam server.
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    Hi all
    I tomowrow go to exam taking!
    I will put my results i hope that be all right!
  • ju
    junk01 Member
    Dec 28, 2015
    39
    Good luck tomorrow with your exam.
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    Thank you great!
  • Tr
    Travis92 Member
    Jan 13, 2016
    Thank you everyone, thanks to this vce i passed my exam 734 / no new questions but definitely some wrong answers. Mostly correct. thanks for the support.
  • revanger81
    revanger81 Member
    Nov 5, 2015
    100
    Thanks for all a has passed today with 775!
    Good luck for all another candidates on this forum!
    See you on 414.
