70-533 Updated Exam
spindrift
when were I click on the download from zippyshare it redirects to a malware page from the two links posted. Maybe I'm just doing wrong?
sheraz9212
Managed to pass my exam today with 811 score. The exam was not difficult with 20% of new questions that can be answered correctly if you have good experience, clear concepts and have studied well. I used forbiden, ExamCollections Premium and Jonathan's VCEs. 80 % of questions were from these dumps.
CrenimNCC
The forbiden that has been posted around here is no longer valid. If you are finding lots of questions about Azure classic and not ARM, you're looking at an invalid dump.
Less than 10% of the questions from the forbiden are on the test. Heavy focus on PowerShell, PAAS apps. Know the CLI, powershell, JSON if you want any hope of passing.
Guttikonda
The new 70-533 dumps (Mar/2018 Updated) now are available, here are part of 70-533 exam questions (FYI):
NEW QUESTION 279
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet the stated goals. Some questions sets might have more than one correct solution, while others might not have a correct solution. After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
A company plans to use Operations Management Suite (OMS) to track changes within virtual machines (VMs). The company required that data collection occur at least every 15 minutes. You need to recommend a solution to monitor VMs which ensures that data collection occurs at least every 15 minutes.
Solution: Monitors daemons on Linux VMs.
NEW QUESTION 280
Solution: Monitor files on Linux VMs.
NEW QUESTION 281
A company has an Azure subscription and plans to deploy virtual machines (VMs). The company needs to use an Azure Active Directory Domain Services (Azure AD DS) domain with the VMs. You need to ensure that you can join the VMs to the Azure AD DS domain. What should you do?
A. Place the VMs in the same resource group as a domain controller.
B. Place the VMs on the same virtual network as the Azure AD DS domain.
C. Create an AD DS domain controller on a VM.
D. Create a custom domain in the Azure subscription.
NEW QUESTION 282
You administer an Azure subscription for your company. You plan to deploy a virtual machine (VM) to Azure. The VM environment must provide 99.95% uptime. A single switch outage must not cause the VM environment to be unavailable VM must be offline due to installation of an update that requires a reboot. You need to configure the environment.
Solution: Create two availability sets. Place a VM in each availability set.
NEW QUESTION 283
Solution: Create an availability set and deploy two VMs in it. Ensure that the VMs are in different update and fault domains.
NEW QUESTION 284
Solution: Create an availability set with two VMs. Place the VMs in the same fault domain.
NEW QUESTION 285
Solution: Monitor registry keys on Windows VMs.
NEW QUESTION 286
You plan to implement shared storage policies. You need to apply a policy to the appropriate resource. What should you use?
A. Queues
B. Recovery Services Vault
C. Premium Disk Storage
D. Resource Group
NEW QUESTION 287
A company uses Azure to host virtual machines (VMs) and web apps. You have an app service named App1 that uses the Basic app service tier. You need to ensure that diagnostic data for App1 is permanently stored.
Solution: You specify a storage account in the ServiceConfiguration.cscfg file.
NEW QUESTION 288
Solution: You specify a storage account in the Diagnostics.xml file.
NEW QUESTION 289
A company has a hybrid environment. The public IP address of the on-premises environment is 40.84.199.233. The company deploys virtual machines (VMs) to Azure on different subnets. You need to ensure that the Azure VMs can communicate with the on-premises environment. What should you create?
A. An Internet rule for each subnet.
B. A user defined route to 255.255.255.0/0 with a VPN gateway.
C. A user defined route to 0.0.0.0/30 with a VPN gateway.
D. A Border Gateway Protocol (BGP) route by using ExpressRoute.
NEW QUESTION 290
You plan to use Azure Monitor with AutoScale Services. You create a URI to be used with the monitoring service. You need to configure an alert that specifies the URI. Which Azure Command Line Interface (CLI) command or Azure PowerShell cmdlet should you run?
A. New-AzureRmAlertRuleEmail
B. azure insights logprofile add
C. azure insights alerts actions webhook create
D. azure insights alerts rule list
NEW QUESTION 291
Get the newest forbiden 70-533 VCE dumps here:
bit.ly/2018-new-70-533-dumps-vce
Download more NEW forbiden 70-533 PDF dumps from Google Drive here:
j.mp/2018-new-70-533-dumps-pdf
Read the newest forbiden 70-533 exam questions from this Blog:
bit.ly/forbiden-latest-70-533-dumps
(p.s. Copy the upper red short link and open it in your browser.)
AVIKBose
NEW QUESTION 279
NEW QUESTION 280
NEW QUESTION 281
NEW QUESTION 282
NEW QUESTION 283
NEW QUESTION 284
NEW QUESTION 285
NEW QUESTION 286
A. Queues
D. Resource Group
NEW QUESTION 287
NEW QUESTION 288
NEW QUESTION 289
NEW QUESTION 290
NEW QUESTION 291
Thanks for sharing!!!
Would you like to upload that forbiden 70-533 dumps in VCE file???
jhonaddison
Enjoy your success in Microsoft Certification Exams with our Implementing Microsoft Azure Infrastructure Solutions Exam Dumps!!! 70-533 Dumps Questions Answers with Implementing Microsoft Azure Infrastructure Solutions Practice Test software is a success leading way towards your Microsoft 70-533 Exam. All the 70-533 Exam VCE are tested and approved by professional experts to assure 100% success in Microsoft MCSA-Cloud Platform Microsoft Certified Solutions Associate exam.
LORENA JIMENEZ
Passed the 70-533 exam on 1/June/2018 with 8xx! Thanks forbiden, I got almost all questions from forbiden 70-533 dumps!!! The following are the details of my test FYI: I had 42 questions in total, including 11 YES/NO questions, I got many questions on Powershell Command and JSON, 1 drag and drop question on Powershell and few MCQs on Kubernetes Ouput, also, some new questions related to Data Lake and Security Token Keys, almost all new questions have been added into the latest forbiden 70-533 braindumps now, valid enough for passing.
P.S. The 70-533 exam have changed since 29/Mar/2018, many new exam objectives appeared, I suggest you do not waste time on MeasureUp or other study materials, many new exam objectives are NOT available in them. Highly Recommend forbiden, Good Luck, All!!!
ggangoe
PLEASE STOP ADVERTISING!!! THIS IS NOT A FORUM TO SELL YOUR STUFF.
ggangoe
Guttikonda
The new 70-533 dumps (July/2018 Updated) now are available, here are part of 70-533 exam questions (FYI):
NEW QUESTION 324
You plan to create a Content Delivery Network (CDN) in Azure that meets the following requirements:
- Ensure that content can be preloaded into CDN endpoints.
- Accept client requests that use HTTP or HTTPS.
- Accept content from customized origin ports.
- Minimize costs per gigabyte (GB) delivered.
You need to create the CDN profile and endpoint.
Solution: You create a CDN profile by using the Azure CDN Standard from Akamai SKU. You configure the profile to use a storage account endpoint.
NEW QUESTION 325
You plan to enable access to a blob storage account for external clients. The access method must include an expiration time and clients should not be able to access other storage services. You need to provide access to the storage account.
Solution: You create a storage account resource type configured as a shared access signature.
NEW QUESTION 326
A company plans to deploy Linux virtual machines (VM) in Azure. The VM configuration and applications must be managed automatically. You need to propose a solution to configure and manage the VMs. What should you recommend?
A. Resource Manager Templates
B. Azure AD Connect
C. Chef
D. Azure Command-Line Interface (CLI)
NEW QUESTION 327
A company plans to use Operations Management Suite (OMS) to track changes within virtual machines (VMs). The company requires that data collection occur at least every 15 minutes. You need to recommend a solution to monitor VMs which ensures that data collection occurs at least every 15 minutes.
Solution: Monitor files on Windows VMs.
NEW QUESTION 328
A company has an Azure subscription and hosts a virtual network in the cloud. The company uses authenticated web proxies on their local network. You need to grant two specific users on the local network access to the virtual network. Which three steps must you perform on the two local machines? (Each correct answer presents part of the solution. Choose three.)
A. Upload an X.509 certificate to the virtual network.
B. Configure multifactor access control on the virtual network.
C. Enable Direct Access on the local devices.
D. Create an exception to the authentication proxy.
E. Download and install the VPN client package from the Azure Management Portal.
F. Install an X.509 certificate on the local devices.
Answer: DEF
NEW QUESTION 329
You are designing a web app deployment in Azure. You need to ensure that inbound requests to the web app are routed based on the endpoint that has the lowest latency. What should you use?
A. Azure Traffic Manager
B. Azure Fabric Controller
C. Azure Load Balancer
D. Azure health probes
NEW QUESTION 330
You are a developer for a company that produces bug tracking software. The software runs on customer provisioned virtual machines (VMs) running in Azure, including deployments within private Azure Virtual Networks. The software has the following requirements for the runtime environment, if any of these components are missing or not configured correctly, the application will not function correctly.
- User groups named bug_users and bug_admins
- a log file location at c:\bug\logs
- a registry key that contains the license keys
- Visual C++ runtime components
- a Windows service named BugCleanup
You need to provide a mechanism to distribute the application to customers that ensures that the application always functions correctly. What should you do?
A. Provide a VM image to customers.
B. Provide an Azure Resource Manager template that contains logic to ensure application requirements are met.
C. Convert the application to a ClickOnce application and distribute the URL of the application to customers.
D. Provide an Azure Resource Manager template to customers with an Azure PowerShell DSC script that installs the application and configures the VM.
NEW QUESTION 331
A. Puppet
B. Resource Manager Templates
C. Azure PowerShell
D. Azure AD Connect
NEW QUESTION 332
Solution: You create a new Azure Key Vault.
NEW QUESTION 333
Solution: You regenerate the storage account keys.
NEW QUESTION 334
A. a Border Gateway Protocol (BGP) route by using ExpressRoute
B. an Internet rule for each subnet
C. a local vNet rule for each subnet
D. a user defined route to 40.84.199.233/0
NEW QUESTION 335
NEW QUESTION 347
You manage a Kubernetes cluster in Azure Container Service. You run the kubectl get pods Windows PowerShell command and receive the following output.
http://www.microsoftbraindumps.com/wp-content/uploads/2018/07/forbiden-70-533-dumps-3471.jpg
You need to use Azure CLI to increase the number of virtual machines (VMs) available in the azure-vm-back deployment to five. How should you complete the command? (To answer, select the appropriate options in the answer area.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/07/forbiden-70-533-dumps-3472.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/07/forbiden-70-533-dumps-3473.png
NEW QUESTION 348
A company plans to use Azure Site Recovery as a disaster recovery (DR) solution. You identify the following requirements for groups:
- Senior administrators must be able to enable and manage DR for applications.
- Junior administrators must be able to execute failover operations, but not manage DR.
- The CIO and IT directors must be able to view settings but not make any changes.
You need to configure the permission levels. Which permission level should you assign for each group? (To answer, drag the appropriate permission levels to the correct groups. Each permission level may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/07/forbiden-70-533-dumps-3481.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/07/forbiden-70-533-dumps-3482.png
NEW QUESTION 349
You are an administrator of an Azure subscription for your company. Management asks you to assign the user [email protected] to a role that can create and manage virtual machines (VMs). The user must not be able to manage storage or virtual networks for the MarketingGroupResources resource group. User1 must have no other permissions. You need to implement the requirements. How should you complete the Azure PowerShell command? (To answer, select the appropriate Azure PowerShell segments in the answer area.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/07/forbiden-70-533-dumps-3491.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/07/forbiden-70-533-dumps-3492.png
NEW QUESTION 350
You are designing the deployment of Azure Site Recovery with Hyper-V Replica. The environment does not have System Center Virtual Machine Manager (VMM) deployed. You need to instruct an implementation team to prepare the Azure environment for deployment. Which three actions should you recommend be performed in sequence? (To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/07/forbiden-70-533-dumps-3501.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/07/forbiden-70-533-dumps-3502.png
NEW QUESTION 351
(p.s. Copy the upper red short links and open them in your browser.)
joshaliman
Hi Sheraz, Can you provide questions as I am appearing for this exam next week or so.
[email protected]
Guttikonda
The new 70-533 dumps (Oct/2018 Updated) now are available, here are part of 70-533 exam questions (FYI):
NEW QUESTION 361
A company uses Azure to host virtual machines (VMs) and web apps. You have an app service named Appl that uses the Basic app service tier. You need to ensure that diagnostic data for Appl is permanently stored.
NEW QUESTION 362
You plan to use Azure Monitor with AutoScale Services. You create a URI to be used with the monitoring service. You need to configure an alert that specifies the URl. Which Azure Command-Line Interface (CLI) command or Azure PowerShell cmdlet should you run?
A. azure insights alerts rule log set
B. azure insights alerts actions webhook create
C. New-AzureRmAutoscaleRule
D. New-AzureRmAutoscaleWebhook
NEW QUESTION 363
A company has deployed multiple ExpressRoute circuits. The configured circuits have been designed to optimize traffic flow. You need to ensure that an alert is generated if traffic is routed through a secondary circuit. What should you do?
A. Monitor the dedicated VNet.
B. Create an Operations Management Suite (OMS) workspace.
C. Enable Network Performance Monitoring (NPM).
D. Enable Active Directory Federation Services (AD FS) auditing.
NEW QUESTION 364
You plan to use Availability Sets with Azure Virtual Machines (VMs). You need to ensure that VM disks are isolated and avoid single points of failure in the Availability Set. What should you use?
A. Managed Disks
B. Standard HDD Disks
C. geo-redundant storage
D. zone-redundant storage
NEW QUESTION 365
You are an administrator for your company's Azure environment. A developer creates an application that needs to access resources in external systems. The application will be deployed in the domain. You need to authenticate the Active Directory application. What should you implement?
A. a password and single sign-on
B. a certificate and a service account
C. a password and a service account
D. a password and a service principal
NEW QUESTION 366
You create an Ubuntu Linux virtual machine (VM) by using the Azure portal. You do not specify a password when you create the VM. You have a workstation that is connected to the internet. You need to connect the workstation to the terminal of the VM.
Solution: You conned to the private IP address of the VM by using Secure Shell (SSH) and specify your public key.
NEW QUESTION 367
You manage an Azure subscription with rnultiple virtual networks in different regions. You deploy an application to one region in the subscription. Network traffic from other regions to the application must be routed through a single virtual network. You need to configure the network.
Solution: You create a container for the application.
NEW QUESTION 368
You manage an Azure subscription with multiple virtual networks in different regions. You deploy an application to one region in the subscription. Network traffic from other regions to the application must be router through a single virtual network. You need to configure the network.
Solution: You configure an Azure ExpressRoute connection between the subscription and an on-premises datacenter.
NEW QUESTION 369
You manage an Azure subscription with multiple virtual networks in different regions. You deploy an application to one region in the subscription. Network traffic from other regions to the application must be routed through a single virtual network. You need to configure the network.
Solution: You enable virtual network peering with service chaining.
NEW QUESTION 370
A company plans to use Azure Automation. Automation runbooks must be started from a single HTTP request. You need to create the automation design.
Solution: You start a runbook by using webhooks.
NEW QUESTION 371
You are planning to utilize Azure Log Analytics and Azure Monitor. You have the following requirements:
- Crate work items automatically based on Azure Long Analytics alerts.
- Synchronizer incident and changed request data from an Azure Long analytics workspace.
Solution: You create an Operations Management Suite (OMS) workspace.
NEW QUESTION 372
A company has virtual machines (VMs) that run in Azure. They plan to use Desired Stale Configuration (DSC) to manage the VM setting. You need to programmatically prepare the VM 10 use DSC. Which Azure PowerShell cmdlet should you run?
A. Set-AzureVMscExtention
B. Set-AzureVMcustomScripExtentiom
C. Set-AzureVMExtantion
D. Set-AzureVMSupportExtention
NEW QUESTION 373
A company synchronizes on-permission Active Directory Domain Services (AS DS) user accounts to Azure Active Directory (Azure AD.) You need to monitor the latency of synchronization operations. Which tool should you use?
A. Azure AD Connect Health
B. DnSync
C. Azure AD Connect
D. AZure AD Sync
NEW QUESTION 374
A company plans to use Azure Active Directory (Azure AD) Connect Health to monitor Usage Analytics with Active Directory Federation Services (AD FS). Single sign-on (SSO) has been configured with Azure AD Connect and AD FS. You need to ensure that monitoring data is displayed in Azure AD Connect Health. What should you do?
A. Subscribe to an Azure AD Premium P1 plan.
B. Subscribe to an Azure AD Premium P2 plan.
C. Enable auditing for AD FS.
D. Create an Operation Management Suite (OMS) workspace.
NEW QUESTION 375
You plan to create virtual machines (VMs) that run Linux in an Azure subscription. You need to ensure that passwords are disabled when you create the VM.
Solution: Delete the ~/.ssh directory after creating the VMs.
NEW QUESTION 376
Solution: You specify a SSH public key when creating the VMs.
NEW QUESTION 377
Solution: You specify a SSH private key when creating the VMs.
NEW QUESTION 378
Solution: You create a storage account shared access signature.
NEW QUESTION 379
NEW QUESTION 380
Solution: You create a CDN profile by using Azure CDN Standard from Verizon SKU. You configure the profile to use a storage account endpoint.
NEW QUESTION 381
Get the newest forbiden 70-533 VCE dumps here: https://www.forbiden.com/70-533.html
https://drive.google.com/open?id=0B-ob6L_QjGLpfnV3MVl6X3pXOWw1Z3YtQUpJRVRiTkNkbGNFbVBNRXhjSkw3bWk1WHdYcW8
http://www.microsoftbraindumps.com/?s=70-533
dumpsprofessor
If you ask me for a suggestion about your preparation for Implementing Microsoft Azure Infrastructure Solutions then I will definitely suggest you to take Microsoft 70-533 EXAM PDF for definite success. I was suggested in the same way and now I am happy for my trust. The questions and answers were to the point and brief according to the exam requirements. I will always prefer Dumpsprofessor for all the exams I am going to appear in future.
Alexandrajhon
Hi friends, I pass 70-533 exam today Try 70-533 dumps PDF which are available on dumps4certs.com. Complete information is available on it regarding course 70-533 question & answers. Moreover there is less chances for failure in exam so it’s a suggestion to review the cisco 70-533 dumps PDF before starting exam. if you want good result just follow this link
http://www.dumps4certs.com/exam/70-533.html
That same questions are in following.
You administer an Azure virtual network named fabrikam VNet.
You need to deploy a virtual machine (VM) and ensure that it is a member of the fabrikam VNet virtual network.
A. Run the New-Azure VM Power Shell cmdlet.
B. Run the New-Azure Quick VM Power Shell cmdlet.
C. Run the New-Azure A fhnity Group Power Shell cmdlet.
D. Update fabrikam VNet's existing Availability Set.
Your company network has two physical locations configured in a geo-clustered environment. You create a Blob storage account in Azure that contains all the data
associated with your company.
You need to ensure that the data remains available in the event of a site outage.
Which storage option should you enable?
A. Locally redundant storage
B. Geo-redundant storage
C. Zone-redundant storage
D. Read-only geo-redundant storage
You administer an Azure Storage account with a blob container. You enable Storage account logging for read, write and delete requests.
You need to reduce the costs associated with storing the logs.
A. Execute Delete Blob requests over https.
B. Create an export job for your container.
C. Set up a retention policy.
D. Execute Delete Blob requests over http.
