70-698 valid dumps
Discussion in '70-698' started by Yasmine, Apr 8, 2018.
  1. Yasmine
    Yasmine Member
    Mar 8, 2018
    53
    Hi guys, does someone have any info about 70-698 exam?
    Or has someone passed and know of a good dump or good place to buy?
    How many of the questions are from current dumps?
  2. grantgingles
    grantgingles Member
    Apr 14, 2018
    Just know the version of 70-698 has been updated the day before last day. 130 exam questions material could be recommended to get.
  3. Yasmine
    Yasmine Member
    Mar 8, 2018
    53
    hi grantgingles, do you maybe have some dumps that I can use? Would appreciate the help
  4. grantgingles
    grantgingles Member
    Apr 14, 2018
    In this section, you will see one or more sets of questions with the same scenario and problem. Each question presents a unique solution to the problem, and you must determine whether the solution meets the stated goals. Any of the solutions might solve the problem. It is also possible that none of the solutions solve the problem. Once you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen. Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution. Determine whether the solution meets the stated goals. You have a computer named Computer1 that runs Windows 10. File History is turned on. The user of Computer1 reports that previous versions of D:\Folder\File1.doc are unavailable from the Previous Versions tab. You need to ensure that the previous versions of the file are created. Solution: Modify the Backup settings in the Settings app. Does this meet the goal?
    In this section, you will see one or more sets of questions with the same scenario and problem. Each question presents a unique solution to the problem, and you must determine whether the solution meets the stated goals. Any of the solutions might solve the problem. It is also possible that none of the solutions solve the problem. Once you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen. Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution. Determine whether the solution meets the stated goals. You have a computer named Computer1 that runs Windows 10. File History is turned on. The user of Computer1 reports that previous versions of D:\Folder\File1.doc are unavailable from the Previous Versions tab. You need to ensure that the previous versions of the file are created. Solution: Turn on System Protection for drive D. Does this meet the goal?
    In this section, you will see one or more sets of questions with the same scenario and problem. Each question presents a unique solution to the problem, and you must determine whether the solution meets the stated goals. Any of the solutions might solve the problem. It is also possible that none of the solutions solve the problem. Once you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen. Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution. Determine whether the solution meets the stated goals. You have a computer named Computer1 that runs Windows 10. File History is turned on. The user of Computer1 reports that previous versions of D:\Folder\File1.doc are unavailable from the Previous Versions tab. You need to ensure that the previous versions of the file are created. Solution: Create a backup of drive D by using Backup and Restore (Windows 7). Does this meet the goal?
    In this section, you will see one or more sets of questions with the same scenario and problem. Each question presents a unique solution to the problem, and you must determine whether the solution meets the stated goals. Any of the solutions might solve the problem. It is also possible that none of the solutions solve the problem. Once you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen. Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution. Determine whether the solution meets the stated goals. You have a computer named Computer1 that runs Windows 10. File History is turned on. The user of Computer1 reports that previous versions of D:\Folder\File1.doc are unavailable from the Previous Versions tab. You need to ensure that the previous versions of the file are created. Solution: Add D:\Folder\to the Documents library. Does this meet the goal?
    In this section, you will see one or more sets of questions with the same scenario and problem. Each question presents a unique solution to the problem, and you must determine whether the solution meets The safer , easier way to help you pass any IT exams. 4 / 4 the stated goals. Any of the solutions might solve the problem. It is also possible that none of the solutions solve the problem. Once you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen. Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution. Determine whether the solution meets the stated goals. Your network contains a single Active Directory domain named contoso.com. The domain contains two computers named Computer1 and Computer2. A user named User1 is a member of the local Administrators group on Computer1 and Computer2. User1 fails to access the Event Viewer logs on Computer2 from Computer1. User1 can connect to Computer2 remotely by using Computer Management. You need to ensure that User1 can use Event Viewer on Computer1 to remotely view the Event Viewer logs on Computer2. Solution: You start the Remote Registry services on Computer2. Does this meet the goal?
    Not the full version but a little part of the real dumps from examgood.
  5. Yasmine
    Yasmine Member
    Mar 8, 2018
    53
    Thanks!
  6. SATORUINUI
    SATORUINUI Member
    Jan 26, 2018
    Recommend to try the latest PassLeader 70-698 dumps here:
    Updated recently, good luck!!!
