70-414 Jedi-September-21
Discussion in '70-414 Exam Files' started by metro, Sep 21, 2016.
  1. Kerberos
    Kerberos Member
    Nov 18, 2016
    Guys need some need some urgent help.
    A) have you guys prepared with reference from 414 Dump by J3di! Posted Here on Certify Chat Under Exam Files Section
    or
    B)By
    from "
    here are the prem and j3di v18 files, study hard also learn the case and questions.
    I've pasted with j3di and also some knowledge because some answers were not in the dump!"
    The Reason both Dumps says by j3di but many answers to same questions are not same .............
    so Any idea Which dump I should refer to.......
  2. Anthony McMillon
    Oct 13, 2016
    If you're using A+ VCE player in Bluestacks, it would be tedious; but, you can take a screenshot of each question, save each image, then add them to a Word document, which may be converted to a PDF.
    ddk003 likes this.
  3. Muhammad Arshad
    Jan 30, 2017
    New 70-414 Jedi VCE.
    Minor Changes. Feel free to Edit to keep it updated.
    Includes:
    // 8 Case Studies
    Case Study 1 – Contoso Case A
    Case Study 2 - Adatum
    Case Study 3 - Proseware Inc
    Case Study 4 - Northwind Traders
    Case Study 5 - Contoso Case B
    Case Study 6 - Contoso Case C
    Case Study 7 - Contoso Case D
    Case Study 8 - Contoso Case E
    //Mix Questions
    If you think there are questions missing or you have spotted wrong answers please let us know.
    IMPORTANT INFORMATION:
    Please consider this Dump as a tool to help and improve lack areas.
    Never must be considered as a replacement for the experience and formal study.
    Microsoft always update their exams, the accuracy of the information provided here is not warranted
    For Internal use only.
    can i get pdf of 70-413 as i m going to take exam in a few days may be after two weeks. would appriciate your help
  • vangelis
    vangelis Member
    Jan 21, 2017
    Thank you so much.
    I passed this exam with 836 score .
    Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Muhammad Arshad likes this.
  • Muhammad Arshad
    Jan 30, 2017
    MANY CONGRATULATIONS DEAR..!! :)
    CAN I GET THE MATERIAL. I AM GOING TO TAKE EXAM IN NEXT WEEK. IF YOU COULD SHARE DUMPS ON THIS ID
    RELAY WOULD APPRECIATE YOUR HELP
    Regards,
    Arshad
  • osayawe ogbebor
    Feb 14, 2017
    Includes:
    // 8 Case Studies
    //Mix Questions
    How do i download this file?
  • clickme78
    clickme78 Member
    Apr 28, 2016
    hi, please i require the premium exam file 412,413,414, preferably in PDF. thanks :)
    email:
  • babyxdeja
    babyxdeja Member
    Jan 18, 2016
    Thoughts on below 2 questions, need updated?
    The solution must support the following requirements.
    • Perform failover replication from Seattle to New York.
    • Perform scheduled replication between as many location as possible.
    • In case of a disaster, a fast failover should be possible to the replicated servers with minimal changes required to the existing infrastructure.
    Which two actions should you perform? Each correct answer presents a part of the solution.
    Correct answer should be
    Use Hyper-V Replica unplanned failovers
    Configure the Seattle Hyper-V server as the primary replica server and the New York Hyper-V server as the secondary replica Server.
    You need to deploy the dedicated storage servers to support the new web application servers.
    Correct answer:
    Install windows storage server 2012 R2 standard on STORAGE1 and STORAGE2. Use STORAGE1 and STORAGE2 as scale-out file server.
  • ciscozel
    ciscozel Supplier
    Supplier Member
    74
    the is currently a lot of rewording on the questions study hard if you still doing this
