70-696 - Administering System Center Configuration Manager and Intune
Discussion in 'Microsoft Certifications General' started by flightybird, Aug 17, 2016.
  1. flightybird
    flightybird Member
    Aug 16, 2016
    Question 1
    Your network contains one Active Directory domain. The domain contains a deployment of Microsoft System Center 2012 R2 Configuration Manger.
    You need to create a collection, which has only members that support connected standby. The collection membership must be updated automatically when new computer are added to the network.
    How should you configure the collection?
    Membership Rule: [ ]
    Choices: Direct Rule, Exclude Collections, Include Collections, Query Rule
    Attribute class for members: [ ]
    Choices: System, System Devices, System Resource
    Question 2
    Your network contains a single Active Directory domain. The functional level of the domain is Windows Server 2012 R2. The domain contains the servers configured as shown in the following table:
    [TABLE]
    [TR]
    [TD]Server
    [/TD]
    [TD]Role
    [/TD]
    [/TR]
    [TR]
    [TD]Server1
    [/TD]
    [TD]Microsoft System Center 2012 R2 Configuration Manager primary site server
    [/TD]
    [/TR]
    [TR]
    [TD]Server2
    [/TD]
    [TD]Windows Server Update Services (WSUS) server
    [/TD]
    [/TR]
    [TR]
    [TD]Server3
    [/TD]
    [TD]Member server
    [/TD]
    [/TR]
    [/TABLE]
    You install Microsoft System Center Updates Publisher 2011 on Server3.
    You run the Publish Software Updates Wizard to publish a third-party update from Server3, and you discover that the Automatic publish option is unavailable.
    You need to ensure that the Automatic publish option is available.
    A. From Updates Publisher 2011, enable Configuration Manager Integration
    B. From Updates Publisher 2011, run the Import Software Updates Catalog Wizard
    C. Install Updates Publisher 2011 on Server1.
    D. Install Updates Publisher 2011 on Server2.
    Question 3
    You are implementing a Microsoft Intune subscriptions that will be used to support Windows 10 mobile devices.
    You need to ensure that the Windows 10 mobile devices can discover the Intune device enrollment point automatically and can register with Microsoft Azure Active Directory (Azure AD) automatically.
    Which Type of DNS records should you create for each requirement? To answer, select the appropriate options in the answer area.
    Discover the Intune device enrollment point automatically:
    Choices: Alias (CNAME), Pointer (PTR), Service (SRV), ????
    Register with Azure AD automatically:
    Choices: Alias (CNAME), Pointer (PTR), Service location (SRV), ????
    Question 4
    You manage a multi-site deployment of Microsoft System Center 2012 R2 Configuration Manager.
    You need to ensure that clients use only their preferred distribution points for downloading content.
    Which objects and settings should you configure? To answer, select the appropriate objects and settings in the answer area.
    Objects: ????
    Settings: ??????
  2. flightybird
    flightybird Member
    Aug 16, 2016
    You deploy Microsoft System Center 2012 R2 Configuration Manager and install the Configuration Manager client on all client computers.
    You need to monitor the latest Endpoint Protection status of all the clients by using the Configuration Manager console.
    A. Use the All Systems collection and create a new deployment.
    B. Create a new collection and modify the Default Client Settings.
    C. Use the All Systems collection and modify the Default Client Settings.
    D. Create a new collection and a new deployment.
    You manage a virtualization infrastructure that has a Remote Desktop Services (RDS) deployment and a Microsoft Application Virtualization (App-V) infrastructure.
    The RDS deployment contains a VDI personal desktop collection. The App-V infrastructure contains a publishing server.
    You need to recommend a solution to ensure that VDI users to whom App-V applications are published successfully, can launch the application even if the App-V infrastructure becomes temporary unavailable.
    What should you include in the recommendation?
    A. Set-AppvClientConfiguration with the –PackageInstallationRoot switch
    B. Set-AppvClientConfiguration with the –SharedContentStoreMode switch
    C. Appv_client_setup.exe with the /AUTOLOAD switch
    D. Appv_client_setup_rds_exe with the /SHAREDCONTENTSTOREMODE switch
    You have a Microsoft System Center 2012 R2 Configuration Manager primary site named ST1.
    To all client computers you deploy the Endpoint Protection client from Configuration Manager and an antimalware policy named Policy1.
    You need to ensure that the Endpoint Protection status is updated every 10 minutes in the Monitoring workspace.
    A. Run the Set-CMClientStatusUpdateSchedule cmdlet
    B. Run the Set-CMEndpointProtectionSummarizationSchedule cmdlet
    C. Modify the scheduled client status update of the client status
    D. Modify the Policy1 Advanced settings
  3. flightybird
    flightybird Member
    Aug 16, 2016
    70-696 A. Datum, Corp.
    A. Datum, Corp.
    Overview
    A Datum Corporation is an IT services provider based in the United States. A Datum currently serves two main customers named Customer1 and Customer2.
    Existing Environment
    Network Environment (Customer1)
    The network of Customer1 contains a single domain Active Directory named
    Cusomter1 has servers that run Windows Server 2012 R2 and client computers that run either Windows 8.1 or Windows 10
    The relevant computers are configured as shown in the following table:
    [TABLE]
    [TR]
    [TD]Computer[/TD]
    [TD]Operating System[/TD]
    [/TR]
    [TR]
    [TD]Client1[/TD]
    [TD]32-bit version of Windows 10 Enterprise[/TD]
    [/TR]
    [TR]
    [TD]Client2[/TD]
    [TD]64-bit version of Windows 10 Enterprise[/TD]
    [/TR]
    [TR]
    [TD]Server102[/TD]
    [TD]Windows Server 2012 R2[/TD]
    [/TR]
    [/TABLE]
    Server102 hosts a Virtual Desktop Infrastructure (VDI). All VDI based virtual machines run the 32-bit version of Windows 10 Enterprise and have Microsoft Application Virtualization (App-V) 5.1 installed.
    Network Environment (Customer 2)
    The Network of Customer2 contains a single-domain Active Directory forest named contoso.com. Cusotmer2 has several client computers that are part of workgroups.
    Customer2 has servers that run Windows Server 2012 R2 and client computers that run either Windows 8.1 or Windows 10. Customer2 also has Windows Phone 8.1 devices used by users in the research department and the marketing department.
    Configuration Manager Environment (Customer1)
    Customer1 has a deployment of Microsoft System Center 2012 R2 Configuration Manger Service Pack 1 (SP1) that has a single primary site server named Server101. Configuration Manager is used to deploy applications and to manage computer configuration settings.
    Configuration Manager Environment (Customer2)
    Customer2 has a deployment of Configuration Manager SP1 that has three sites and ten servers configured as shown in the following table:
    [TABLE]
    [TR]
    [TD]Server Name[/TD]
    [TD]Role[/TD]
    [/TR]
    [TR]
    [TD]Server1[/TD]
    [TD]Central administration site server[/TD]
    [/TR]
    [TR]
    [TD]Server2[/TD]
    [TD]Central administration site database server[/TD]
    [/TR]
    [TR]
    [TD]Server3[/TD]
    [TD]Primary site server[/TD]
    [/TR]
    [TR]
    [TD]Server4[/TD]
    [TD]Primary site database server[/TD]
    [/TR]
    [TR]
    [TD]Server5[/TD]
    [TD]Software update point with a local Windows Server Update Services (WSUS) database[/TD]
    [/TR]
    [TR]
    [TD]Server6[/TD]
    [TD]Internet-based management point[/TD]
    [/TR]
    [TR]
    [TD]Server7[/TD]
    [TD]Enrollment point[/TD]
    [/TR]
    [TR]
    [TD]Server8[/TD]
    [TD]Enrollment proxy point[/TD]
    [/TR]
    [TR]
    [TD]Server9[/TD]
    [TD]Microsoft Intune connector[/TD]
    [/TR]
    [TR]
    [TD]Server10[/TD]
    [TD]Secondary site server[/TD]
    [/TR]
    [/TABLE]
    The code for the central administration site is C2C, the code for the primary site is C21, and the code for the secondary site is C22. Computers in the research department are part of the secondary site.
    Customer2 uses Configuration Manager to deploy software updates, to implement Endpoint Protection, and to maintain compliance of the computer configuration settings.
    Customer2 has two custom client devices settings named CS2 and CSR. CS2 is deployed to all computers. CSR is deployed to the research department computers only.
    Customer2 has a device collection named Colleciotn1 and a user collection named Collection2.
    Applications (Customer1)
    Customer1 has two main applications named App1 and App2. App1 is a 32-bit application and App2 is a 64-bit application.
    You sequence the applications as App-V packages as shown in the following table.
    [TABLE]
    [TR]
    [TD]Application Name[/TD]
    [TD]Operating System Deployment Target[/TD]
    [/TR]
    [TR]
    [TD]App1[/TD]
    [TD]32-bit version of Windows 10, 64-bit version of Windows 10, and Remote Desktop Services (RDS) in Windows Server 2012 R2[/TD]
    [/TR]
    [TR]
    [TD]App2[/TD]
    [TD]Any operating System[/TD]
    [/TR]
    [/TABLE]
    Applications (Customer2)
    Customer2 has an application named App3 that is deployed by using Configuration Manger. A new application named App4 will replace App3
    Get-AppvClientConfiguration Output (Customer2)
    You run the Get-AppvClientConfiguration cmdlet on the VDI-based machines of Cusotmer1, which generates the following output
    [TABLE]
    [TR]
    [TD]Name[/TD]
    [TD]Value[/TD]
    [/TR]
    [TR]
    [TD]PackageInstallationRoot[/TD]
    [TD]%programdata%\App-V[/TD]
    [/TR]
    [TR]
    [TD]LocationProvider[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]AutoLoad[/TD]
    [TD]2[/TD]
    [/TR]
    [TR]
    [TD]EnablePackageScripts[/TD]
    [TD]0[/TD]
    [/TR]
    [TR]
    [TD]ReestablishmentInterval[/TD]
    [TD]5[/TD]
    [/TR]
    [TR]
    [TD]ReestablishmetRetries[/TD]
    [TD]3[/TD]
    [/TR]
    [TR]
    [TD]SharedContentStoreMode[/TD]
    [TD]0[/TD]
    [/TR]
    [TR]
    [TD]MigrationMode[/TD]
    [TD]0[/TD]
    [/TR]
    [TR]
    [TD]RoamingFileExclusions[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]RomaingRegistryExclusions[/TD]
    [TD]SOFTWARE\CLASSES[/TD]
    [/TR]
    [TR]
    [TD]AllowHighCoastLaunch[/TD]
    [TD]1[/TD]
    [/TR]
    [TR]
    [TD]PackageStoreAccessControl[/TD]
    [TD]0[/TD]
    [/TR]
    [TR]
    [TD]IgnoreLocaitonProvider[/TD]
    [TD]0[/TD]
    [/TR]
    [TR]
    [TD]EnablePublishingRefresh[/TD]
    [TD]0[/TD]
    [/TR]
    [TR]
    [TD]EnableDynamicVirtualization[/TD]
    [TD]1[/TD]
    [/TR]
    [/TABLE]
    Requirements
    Planned Changes (Customer1)
    You plan to deploy App1 and App2 as App-V packages to Client1, Clint2, and the VDI based virtual machines.
    Planned Changes (Customer2)
    You identify the following planned changes for Customer2:
    · Replace App3 with App4
    · Enforce folder redirection settings for the users in Collection2
    · Manage Internet-based computers in the marketing department by using Configuration Manager
    · Add a new hardware inventory class to collect data form the research department computer
    · Deploy a server named Server11 to host an additional software update point for the primary Configuration Manager site
    · Implement a single baseline to monitor the configuration settings and the presence of software updates on the computers.
    · A Windows Server Update Services (WSUS) server
    · Five file servers that host multiple shared folders
    Technical Requirements (Customer1)
    A Datum must comply with the following requirements of Customer1:
    · The disk space used by the App-V packages on the VDI based virtual machines must be minimized.
    · Configuration Manager automatic remediation on the VDI based virtual machines must be disabled.
    · Cusotmer1 must be able to view the results of all Configuration Manage Asset Intelligence reports
    · On the VDI based virtual machines, only the App-V packages launched by users must be streamed in the background.
    Technical Requirements (Customer2)
    A Datum must comply with the following requirements of Customer2:
    · Minimize the number of components used for the new single baseline
    · Enforce folder redirection policies by using Configuration Manager compliance configuration
    · Ensure that the Endpoint Protection status of Colleciton1 is available in the Monitoring workspace of the Configuration Manager Console
    · Use Configuration Manager to block the Windows Phone 8.1 devices of the marketing department users from running a specific application
    · Use Configuration Manager to ensure that the Windows Phone 8.1 devices of the research department users can run three specific applications only.
    Q1:
    You need to upgrade App3 to meet the planned changes to Customer2.
    Which four actions should you perform in sequence?
    Choices:
    Create a new deployment
    Create a new application
    Configure supersedence for App4
    Configure supersedence for App3
    Create a new deployment type for App3
    Create a new deployment type for App4
    Q2:
    You need to deploy the Configuration Manager agent to the marketing department computer.
    What command should you run?
    CCMSetup.exe [CCMHOSTNAME=Server???] [SMSSITECIDE=XXXX] CCMAWAYSINF=1 /UsePKICert
    Q3:
    Which server must host the WSUS database for the additional software update point of Customer2?
    A. Server2
    B. Server4
    C. Server5
    D. Server11
  4. Battlemage
    Battlemage Member
    Aug 23, 2016
    Anyone have additional windows 10 questions? What about answers?
  5. Battlemage
    Battlemage Member
    Aug 23, 2016
    Here -
    is premium dump from examcollection.
    I know it is out dated, but still you can find some valid questions which may appear in exam.
  6. flightybird
    flightybird Member
    Aug 16, 2016
    You have a deployment of Microsoft System Center 2012 R2 Configuration Manager. The deployment contains two servers. The servers are configured as shown in the following table:
    [TABLE]
    [TR]
    [TD]Server
    [/TD]
    [TD]Role
    [/TD]
    [/TR]
    [TR]
    [TD]Server1
    [/TD]
    [TD]Site Server
    [/TD]
    [/TR]
    [TR]
    [TD]Server2
    [/TD]
    [TD]Reporting Services Point
    [/TD]
    [/TR]
    [/TABLE]
    Answer
    [TABLE]
    [TR]
    [TD]Actions
    [/TD]
    [TD]Server1
    [/TD]
    [TD]Server2
    [/TD]
    [/TR]
    [TR]
    [TD]Run the Create Report Wizard
    [/TD]
    [TD]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Configure the Email Settings
    [/TD]
    [TD][/TD]
    [TD]
    [/TD]
    [/TR]
    [TR]
    [TD]Run the Create Subscription Wizard
    [/TD]
    [TD][/TD]
    [TD]
    [/TD]
    [/TR]
    [TR]
    [TD]Create a shared schedule
    [/TD]
    [TD]
    [/TD]
    [TD][/TD]
    [/TR]
    [/TABLE]
  7. Rawdha Juma
    Rawdha Juma Member
    Aug 25, 2016
    MCSC EXAM Question Required Answers
    here are some more question if any one now the answer of the previse and these question please share it with us.
    1. You need to configure software monitoring for the development department users. The solution must meet the Configuration Manager requirements.
    Which three actions should you perform in sequence? To answer, move the appropriate actions from the list of actions of the answer area and arrange them in the correct order.
    Actions Answer Area
    [TABLE="width: 100%"]
    [TR]
    [TD]Create custom client user settings[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Configure user device affinity[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Create custom client device settings[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Create a deployment[/TD]
    [/TR]
    [/TABLE]
    2. You need to configure the maintenance window for thecomputers in Collection1 and Collection2. The solution must meet the Configuration Managerrequirements. What is the minimum number of maintenance windows you must create?
    3. You are planning the replacement of App4 to meet the Configuration Manager requirements. You need to ensure that you can deploy App3 after the upgrade of App4 is complete. Which three actions should you perform in sequence? To answer, move the appropriate actions from the list of actions of the answer area and arrange them in the correct order.
    Actions Answer Area
    [TR]
    [TD]Configure supersedence for App3. [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Configure supersedence for App5.
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Configure supersedence for App4.
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Add App5 to the dependency group of App3
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Create a Configuration Manager application for App5.
    [/TD]
    [/TR]
    [/TABLE]
  8. Battlemage
    Battlemage Member
    Aug 23, 2016
    From my perspective, correct answers:
    Objects: Distribution Points
    Settings: Boundary groups
    4)Create a new deployment
    1)Create a new application
    3)Configure supersedence for App4
    2)Create a new deployment type for App4
    Q3:
    A. Server2
    B. Server4
    C. Server5
    D. Server11
    [TABLE="width: 531"]
    [TR]
    [TD]Actions[/TD]
    [TD]Server1[/TD]
    [TD]Server2[/TD]
    [/TR]
    [TR]
    [TD]Run the Create Report Wizard[/TD]
    [TD]x[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Configure the Email Settings[/TD]
    [TD][/TD]
    [TD]x[/TD]
    [/TR]
    [TR]
    [TD]Run the Create Subscription Wizard[/TD]
    [TD]x[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    2)Configure user device affinity
    1)Create custom client device settings
    3)Create a deployment
    [TR]
    [TD]Configure supersedence for App3.[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]2) Configure supersedence for App5.[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]Configure supersedence for App4.[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]3) Add App5 to the dependency group of App3[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]1)Create a Configuration Manager application for App5.[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [TD]x
    [/TD]
    [/TR]
    [/TABLE]
    If anyone have new additional questions, please share with us. :)
  9. flightybird
    flightybird Member
    Aug 16, 2016
    From a friend who took the test today:
    Proseware Case Study
    You need to recommend a deployment solution for App3.
    What is the best recommendation? More than one answer choice may achieve the goal. Select the BEST answer.
    A. A Configuration Manager package that performs an automated installation by using the MSI packages
    B. A Configuration Manager application that performs streaming delivery of a Microsoft Applications Virtualization (App-V) package.
    C. A Configuration Manager application that performs an automated installation by using the MSI packages
    D. A Configuration Manger package that performs local delivery of a Microsoft Application Virtualization (APP-V) package
    Litware Case Study
    You run several Windows PowerShell command and you receive the following output:
    PS LI1:\> Get-CMDeviceCollection –Name ‘Collection4’
    CollectionID : LI10000D
    CollectionRules : {Collection2, Rule1}
    CollectionType : 2
    CollectionStatus : 1
    HasProvisionedMember: True
    IncludeExcludeCollectionsCount : 1
    IsBuiltIn : False
    IsReferenceCollection : False
    LimitToCollectionId : LI110000A
    LimitToColletionNAme : Collection1
    LocalMemberCount :
    MemberCount : 1300
    PS LI1:\> Get-CMDeviceCollectionQueryMembershipRule –CollectionName ‘Collection4’ –RuleName ‘Rule1’
    QueyExpression : select
    SMS_R_SYSTEM.ResrouceID,SMS_R_SYSTEM.RsourceType,SMS_R_SYSTEM.Name,SMS_R_SYSTEM. SMSUniqueIdentifier,SMS_R_SYSTEM.ResourceDomainORWorkgroup,SMS_R_System.Client from SMS_R_System inner join
    On SMS_G_System_OPERATING_SYSTEM.ResourceId = SMS_R_System.ResourceId where
    SMS_G_System_OPERATING_SYSTEM.Captionlike “%Windows 8.1 Pro%” RuleName : Rule1
    PS LI1:\ Get-CMDeviceColletionIncludeMembershipRule – CollectionID LI10000D –IncludeCollectionId LI1000B
    LI10000B Collection 2
    Use the drop-down menus to select the answer choice that completes each statement:
    Collection4 will contain [answer] physical desktop computers that run Windows 8.1 Enterprise
    Choices: All, No, Some
    Collection 4 will contain [answer] client computers in the Toronto office
    Choice: All, No, Some
  10. flightybird
    flightybird Member
    Aug 16, 2016
    There is also a stupid question where you have to choose the right size/file type/resolution for your customized Intune portal company logo. Since that absolutely proves you are an expert in this stuff. Who bothers to hold stuff like that in the memory?
    Here is the relevant stuff to memorize:
    [TABLE="width: 748"]
    [TR]
    [TD]Include company logo[/TD]
    [TD]When you enable this option, you can upload your company logo to show in your Company Portal. You can upload two logos: one logo that is displayed when the Company Portal background is white, and one logo that is displayed when the Company Portal background uses your selected theme color. Each logo must be a .png or .jpg file type and have a maximum resolution of 400 x 100 pixels and be 750 KB or less in size.[/TD]
    [/TR]
    [/TABLE]
    #10 flightybird, Aug 27, 2016
  11. flightybird
    flightybird Member
    Aug 16, 2016
    Best Guess: A Configuration Manager application that performs streaming delivery of a Microsoft Applications Virtualization (App-V) package.
    A third party desktop application named App3 is used by the users in the research department. The first update for App3 was released by the application vendor as a Windows Installer (MSI) package. The update was not deployed yet.
    App3 is used only on company owned computers
    Redeploy App3 to include the update.
    When you decide which Configuration Manager virtual application delivery method to use, compare the reduced disk space requirement for streaming delivery against the guaranteed availability of App-V applications by using local delivery. The increased client disk space that is required for local delivery might be preferable to streaming delivery so that users always have the application available from any location.
    So, if users are already running out of disk space, I am guessing local delivery would not be a viable option.
  12. flightybird
    flightybird Member
    Aug 16, 2016
    You need to configure the maintenance window for the computers in Collection1 and Collection2.
    1. 1
    2. 2
    3. 3
    4. 4
    Answer: Best Guess is C
    Collection1 and Collection2 have Computers 1, 2, and 3 in them. Computer3 also belongs to Colletion3.
    The maintenance window for Computer 1 can be between 01:00 – 05:00 since it is in both Collection1 and Collection3
    The maintenance window for Computer 2 can be between 01:00 – 04:00 since it is in both Collection1 and Collection2.
    The maintenance windows for Computer 3 can be between 02:00 – 05:00 since it is in both Collection2 and Collection3.
    _____________________
    Deployments are somewhat limited in that they do not define an exact time that updates should or must be installed; they merely define a time when updates become mandatory. This could easily cause disruption to your users and your servers if updates install at various times after the deadline. Maintenance windows solve this dilemma. In general, maintenance windows prevent the ConfigMgr client from undertaking any action that could disrupt the end user or hosted services on a system. This includes preventing software updates deployments, software distribution advertisements, and restarts initiated by ConfigMgr for software updates.
    The effective maintenance windows for any given system is the cumulative or combined schedule specified in all the maintenance windows of all the collections of which a system is a member.
    System Center 2012 Configuration Manager (SCCM) Unleashed
  13. Abd92350
    Abd92350 Member
    Aug 24, 2016
    thank you guys this is very helpful but can you provides question and answers for the new two case study in 70-695(relecloud & Datum)I couldn't find it any where
  14. Battlemage
    Battlemage Member
    Aug 23, 2016
    I suppose there are no answers available. You have to go through questions and find answers by yourself.
  15. Hector Garrity
    Aug 8, 2016
    48
    Let me share some 70-695/696 study materials:
    70-695 dumps with exam topics:
    (short link: tr.im/1kSLa)
    70-696 dumps with exam topics:
    (short link: tr.im/1xsHH)
  16. Raul
    Raul Member
    Sep 14, 2016
    Hi hector,
    In this new dumps is included new case (Datum Corporation) ?
  17. Raul
    Raul Member
    Sep 14, 2016
    I think that the answers is:
    Litware Case Study
    CollectionType : 2
    IsBuiltIn : False
    LocalMemberCount :
    MemberCount : 1300
    Collection4 will contain NO physical desktop computers that run Windows 8.1 Enterprise
    Collection 4 will contain ALL client computers in the Toronto office
    #17 Raul, Nov 14, 2016
  18. Raul
    Raul Member
    Sep 14, 2016
    Question 3
  19. Battlemage
    Battlemage Member
    Aug 23, 2016
    Anyone have any updates regarding to this exam?
  20. Raul
    Raul Member
    Sep 14, 2016
    Hi Battlemage,
    I passed the exam with a 700 and the questions that were based were those that are commented here, the case study of Datum Corporation, has 7 questions
