70-413 November 2015 VCE
Discussion in '70 - 413 Exam Files' started by trouble4k, Nov 15, 2015.
  1. nottelling
    nottelling Member
    Dec 17, 2015
    Where is the junk01.pdf?
  2. junk01
    junk01 Member
    Dec 28, 2015
    36
    are the junk01 files And here you can find the
    made by kwnl031.
  3. d3000
    d3000 Member
    Jan 21, 2016
    42
    Finaly passed yesterday. :)
    Score 780
    Cases Proseware , Alpine Ski and Woodgrove Bank.
    35 Mixed questions, 15 drag n drops
    Like the first time, about 10 new/modified questions.
    3 questions about Azure, i saw them for the firs time.
    I remember some questions/answers, i think they were not in .vce :
    20 VPN Servers, A RADIUS server for each customer and one RADIUS proxy
    Three domain and Three sites
    Link GPO6 to OU4 and configure Security Setting in GPO6.
    One Drag n drop :
    Create a simple virtual Disk
    Create a parity Disk
    Create and Attach VHD
    create a simple Volume
    Create a Share
    Create a Pool of Disk
  4. Mishel
    Mishel Member
    Jan 5, 2016
    Hello all,
    I`m taking this exam on Wednesday, I use only this vce from 20-01.2016, will this be enough?
  5. nottelling
    nottelling Member
    Dec 17, 2015
    made by kwnl031.
    Thanks for the link.
  • Mileszn
    Mileszn Member
    Feb 26, 2016
    Passed my exam today. I used vce from 20-01.2016 it is still valid and cbt nuggets. There are some new questions but study hard guys and you will pass
    Thanks for all the help and advice
    :D
  • everglide
    everglide Member
    Mar 24, 2016
    I passed my exam this week with a low 8xx score. I used this file for my study. In the "line of business" case there were 2 new questions about azure. One was a drag and drop question. And one was a question about how many azure instances you needed.
    These 2 questions i also had in my previous exam (which i failed)
  • ramzi
    ramzi Member
    Feb 11, 2016
    Gooooooooood job guys
  • BluAlien
    BluAlien Member
    Nov 5, 2015
    47
    If you look in the pdf file on page 129/130 question 109 you find exactly the same question but only 1 of the answers is different.
    A. Add at least 20 GB of storage to the IPAM server.
    B. Migrate Contoso.com to Fabrikam.com.
    C. Establish a forest trust between Contoso.com and Fabrikam.com.
    D. Upgrade SERVER3 to Windows Server 2012.
    The file says : Correct Answer: D
    IPAM can't work on multiple forest (the functionality is implemented only in Windows 2016), and also referring the question to the disk size can't be the right way because no answer match the corret size needed, the answer is B.
  • JRJakkals
    JRJakkals Member
    Jul 12, 2016
    Passed Exam 70-413 today - 15 August 2016, score 880. Only studied 70-413 February 2016 VCE. New Case study Woodgrove Bank, about 5 questions. And 1 new question in question set. Thanks very much to everybody that created and posted PDF, keep up the good work....
  • wakbrdr4life
    wakbrdr4life Member
    Jun 22, 2016
    30
    Passed yesterday by using the updated June VCE that can be found in these threads. I also supplemented with Ivan and Denise dumps, although I would say there isn't much from those that wasn't found in the June update. No new case study's for me. I had woodgrove and studied it in the VCE. I will say there were several new questions that I did not find in the dumps, but on this VCE alone, you should be able to pass. I finished mid 700s.
  • dany92
    dany92 Member
    Feb 21, 2016
    39
    Hi
    FYI : Passed with the scary min score required (700), :mad: I used 70-413-CertifyChat-vce-21-01-2016.pdf and its corresponding VCE
    Thanks to all contributors
    Good Luck
    Dany
  • andry79
    andry79 Member
    Jul 15, 2016
    Hi all,
    i did the exam and i passed. I studied on this dumps, ivan and death.
    The question about NPSPRX01 the correct last option is "Percentage of authentication request that NPS02 services if NPS03 is unavailable".
    Some questions are reworderd and i remember this question: "You deploy an Active Directory domain named contoso.com to the network
    The domain is configured as an Active Directory-integrated zone. All domain controllers run Windows Server 2012 and are DNS servers.
    You plan to deploy a child domain named operations.contoso.com.
    You need to recommend changes to the DNS infrastructure to ensure that users in the operations department can access the servers in the contoso.com domain.
    What should you include in the recommendation?" isn't more a child domain, but a tree forest.
    The question about the groups on IPAM was also reworderd with different options.
    I hope that this can help everybody to pass the exam.
  • BluAlien
    BluAlien Member
    Nov 5, 2015
    47
    Hi, did 70-413 exam today and pass with 8xx using only this dump.
    gargamel likes this.
  • IBS
    IBS Member
    Nov 2, 2016
    Passed !!!!
    Score 88X
    Thanks for all the help and advice.
  • goldteam
    goldteam Member
    Nov 7, 2016
    Hi all is this dump the most uptodate ?
    thanks for your reply
