70-414 December 15 VCE
Discussion in '70-414 Exam Files' started by trouble4k, Dec 15, 2015.
  1. Dms2701
    Dms2701 Member
    Feb 21, 2016
    Barely passed with a 727...can finally chill on these certs till the 2016 stuff comes out. Thanks to everyone in this forum, especially puck and cupertino, for giving better explanations of the technology than M$ does.
    No *new* questions from what I could see, but they have definitely started to re-order questions/answers. I will say that the main reason I passed was probably more from reading the explanations posted in the PDF and these forums than anything else, as that gave me the tools to logic my way through the altered questions. Thanks again to everyone - gonna go have a beer now!
    What resources did you use? ThePuck is valid with cupertino correction? Any advices? Thanks and grats!
  • revanger81
    revanger81 Member
    Nov 5, 2015
    97
    Congrats!
    I will take 414 on about 10-15 days
  • revanger81
    revanger81 Member
    Nov 5, 2015
    97
    I learn by ThePuck with Cupertinos corrections and i planning to take test on 15-20 april.
    Does it safe?
  • Yuriy.Yulian
    Yuriy.Yulian Member
    Nov 4, 2015
    Could someone update the VCE and create a new one with corrections and new questions?
    Any Op's around to do that or share the password for the VCE?
  • revanger81
    revanger81 Member
    Nov 5, 2015
    97
    I learning with ThePucks VCE, and in simulator i answer with Cupertinos corrections.
    Results is 93%
    Try to do that.
  • Cameron
    Cameron Member
    Feb 22, 2016
    I corrected the vce file a while back,
  • stickerbush1970
    Jan 13, 2016
    122
    where do we find the "ThePucks VCE, and in simulator i answer with Cupertinos corrections."
  • revanger81
    revanger81 Member
    Nov 5, 2015
    97
  • jctech
    jctech Member
    Does this VCE contain the ThePhucks vce´s and cupertinos corrections? is that it?
  • revanger81
    revanger81 Member
    Nov 5, 2015
    97
    Yes many questions are corrected, but some not
    like this
  • barto90
    barto90 Member
    Dec 18, 2015
    Is this a valid dump?
  • Ergis
    Ergis Member
    Dec 14, 2015
    33
    Ill take the exam in 26 april, i have learned thePuck and the cupernios correction ill make u know for the results...thank you
  • james1234
    james1234 Member
    Apr 22, 2016
    man i wish i had found this site before failing twice with 650 625 using examcollection premium. i had a feeling there were a lot of incorrect answers in the dump i was using. hopefully with these corrections and new dump it will be 3rd times a charm.
    i have valid premium dumps for 409,410,411 and 413 if anyone wants them let me know where to upload them
  • orangejulius
    orangejulius Member
    Apr 20, 2016
    Yes, it looks like Examcollection's closing on their forums caused an exodus away from the site. When I passed 410/411/412, I think the best part of that site was discussing which answers were incorrect so we could figure out the answers without needing to simply braindump.
    As much as studying and CBT helps with broad knowledge, it's impossible to know what MS actually wants us to remember or focus on. I found that discussing the finer points of MS server based on the questions helps considerably; I haven't scored under 900 with any tests since the 2003 MCSE days.
    I'm just glad I found this place. Hopefully I can be of help too. I'm on my way to completing 413 and 414 over the next few months, with Server 2016 exams by the end of the year. Start on them early and they are easier!
  • Meena
    Meena Member
    Mar 19, 2016
    37
    Is this a correction of Th3Puck and cupertinosucks corrections?? r u sure of it i mean?
    Cuz i am goning to take 414 soon and need to study the right VCE.
  • stickerbush1970
    Jan 13, 2016
    122
    The problem with starting on the exam early is they expire after 3 years, meaning you will have to take the upgrade test to keep you cert valid. If you let your cert expire, it is gone, you will not be able to take the upgrade test and you will have too re-certify with another route.
  • ensingg
    ensingg Member
    Apr 29, 2016
    I downloaded the 70-414 Correction.vce. Is this the Puck dump corrected with the 414 corrections?
    Is there a pdf of this complete set somewhere? I like to have it printed on paper to learn. Before using vce to test myself.
  • anteste
    anteste Member
    Apr 25, 2016
    Thanks everyone! The test was 50 questions with 2 and half hours to complete. I had 33 individual questions and the other 17 were from a mixture of about 5 case studies, 3-4 questions each.
    I made a doc file with about 20+ corrections and some links to threads here for some new questions and answer sets. Most of the questions have referencing links or explanations. There are a couple new questions/answers that I have not validated myself yet, but they are noted as so. Hope it helps you guys!
    Link to doc
    Some other links to questions that I answered on this forum.
    Many thanks regarding the amount of work you put into this, i will have the exam soon and this is invaluable.
    A note: on the first question in your corrected doc file i think it should be Windows Server Storage Standard, because Workstation is limited to six disks and 32 GB of RAM; our servers have 10 disks and 48 GB of RAM.
  • j0ngmoi
    j0ngmoi Member
    Apr 27, 2016
    many thank you brother
  • Meena
    Meena Member
    Mar 19, 2016
    37
    Did u pass??
    If yes what dupm u used?
