70-743 Dump
Paul Cinmarek
hi people, now you have all compiled and corrected in just 1 vce, dont need to buy anything from spammers here ;)
http://www.certifychat.com/threads/70-743-upgrading-your-skills-to-mcsa-windows-server-2016.8290/
Q238 - Your answer looks incorrect to me. Round robin is enabled in this case, so DNS can resolve up to 3 different addresses for Host1, since there are 3 different A records for it, unless netmask ordering overrides that. That leaves me with the final question, why would host 172.16.100.1 always resolve host1 to 172.16.1.100, and not all 3? Netmask ordering would not apply here.
Care to elaborate? Thanks.
BS123
Q238
Yes ( Netmask ordering)
Yes
No
https_nedimmehic.org/2017/03/21/how-to-deploy-and-configure-dns-2016-part3
supimpa2017
has anyone recently taken this test with success ? thinking about taking it next week
Tanya
Are you looking for the latest preparation material for Microsoft 70-743 Exam Dumps? Then you should visit Dumps4free for 70-743 Braindumps. Dumps4free have the best online training material for Microsoft 70-743 Dumps Upgrading Your Skills to MCSA: Windows Server 2016 Exam, and it covers all the questions that will be asked in the 70-743 Free Dumps Questions Answers. I vastly acclaim you to visit the Dumps4free if you want to score good grades in the Microsoft 70-743 Dumps PDF at first endeavor. Dumps4free is a leading source that provides most precise and reliable dumps of Microsoft 70-743 Free Braindumps exam. Dumps4free provides all the facility that makes you 70-743 Free Exan Dynos certified.
666Forest
Failed today 663/1000.
Maybe 10 question from this dump. Total 56, questions. ~15 question in yes/no option.
Margrietha Wezenberg
The new 70-743 dumps (Nov/2018 Updated) now are available, here are part of 70-743 exam questions (FYI):
NEW QUESTION 260
Your network contains an Active Directory domain named contoso.com that contains a domain controller named DC1. All DNS servers for the network run BIND 10. Your perimeter network contains a DHCP server named DHCP1 that runs Windows Server 2016. DHCP1 is a member of a workgroup named WORKGROUP. DHCP1 provides IP address leases to guests accessing the Wi-Fi network. Several engineers access the network remotely by using a VPN connection to remote access server that runs Windows Server 2016. All of the VPN connections use certificate-based authentication and are subjects to access policies in Network Policy Server (NPS). Certificates are issued by an enterprise certification authority (CA) named CA1. All Windows computers on the network are activated by using Key Management Service (KMS). On-premises users use Remote Desktop Services (RDS). You plan to deploy IP Address Management (IPAM) to the network. Which action can you perform on the network by using IPAM?
A. Audit authentication events from DC1.
B. Create DHCP reservations on DHCP1.
C. Audit certificate enrollment requests on CA1.
D. Manage activations on the KMS server.
NEW QUESTION 261
You have a server named Server1 that runs Windows Server 2016. You install the Hyper-V role on Server1. Server1 has eight network adapters that are dedicated to virtual machines. The network adapters are Remote Direct Memory Access (RDMA)-enabled. You plan to use Software Defined Networking (SDN). You will host the virtual machines for multiple tenants on the Hyper-V host. You need to ensure that the network connections for the virtual machines are resilient if one or more physical network adapters fail. What should you implement?
A. NIC Teaming on the Hyper-V Host
B. Virtual Receive-Side Scaling (vRSS)
C. Switch Embedded Teaming (SET)
D. Single Root I/O Virtualization (SR-IOV)
NEW QUESTION 262
Your network contains an Active Directory forest named contoso.com. The forest contains two domains named contoso.com and litwareinc.com. Your company recently deployed DirectAccess for the members of a group named DA_Computers. All client computers are members of DA_Computers. You discover that DirectAccess clients can access the resources located in the contoso.com domain only. The clients can access the resources in the litwareinc.com domain by using an L2TP VPN connection to the network. You need to ensure that the DirectAccess clients can access the resources in the litwareinc.com domain. What should you do?
A. On an external DNS server, create a zone delegation for litwareinc.com.
B. From a Group Policy object (GPO), modify the Name Resolution Policy Table (NRPT).
C. Add the servers in litwareinc.com to the RAS and IAS Servers group.
D. From the properties of the servers in litwareinc.com, configure the delegation settings.
NEW QUESTION 263
You have two Hyper-V hosts named Server1 and Server2 that run Windows Server 2016. The hosts are nodes in failover cluster. You have a virtual machine named VM1. VM1 connects to a virtual switch named vSwitch1. You discover that VM1 automatically live migrates when vSwitch temporarily disconnects. You need to prevent VM1 from being live migrated when vSwitch1 temporarily disconnects. What should you do?
A. From the network adapter setting of VM1, disable the Protected network setting.
B. From the network adapter setting of VM1, disable the Heartbeat integration service.
C. Run the Set-VMNetworkAdapter cmdlet and set IsmanagementOS to False.
D. Run the Set-VMNetworkAdapter cmdlet and set StormLimit to 0.
NEW QUESTION 264
You have a Windows Server 2016 failover cluster named Cluster1 that contains four nodes named Server1, Server2, Server3, and Server4. You need to configure Cluster1 to use directly attached storage to host several virtual machines. You run the Enable-ClusterStorageSpacesDirect cmdlet on Server1. What should you do next?
A. Run the Enable-ClusterStorageSpacesDirect cmdlet on the other three nodes.
B. Create volumes.
C. Create a storage pool.
D. Run the Add-ClusterResource cmdlet on all of the nodes.
NEW QUESTION 265
Your network contains an Active Directory domain named contoso.com. The domain contains two servers named Server1 and Server2 that run Windows Server 2016. Each server has an operating system disk and four data disks. All of the disks are locally attached SATA disks. Each disk is a basic disk, is initialized as an MBR disk, and has a single NTFS volume. You plan to implement Storage Spaces Direct by using the data disks on Server1 and Server2. You need to prepare the data disks for the Storage Spaces Direct implementation. What should you do?
A. Format the volumes on the data disks as exFAT.
B. Initialize the data disks as GPT disks and create a ReFS volume on each disk.
C. Convert the data disks to dynamic disks.
D. Delete the volumes from the data disks.
NEW QUESTION 266
You use Application Request Routing (ARR) to make internal web applications available to the Internet by using NTLM authentication. You need to replace ARR by using the Web Application Proxy. Which server role should you deploy first?
A. Active Directory Rights Management Services
B. Active Directory Federation Services
C. Active Directory Certificate Services
D. Active Directory Lightweight Directory Services
NEW QUESTION 267
You have a server named Server1 that runs Windows Server 2016. Server1 is an IP Address Management (IPAM) server that collects DHCP and DNS logs and events for your entire network. You need to enable a user named TECH1 to create pointer (PTR), host (A) and service location (SRV) records on all of the DNS servers on the network. What should you do on Server1?
A. From the IPAM node in Server Manager, assign the IPAM DNS Administrator Role to TECH1 and create a new access policy.
B. Run the Set-IpamCustomField cmdlet, and then run the Set-IpamAddressSpace cmdlet.
C. Run the Set-IpamCustomField cmdlet, and then run the Set-IpamAccessScope cmdlet.
D. Run the Set-IpamRange cmdlet, and then run the Set-IpamAddressSpace cmdlet.
NEW QUESTION 268
On a new server, you install Windows Server 2016, and then you install the Hyper-V server role. You need to ensure that you can deploy Windows containers that use an image of the Server Core installation of Windows Server. Which four commands should you use in sequence? (To answer, move the appropriate commands to the answer area and arrange them in the correct order.)
NEW QUESTION 269
You deploy a new Hyper-V host named Server1 that runs Windows 2016. You implement receive side scaling (RSS) on Server1. The chipset on Server1 does not support NetDMA. All of the equipment on your network supports 10-Gbps connectivity. On Server1, you deploy a virtual machine named VM1. You configure VM1 to aggregate all of the Windows and non-Windows log files for all of the servers on the network. VM1 has four virtual processors. You discover that VM1 drops packets. You monitor the network, and you discover that the network capacity is sufficient for the monitoring traffic. You monitor the performance of VM1, and you discover that one processor is consistently at 100 percent utilization, while the other processor is barely in use. You need to resolve the performance issue. What should you do? (To answer, select the appropriate options in the answer area.)
NEW QUESTION 270
Download more NEW Pass Leader 70-743 PDF dumps from Google Drive here:
https://drive.google.com/open?id=0B-ob6L_QjGLpdUZlRVBrYVdFb28
Read the newest Pass Leader 70-743 exam questions from this Blog:
http://www.microsoftbraindumps.com/?s=70-743
ricard
Thank! Coud you put new update December? Thx!
skater_7
NEW QUESTION 260
NEW QUESTION 261
NEW QUESTION 262
NEW QUESTION 263
NEW QUESTION 264
B. Create volumes.
NEW QUESTION 265
NEW QUESTION 266
NEW QUESTION 267
NEW QUESTION 268
http://www.microsoftbraindumps.com/wp-content/uploads/2018/11/forbiden-70-743-dumps-2681.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/11/forbiden-70-743-dumps-2682.png
NEW QUESTION 269
http://www.microsoftbraindumps.com/wp-content/uploads/2018/11/forbiden-70-743-dumps-2691.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/11/forbiden-70-743-dumps-2692.png
NEW QUESTION 270
Get the newest forbiden 70-743 VCE dumps here: https://www.forbiden.com/70-743.html
Download more NEW forbiden 70-743 PDF dumps from Google Drive here:
Read the newest forbiden 70-743 exam questions from this Blog:
there is like 30% incorrect answers there guys, so be carefull
The new 70-743 dumps (Mar/2019 Updated) now are available, here are part of 70-743 exam questions (FYI):
NEW QUESTION 287
You have a Hyper-V named Server1. The network adapters on Server1 have single root I/O virtualization (SR-IOV) enabled. Server1 hosts a virtual machine named VM1 that runs Windows Server 2016. You need to identify whether SR-IOV is used by VM1.
Solution: On Server1, you open Hyper-V Manager and view the integration Services settings of VM1.
NEW QUESTION 288
Solution: You sign in to VM1. You view the properties of the network connections.
NEW QUESTION 289
Solution: You sign in to VM1. You open Device Manager and view the properties of the network adapters.
NEW QUESTION 290
Your network contains an Active Directory domain named contoso.com. The domain contains two domain controllers named DC1 and DC2. DC1 holds the RID master operations role. DC1 fails and cannot be repaired. You need to move the RID role to DC2.
Solution: On DC2, you open the command prompt, run dsmgmt.exe, connect to DC2, and use the Seize RID master option.
NEW QUESTION 291
Solution: On DC2, you open the command prompt, run ntdsutil.exe, connect to DC2, and use the Transfer RID master option.
There are 2 ways of transferring FSMO roles. You can do that using graphical consoles available on a DC or any server/workstation with Administrative Tools / Remote Server Administration Tools installed or using command-line tool called ntdsutil.
NEW QUESTION 292
You have a server named Server1 that is an iSCSI target. You have a server named Server2 that runs Windows Server 2016. Server2 has an iSCSI disk named Disk1 that is hosted on Server1. Disk1 contains one volume that is assigned a drive letter of E. You need to increase the size of Disk1. What should you do?
A. Run the Resize-IscsiVirtualDisk cmdlet and specify the -ComputerName Server1 parameter.
B. Run the Resize-Partition cmdlet and specify the -ComputerName Server1 parameter.
C. Run the Resize-Partition cmdlet and specify the -ComputerName Server2 parameter.
D. Run the Resize-IscsiVirtualDisk cmdlet and specify the -ComputerName Server2 parameter.
NEW QUESTION 293
You have a server named Server1 that runs Windows Server 2016. You need to install the DNS Server role on Server1. What should you run?
A. the dnscmd.exe command
B. the dns.exe command
C. the Install-WindowsFeature cmdlet
D. the Add-WindowsPackage cmdlet
NEW QUESTION 294
A. Audit user and device logon event from NPS.
B. Audit configuration changes to the remote access server.
C. Audit logon event on the RDS server.
NEW QUESTION 295
Solution: On DC2, you open Windows PowerShell and run Move-ADDirectoryServerOperationMasterRole -OperationMasterRole RIDMaster -Identity DC2.Adatum.com.
We need to seize the RID role and thus must use the -Force parameter.
NEW QUESTION 296
You have two servers named Server1 and Server2 that run Windows Server 2016. Server1 contains a volume named Volume1. You implement a Storage Replica that replicates the contents of Volume1 from Server1 to Server2. Server1 fails. From Server2, you need to ensure that you can access the contents of Volume1. What should you run?
A. vssadmin revert shadow
B. Set-SRPartnership
C. Clear-FileStorageTier
D. Update-StoragePool
We need to promote the destination volume to become the source volume.
NEW QUESTION 297
You have a server named Server1 that runs Windows Servers 2016. Server1 has a storage array that contains multiple storage enclosures. The storage supports enclosure awareness. You need to implement Storage Spaces on Server1. Storage Spaces must remain available if two enclosures fail. The solution must minimize the number of enclosures required and must provide the fastest possible write performance. Which configurations should you use? (To answer, select the appropriate options in the answer area.)
Both dual parity and three-way mirror provide resilience against two enclosures failing but dual parity provides better storage efficiency.
NEW QUESTION 298
Your network contains an Active Directory domain contoso.com. The domain contains a server named Server1 that runs Windows Server 2016. Server1 allows inbound connectivity from all computers in the contoso.com domain. Server1 has an IP address of 192.168.0.10. Server1 hosts a Windows container named Container1. Container1 hosts a website that is accessible on port 80. You need to ensure that you can use the Docker client to manage Container1 from any computer in the domain. Which three commands should you run on Server1 in sequence? (To answer, move the appropriate commands from the list of commands to the answer area and arrange them in the correct order.)
NEW QUESTION 299
You have a server named Server1 that runs Windows Server 2016. The Docker daemon runs on Server1. You need to ensure that members of a security group named Docker Administrators can administer Docker. What should you do?
A. Run the sc privs command.
B. Modify the Security settings of Docker.exe.
C. Run the Set-Service cmdlet.
D. Run the sc config command.
The preferred method for configuring the Docker Engine on Windows is using a configuration file. The configuration file can be found at 'C:\ProgramData\Docker\config\daemon.json'. If this file does not already exist, it can be created.
NEW QUESTION 300
Solution: You sign in to VM1. You run the Get-NetAdapterSriov cmdlet.
The Get-NetAdapterSriov cmdlet gets the Single-Root I/O Virtualization (SR-IOV) properties of network adapters that support SR-IOV.
NEW QUESTION 301
You have a server named Server1 that runs Windows Server 2016. Server1 is configured as a VPN server. Server1 is configured to allow domain users to establish VPN connections from 06:00 to 18:00, every day of the week. You need to ensure that domain users can establish VPN connections only between Monday and Friday.
Solution: From Active Directory Users and Computers, you modify the Dial-in properties of the user accounts.
NEW QUESTION 302
