70-414 December 15 VCE
Discussion in '70-414 Exam Files' started by trouble4k, Dec 15, 2015.
  1. trouble4k
    trouble4k Administrator
    Staff Member
    164
    70-414 by CertifyChat Team V 1.0
    Special thanks to:
    Th3Puck
    Ciscozel
    mecbeau
    Enya
    AikonFX
    All Members of our forum for helping with the proofing and providing questions
    This file has been tested by several members and they all scored between700 to 850.
    Not 100% valid but it is enough for you to practice and pass your exam.
    Includes:
    // 8 Case Studies
    Case Study 1 – Contoso Case A
    Case Study 2 - Adatum
    Case Study 3 - Proseware Inc
    Case Study 4 - Northwind Traders
    Case Study 5 - Contoso Case B
    Case Study 6 - Contoso Case C
    Case Study 7 - Contoso Case D
    Case Study 8 - Contoso Case E
    //Mix Questions
    120 Mix Questions
    //DD-Hotspots
    27 Drag & Drops and Hotspots
    //Yes / No
    26 Yes /No Questions
    VCE Link
    PDF Link
    If you think there are questions missing or you have spotted wrong answers please let us know.
    IMPORTANT INFORMATION:
    Please consider this Dump as a tool to help and improve lack areas.
    Never must be considered as a replacement for the experience and formal study.
    Microsoft always update their exams, the accuracy of the information provided here is not warranted
    For Internal use only.
  2. strider
    strider Member
    Nov 5, 2015
    33
    Awesome! Thank you all! and Goodluck!
  3. Th3Puck
    Th3Puck Member
    Dec 2, 2015
    Good luck to all!
    This dump has very detailed explanations for most of the questions so please use it as a tool to learn rather than simply memorizing the answers.
    This will be to your benefit :)
    If you get stuck or disagree, the forums here are a great place to find help!
  4. adooly
    adooly Member
    Dec 8, 2015
    Sehr gut, danke!
  5. techeart
    techeart Member
    Nov 6, 2015
    80
    Thanks to all those who have taken time to prepare this. Great work! Cheers!
  6. kramaijcovich
    kramaijcovich Member
    Nov 12, 2015
    Hi guys... great work!!! Thanks a lot!!
  7. tucar
    tucar Member
    Dec 8, 2015
    Great job, Thanx!
  8. zzmflz
    zzmflz Member
    Nov 5, 2015
    25
    thanks trouble4k
  9. dapenguin
    dapenguin Member
    Oct 30, 2015
    120
    Good luck to all!
    merci beacoup...
  • techeart
    techeart Member
    Nov 6, 2015
    80
    Did you use the 245Q in this VCE?
  • admin
    admin Administrator
    Staff Member Supplier Banned Contributor Member
    Oct 23, 2015
    20
    It contains all the questions of the premium 245 but we haven't used that as our base.
  • emiort
    emiort Member
    Dec 10, 2015
    29
    QUESTION 7
    You need to ensure that the developers can manage their own virtual machines.
    Solution: You perform the following actions:
    In Virtual Machine Manager, you create a new user role named DevUsers that uses the Application
    Administrator profile.
    You grant Checkpoint permissions to the DevUsers role.
    You distribute the Virtual Machine Manager Console URL to the developers.
    what about these question on 70-414 by CertifyChat Team V 1.0??? i Think the correct answer is "B"
  • techeart
    techeart Member
    Nov 6, 2015
    80
    QUESTION 7
    Yes, its B and its in the new VCE
  • emiort
    emiort Member
    Dec 10, 2015
    29
    i've found these error on the File Version: 1.0 pdf QUESTION 7 on page 78
    Where is the link of the new vce?
    Thank's a lot
    #14 emiort, Dec 17, 2015
  • techeart
    techeart Member
    Nov 6, 2015
    80
    Thank's a lot
    Same thread, first post by trouble4k!
  • ashfoo
    ashfoo Member
    Nov 23, 2015
    thx to those guys prepare the question, ;) thx u all
  • emiort
    emiort Member
    Dec 10, 2015
    29
    Special thanks to:
    Th3Puck
    Ciscozel
    mecbeau
    Enya
    AikonFX
    Difference beeween 70-414 CC Th3Puck and 70-414.PassLeader.Premium.Exam.245q-fixed and mecbeau
    In adatum.com, you install and configure a server that has the Active Directory Federation Services server
    role and all of the AD FS role services installed.
    You need to recommend which AD FS configurations must be performed m adatum.com to meet
    the security requirements.
    Which configurations should you recommend before creating a trust policy?
    A. Export the server authentication certificate and provide the certificate to Trey Research. Import the
    token-signing certificate from Trey Research.
    B. Export the server authentication certificate and provide the certificate to Trey Research. Import the
    server authentication certificate from Trey Research.
    C. Export the token-signing certificate and provide the certificate to Trey Research. Import the server
    D. Export the token-signing certificate and provide the certificate to Trey Research. Import the tokensigning
    Correct Answer: C (FOR TH3PUCK) B (FOR MECBEAU)
    You need to enable virtual machine network health detection on all supported clusters.
    A. On the virtual machine settings page for Cluster4, select the Protect network checkbox for each virtual
    machine on the cluster.
    B. On the virtual machine settings page for Cluster1, select the Protect network checkbox for each virtual
    C. On each guest virtual machine in Cluster4, configure protected access for the network interface
    card.
    D. On each guest virtual machine in Cluster3, configure protected access for the network interface
    card.
    E. On the virtual machine settings page for Cluster3, select the Protect network checkbox for each virtual
    F. On each guest virtual machine in Cluster1, configure protected access for the network interface
    card.
    Correct Answer: B (FOR TH3PUCK) E (FOR MECBEAU)
    This question consists of two statements: One is named Assertion and the other is named Reason. Both of
    these statements may be true; both may be false; or one may be true, while the other may be false.
    To answer this question, you must first evaluate whether each statement is true on its own. If both
    statements are true, then you must evaluate whether the Reason (the second statement) correctly explains
    the Assertion (the first statement). You will then select the answer from the list of answer choices that
    matches your evaluation of the two statements.
    Assertion:
    You can manage VMware ESX hosts and virtual machines by using a System Center Virtual Machine
    Manager (SCVMM) server.
    Reason:
    SCVMM automatically imports ESX hosts and virtual machines when you add the corresponding VMware
    vCenter to the SCVMM server.
    Evaluate the Assertion and Reason statements and choose the correct answer option.
    A. Both the Assertion and Reason are true, and the Reason is the correct explanation for the Assertion.
    B. Both the Assertion and Reason are true, but the Reason is not the correct explanation for the
    Assertion.
    C. The Assertion is true, but the Reason is false.
    D. The Assertion is false, but the Reason is true.
    E. Both the Assertion and the Reason are false.
    Correct Answer: C (FOR TH3PUCK) A (FOR MECBEAU)
    Your network contains an Active Directory domain named contoso.com.
    You currently have an intranet web site that is hosted by two Web servers named Web1 and Web2.
    Web1 and Web2 run Windows Server 2012.
    Users use the name intranet.contoso.com to request the web site and use DNS round robin.
    You plan to implement the Network Load Balancing (NLB) feature on Web1 and Web2.
    You need to recommend changes to the DNS records for the planned implementation.
    What should you recommend?
    A. Create one alias (CNAME) record named Intranet. Map the CNAME record to Intranet.
    B. Delete both host (A) records named Intranet. Create a pointer (PTR) record for each Web server.
    C. Create a new host (A) record named Intranet. Remove both host (A) records for Web1 and Web2.
    D. Delete one of the host (A) records named Intranet. Modify the remaining host (A) record named
    Intranet.
    Correct Answer: A (FOR TH3PUCK) C (FOR MECBEAU)
    Your company has an enterprise root certification authority (CA) named CA1.
    You plan to deploy Active Directory Federation Services (AD FS) to a server named Serverl.
    The company purchases a Microsoft Office 365 subscription.
    You plan register the company's SMTP domain for Office 365 and to configure single sign-on for all users
    You need to identify which certificate or certificates are required for the planned deployment.
    Which certificate or certificates should you identify?
    A. a server authentication certificate that is issued by a trusted third-party and that contains the subject
    name serverl.contoso.com
    B. a server authentication certificate that is issued by CA1 and that contains the subject name Server1
    C. a server authentication certificate that is issued by a trusted third-party root CA and that contains the
    D. a server authentication certificate that is issued by CA1 and that contains the subject name
    serverl.contoso.com
    E. self-signed server authentication certificates for serverl.contoso.com
    Correct Answer: A (FOR TH3PUCK) E (FOR MECBEAU)​
    #17 emiort, Dec 18, 2015
  • emiort
    emiort Member
    Dec 10, 2015
    29
    QUESTION 6
    The corporate security policy states that when new user accounts, computer accounts, and contacts are
    added to an organizational unit (OU) named Secure, the addition must be audited.
    You need to recommend an auditing solution to meet the security policy.
    What should you include in the recommendation? (Each answer presents part of the solution. Choose all
    that apply.)
    A. From the Default Domain Controllers Policy, enable the Audit directory services setting.
    B. Create a new Group Policy object (GPO) that is linked to the Secure OU, and then modify the Audit
    C. From the Secure OU, modify the Auditing settings.
    D. From the Default Domain Controllers Policy, enable the Audit object access setting.
    E. From the Secure OU, modify the Permissions settings.
    F. Create a new Group Policy object (GPO) that is linked to the Secure OU, and then modify the Audit
    Correct Answer: AC OR AB
    QUESTION 7
    Your company has a main office and a branch office.
    Each office contains several hundred computers that run Windows 2012.
    You plan to deploy two Windows Server Update Services (WSUS) servers.
    The WSUS servers will be configured as shown in the following table.
    You need to implement the WSUS infrastructure to meet the following requirements:
    - All updates must be approved from a server in the main office.
    - All client computers must connect to a WSUS server in their local office.
    What should you do? (Each correct answer presents part of the solution. Choose all that apply.)
    [TABLE="class: cms_table_MsoTableGrid"]
    [TR]
    [TD]SERVER NAME[/TD]
    [TD]OFFICE[/TD]
    [/TR]
    [TR]
    [TD]SERVER1[/TD]
    [TD]MAIN[/TD]
    [/TR]
    [TR]
    [TD]SERVAR2[/TD]
    [TD]BRANCH[/TD]
    [/TR]
    [/TABLE]
    A. Deploy a Group Policy object (GPO) that has the update location set to Server1.
    B. On Server2, configure WSUS in Replica mode.
    C. On Server1, configure WSUS in Replica mode.
    D. On Server2, configure WSUS in Autonomous mode.
    E. Deploy a Group Policy object (GPO) that has the update location set to Server2.
    F. On Server1, configure WSUS in Autonomous mode.
    Correct Answer: ABE OR ABEF
    QUESTION 8
    Your network contains an Active Directory domain.
    The domain contains a site named Site1.
    All of the client computers in Site1 use static IPv4 addresses on a single subnet.
    Site1 contains a Storage Area Network (SAN) device and two servers named Server1 and Server2 that run
    You plan to implement a DHCP infrastructure that will contain Server1 and Server2.
    The infrastructure will contain several IP address reservations.
    You need to recommend a solution for the DHCP infrastructure to ensure that clients can receive IP
    addresses from a DHCP server if either Server1 or Server2 fails.
    What should you recommend? (Each correct answer is a complete solution. Choose all that apply.)
    A. Configure all of the client computers to use IPv6 addresses, and then configure Server1 and Server2 to
    run DHCP in stateless mode.
    B. Configure Server1 and Server2 as members of a failover cluster, and then configure DHCP as a
    clustered resource.
    C. Configure a DHCP failover relationship that contains Server1 and Server2.
    D. Create a scope for each server, and then configure each scope to contain half of the IP addresses.
    Correct Answer: BC OR BCD
    QUESTION 9
    You are an Active Directory administrator for Contoso, Ltd.
    You have a properly configured certification authority (CA) in the contoso.com Active Directory Domain
    Services (AD DS) domain.
    Contoso employees authenticate to the VPN by using a user certificate issued by the CA.
    Contoso acquires a company named Litware, Inc., and establishes a forest trust between contoso.com and
    litwareinc.com.
    No CA currently exists in the litwareinc.com AD DS domain. Litware employees do not have user accounts
    in contoso.com and will continue to use their litwareinc.com user accounts.
    Litware employees must be able to access Contoso's VPN and must authenticate by using a user
    certificate that is issued by Contoso's CA.
    You need to configure cross-forest certificate enrollment for Litware users.
    Which two actions should you perform? Each correct answer presents part of the solution.
    A. Grant the litwareinc.com AD DS Domain Computers group permissions to enroll for the VPN template
    on the Contoso CA.
    B. Copy the VPN certificate template from contoso.com to litwareinc.com.
    C. Add Contoso's root CA certificate as a trusted root certificate to the Trusted Root Certification Authority
    in litware.com.
    D. Configure clients in litwareinc.com to use a Certificate Policy server URI that contains the location of
    Contoso's CA.
    Correct Answer: AC OR CD
    QUESTION 10
    A company has data centers in Seattle and New York.
    A high-speed link connects the data centers. Each data center runs a virtualization infrastructure that uses
    Hyper-V Server 2012 and Hyper-V Server 2012 R2.
    Administrative users from the Seattle and New York offices are members of Active Directory Domain
    Services groups named SeattleAdmins and NewYorkAdmins, respectively.
    You deploy one System Center Virtual Machine Manager (SCVMM) in the Seattle data center.
    You create two private clouds named SeattleCloud and NewYorkCloud in the Seattle and New York data
    centers, respectively.
    You have the following requirements:
    Administrators from each data center must be able to manage the virtual
    machines and services from their location by using a web portal.
    Administrators must not apply new resource quotas or change resource quotas.
    You must manage public clouds by using the existing SCVMM server.
    You must use the minimum permissions required to perform the administrative
    tasks.
    You need to configure the environment.
    A. For both the Seattle and New York admin groups, create a User Role and assign it to the Application
    Add the Seattle and New York private clouds to the corresponding User Role.
    B. For both the Seattle and New York admin groups, create a User Role and assign it to the Delegated
    C. For both the Seattle and New York admin groups, create a User Role and assign it to the Tennant
    D. Add both SeattleAdmins and NewYorkAdmins to the Local Administrators group of each Hyper-V host
    in Seattle and New York, respectively.
    Correct Answer: A OR B
    #18 emiort, Dec 18, 2015
  • jansmit
    jansmit Member
    Nov 10, 2015
    25
    Q106 is wrong. Storage Spaces do not support iSCSI and Fibre Channel controllers Storage pool 3 has iscsi discs so anwer is A and D
  • Hounel
    Hounel Member
    Dec 13, 2015
    Greeting,
    In the VCE, the answer for the study case Contoso Ltd case A, Q13
    the correct answer is A ""Install windows storage server 2012 R2 workgroup on storage1 and storage2. Use storage1 and storage 2 as scale-out file servers"
    but in the PDF file(the fixed one), it is D "Install windows storage server 2012 R2 standard on storage1 and storage2. Use storage1 and storage 2 as scale-out file servers"
    what is the real answer?
