70-414 premium Dump
jhonBB
Hi
i wanna know whether anyone has new premium dump?
i have exam 10days later
plz share me
its strictly necessary for me....
TSpears
Looking for 70-246 premium dump anyone please? Mission critical at this stage at work here
yawyaw
Please, I need your help sending me the latest dumps, please in PDF
SashaFeld
The new 2018 version (Sep/2018 Updated) 70-414 dumps now are available, here are part of 70-414 exam questions (FYI):
Your network contains an Active Directory domain named contoso.com. The domain contains several domain controllers. The domain controllers run either Windows Server 2012 or Windows Server 2008 R2. The domain functional level is Windows Server 2008 R2. The forest functional level is Windows Server 2008. The corporate compliance policy states that all items deleted from Active Directory must be recoverable from a Recycle Bin. You need to recommend changes to the current environment to meet the compliance policy. Which changes should you recommend? (Each correct answer presents part of the solution. Choose all that apply.)
A. Run the Set-ADForestMode cmdlet.
B. Run the New-ADObject cmdlet.
C. Run the Set-ADObject cmdlet.
D. Run the Set-ADDomainMode cmdlet.
E. Run the Enable-ADOptionalFeature cmdlet.
- A: You can enable Active Directory Recycle Bin only if the forest functional level of your environment is set to Windows Server 2008 R2. The Set-ADForestMode cmdlet sets the Forest mode for an Active Directory forest. You specify the forest mode by setting the ForestMode parameter. Here we should set it to Windows 2008 R2 Forest.
- E: Enabling Active Directory Recycle Bin. After the forest functional level of your environment is set to Windows Server 2008 R2, you can enable Active Directory Recycle Bin by using the following methods: / Enable-ADOptionalFeature Active Directory module cmdlet. (This is the recommended method.)
You need to automatically restart the appropriate web service on DETCRL01 and CHICRL01 if the web service is stopped.
Solution: You create a Basic service monitor in SCOM and configure it to monitor the World Wide Web publishing service.
This can be done with a recovery task.
You plan to allow users to run internal applications from outside the company's network. You have a Windows Server 2012 R2 that has the Active Directory Federation Services (AD FS) role installed. You must secure on-premises resources by using multi-factor authentication (MFA). You need to design a solution to enforce different access levels for users with personal Windows 8.1 or iOS 8 devices.
Solution: You install a local instance of MFA Server and connect it to your Microsoft Azure MFA provider. Then, you use the Workplace Join process to configure access for personal devices to the on-premises resources.
You manage a Hyper-V 2012 cluster by using System Center Virtual Machine Manager 2012 SP1. You need to ensure high availability for business-critical virtual machines (VMs) that host business-critical SQL Server databases.
Solution: You set the memory-weight threshold value to High for each business-critical VM.
You administer a group of servers that run Windows Server 2012 R2. You must install all updates. You must report on compliance with the update policy on a monthly basis. You need to configure updates and compliance reporting for new devices. What should you do?
A. Deploy the Microsoft Baseline Security Analyzer.
Scan the servers and specify the /apply switch.
B. In Configuration Manager, deploy a new Desired Configuration Management baseline that includes all required updates.
C. Configure a new group policy to install updates monthly.
Deploy the group policy to all servers.
D. In Operations Manager, create an override that enables the software updates management pack.
Apply the new override to the servers.
Solution: You configure preferred and possible owners for each business-critical VM.
An organization uses an Active Directory Rights Management Services (AD RMS) cluster named RMS1 to protect content for a project. You uninstall AD RMS when the project is complete. You need to ensure that the protected content is still available after AD RMS is uninstalled.
Solution: You add the backup service account to the SuperUsers group and back up the protected content. Then, you restore the content to a file server and apply the required NTFS permissions to the files.
You perform a Server Core Installation of Windows Server 2012 R2 on a server named Server1. You need to add a graphical user interface (GUI) to Serverl. Which tool should you use?
A. the ocsetup.exe command
B. the Install-Module cmdlet
C. the setup.cmd command
D. the dism.exe command
Your network contains one Active Directory domain named contoso.com. The domain contains 10 domain controllers that run Windows Server 2012 R2. You need to prevent several members of the Domain Admins group from logging on to the domain controllers. Which two objects should you create and configure? (Each correct answer presents part of the solution. Choose two.)
A. a user certificate
B. a Group Policy object (GPO) linked to the domain
C. a central access policy
D. an authentication policy
E. an authentication policy silo
You network contains an Active Directory domain named adatum.com. The network has an Active Directory Certificate Services (AD CS) infrastructure. You need to issue a certificate to users to meet the following requirements:
- Ensure that the users can encrypt files by using Encrypting File System (EFS).
- Ensure that the default key length is 4096 bits for all users.
- Ensure that the domain administrator can recover EFS encrypted files.
What should you do first?
A. Create a copy of the Key Recovery Agent certificate template, and then modify the permissions of the copy.
B. From the properties of the Basic EFS template, assign the Full Control permission to the Domain Admins group.
C. From the properties of the EFS Recovery Agent certificate template, assign the Allow-Enroll permission to the Domain Admins group.
D. Create a copy of the basic EFS certificate template, and then modify the key length of the copy.
Your network contains two servers named Hyper1 and Hyper2 that run Windows Server 2012. Hyper1 and Hyper2 have the Hyper-V server role installed and are members of a failover cluster named Cluster1. The network contains a Fibre Channel Storage Area Network (SAN) named SAN1. SAN1 contains a LUN named LUN1. You plan to host a new virtual machine named VM1 on Cluster1. You need to ensure that VM1 can store data directly on LUN1. What three actions should you perform?
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-414-dumps-111.jpg
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-414-dumps-112.jpg
Get the newest forbiden 70-414 VCE dumps here: https://www.forbiden.com/70-414.html
Download more NEW forbiden 70-414 PDF dumps from Google Drive here:
https://drive.google.com/open?id=0B-ob6L_QjGLpfmxzR3ZsVU52M0wxX2d6OWtDWjJSZVE5Tm81bEpDak5MQWlOTHBDdERCWXM
Read the newest forbiden 70-414 exam questions from this Blog:
http://www.microsoftbraindumps.com/?s=70-414
Erika Jacobs
Pass Your Microsoft 70-414 Certification Exam Fast! Visit This Link And Get Actual 70-414 Exam Questions: https://www.theexamcerts.com/Microsoft/70-414-pdf-exam-dumps - TheExamCerts provide actual and updated 70-414 Implementing an Advanced Server Infrastructure exam material with 24/7 customer support. You can easily pass your Microsoft 70-414 Exam in first attempt otherwise get your money back easily. TheExamCerts is providing the services of Microsoft 70-414 exam study guides for last few years and gathered the confidence of 30,000+ customers. Study guides are detailed and their lengthy nature makes the students dull. You must have a complete knowledge of syllabus before preparing it. So you can easily prepare it. TheExamCerts recommend you to try the free demo of the Microsoft 70-414 exam product before purchase. Get 20% discount offer limited time. Click this link and get actual and updated Microsoft 70-414 exam questions: https://www.theexamcerts.com/Microsoft/70-414-pdf-exam-dumps
