70-743 Dump
Discussion in '70-743' started by HomeWorld, Feb 10, 2017.
  1. Mouratov
    Mouratov Member
    Jan 27, 2016
    188
    22
    Thanks i will check, anyone take recently?
  2. MyUsername
    MyUsername Member
    Oct 5, 2017
    I have found 2 things in Grubberz vce (Fixed.70-743.v4.1_05.09.2017_Grubberz.vce) that need fixing.
    Question 121 list no answer ?
    Your network contains an Active Directory domain named contoso.com. The domain contains a
    domain-based Distributed File System (DFS) namespace named Namespace1.
    You need to view the shares to which users will be redirected when the users attempt to connect to a
    folder named Folder1 in the DFS namespace.
    What cmdlet should you run? To answer, select the appropriate options in the answer area
    Is the correct answer ?
    Get-DfsnFolder \\Contoso.com\Namespace1\Folder1
    Question 91, 119 and 120 are exactly the same question but have different answers ?
    Your company has 10 offices. Each office has a local network that contains several Hyper-V
    hosts that run Windows Server 2016.
    All of the offices are connected by high speed, low latency WAN links.
    You need to ensure that you can use QoS policies for Live Migration traffic between the offices.
    Which component should you install?
    Question 91 says that 'The Data Center Bridging feature' + 'the Netwrok Contrller server role' is the correct answer
    Question 119 and 120 says that only 'The Data Center Bridging feature' is the correct answer
    Which one is correct ?
    Does anyone know the answers to these?
    #262 MyUsername, Oct 31, 2017
  3. Dac
    Dac Member
    Oct 28, 2017
    The correct answer is : The Data Center Bridging feature
    Server Message Block Direct (SMB Direct) and Data Center Bridging (DCB).
    Minimum Bandwidth and Maximum Bandwidth are enforced by QoS Packet Scheduler. They work well with traffic that flows through the Windows Server networking stack.
    But there is network traffic that bypasses the networking stack. The most notable example is Server Message Block Direct (SMB Direct), a Windows Server 2012 feature that builds on Remote Direct Memory Access (RDMA). SMB Direct offloads the SMB traffic directly to an RDMA-capable NIC to reduce latency and the number of CPU cycles that are spent on networking. Because SMB Direct still competes for bandwidth with other network traffic at the NIC hardware, one can impact or even starve the other if they are left unchecked.
    To resolve this issue, you can use Data Center Bridging (DCB). DCB is implemented by some NIC vendors in network adapters. DCB works in a similar way as Minimum Bandwidth: each class of traffic, regardless of whether it’s offloaded or not, has bandwidth allocation; in the event of network congestion, each class gets its share - otherwise, each class gets as much bandwidth as is available.
  4. Dac
    Dac Member
    Oct 28, 2017
    Can someone confirm if this is valid?
  5. jupuanpa2004
    jupuanpa2004 Member
    Oct 26, 2017
    Dac, there are few differences in answers between your VCE and Grubberz vce (Fixed.70-743.v4.1_05.09.2017_Grubberz.vce).
    One of the questions with dif. answer is about IPAM discovery and other about ADFS (yes or no answer).
    Also there are some questions that in Grubberz Vce does not exist.
    This question are: 15, 23, 24, 25, 26, 28, 33, 34, 46, 54, 57, 65, 71, 72, 76, 84, 105, 106, 125, 127, 129.
    I think both VCE are valids.
    Regards.
    #265 jupuanpa2004, Oct 31, 2017
  6. Dac
    Dac Member
    Oct 28, 2017
    Thanks ;)
  7. MyUsername
    MyUsername Member
    Oct 5, 2017
    Dac, i'm going with your PDF is invalid but only based on question 1 answer is incorrect but is correct in Grubberz VCE
    Your network contains an Active Directory domain named contoso.com. The domain contains a server named Server1 that runs Windows Server 2016.
    You install IP Address Management (IPAM) on Server1. You select the automatic provisioning method, and then you specify a prefix of IPAM1.
    You need to configure the environment for automatic IPAM provisioning.
    Which cmdlet should you run? To answer, select the appropriate options in the answer area.
    Invoke-IpamGpoProvisioning –Domain "contoso.com" –GpoPrefixName
    You can choose to manually or automatically provision access to managed servers. If you provisioned the managed servers by using group policy, make sure to create the corresponding GPOs in every managed domain by using the Invoke-IpamGpoProvisioning cmdlet.
  8. TunaLion
    TunaLion Member
    Feb 2, 2016
    24
    How about this Premium dump. is this also valid? or it pretty much the same? don't know.
    Why do you want to use a dump with more questions, when the dump from Grubberz is already valid as it is with fewer questions to study?
    Thx once again Grubberz, you are awesome!
  • jupuanpa2004
    jupuanpa2004 Member
    Oct 26, 2017
    Dear.
    I passed 70-743 exam: 9XX.
    740 installing storage and compute with w2016 -> 100%
    741 Networking with w2016 -> 8X%
    742 Identity with w2016-> 8X%
    I studied with grubberz vce.
    59 question, 1 question was in DAC VCE (Number 33). This question is not in Grubberz vce. For other 58q i answered studying Grubberz VCE.
    My suggestion: Use Grubberz VCE to study, it's holy!!!
    And use DAC VCE only in questions that not appears in Grubberz VCE.
    Grubberz, you are great!!!!!
    Regards.
    mpmpmn likes this.
  • mpmpmn
    mpmpmn Member
    Nov 9, 2015
    Dear.
    Regards.
    Congrats, when did you took the exam 70-743 ?
  • jupuanpa2004
    jupuanpa2004 Member
    Oct 26, 2017
    Yesterday.
  • TunaLion
    TunaLion Member
    Feb 2, 2016
    24
    All the questions from my exam were in Grubberz VCE, except three VPN yes/no questions, which I answered all 'No'. I would thus not recommend any other VCE, except if you like to waste your own time.
  • Dac
    Dac Member
    Oct 28, 2017
    Passed the exam with 9xx
    New 4 VPN questions series:
    This question is part of a series of questions that present the same scenario. Each
    question in the series contains a unique solution that might meet the stated goals. Some questions
    sets might have more than one correct solutions, while others might not have a correct solution.
    After you answer a question in this section, you will NOT be able to return to it. As a result, these
    questions will not appear in the review screen.
    You have a server named Server1 that runs Windows Server 2016. Server1 is configured as a VPN
    server.
    Server1 is configured to allow domain users to establish VPN connections from 06:00 to
    18:00 everyday of the week.
    You need to ensure that domain users can establish VPN connections only between
    Monday and Friday...........................
    I am sharing the latest dump
  • themaintainer
    themaintainer Member
    Jan 11, 2017
    Hi guys,
    I've uploaded my own vce + pdf + last A+ player on my cloud and you can use it.
    Hi Grubberz!
    Which VCE Designer version did u use?
    THX
  • mpmpmn
    mpmpmn Member
    Nov 9, 2015
    Passed with 9XX, Thanks to Grubberz , VCE fully valid, I got only 2 new questions
  • sydey123
    sydey123 Member
    Jan 11, 2016
    Passed today with 843, New Questions are
    1. How to enable make windows server 2016 as global catalog server
    Ans: I have answered as "NTDS Settings"
    2. Answered below
    Mount-WindowsImage
    Add-WindowsDriver
    Save-WindowsImage
    3. as Gardan mentioned
    Office 365 with AD FS Single Sign-On with PowerShell: 4-5 steps (not sure)
    Connect-MsolService
    Convert-MsolDomainToFederated –DomainName
    Can’t remember the rest about 5-6 options
    Correct Answer :
    • Connect to Microsoft Online Services with the credential variable set previously
      • Connect-MsolService –Credential $cred
    • Set the MSOL ADFS Context server, to the ADFS server
      • Set-MsolADFSContext –Computer adfs_servername.domain_name.com
    • Convert the domain to a federated domain
      • Convert-MsolDomainToFederated –DomainName domain_name.com
    I have made first two correct and last one will be above
    4. question around someone added a host record in DNS, where does it logs in IPAM or IPAM events last updated is yesterday and we need to change that setting to log changes every 1 hour
    I have answered as IPAM_DNS update GPO setting, not remember, pls investigate urself
    5. Question around IPAM where does administrator view all IP address inventory in IPAM - options are event log, IPAM inventory etc etc
    I have answered like Inventory
    6. No Yes/No questions in my exam
    I hope my feedback is helpful
  • sydey123
    sydey123 Member
    Jan 11, 2016
    By the way thanks to GrubberZ VCE and 13.95 is valid
  • daveorange
    daveorange Member
    Dec 24, 2017
    guys anyone can you share GrubberZ VCE and 13.95 ? latest version did you use? I want to take exam next week
  • sydey123
    sydey123 Member
    Jan 11, 2016
    hey dave, this pdf has more questions than VCE
    Icaro, _warp_ and daveorange like this.
  • daveorange
    daveorange Member
    Dec 24, 2017
    Thanks Sydev123 I will be checking I have exam next friday
    Icaro likes this.
