All YES/NO Exam 414 Questions
Discussion in '70-414' started by mecbeau, Dec 12, 2015.
  1. mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    NOTE:
    Remember YES/NO are 12++ Question in MIX & also In every case study there are 2 each YES/NO Question.
    Key to Success is Master them before you Hit The Exam ...!!!!
    NOTE: Once you answer this question, you will NOT be able to return to it.
    You manage a Hyper-V 2012 cluster by using System Center Virtual Machine Manager 2012 SP1.
    You need to ensure high availability for business-critical virtual machines (VMs) that host business-critical SQL Server databases.
    Solution: You configure preferred and possible owners for each business-critical VM.
    Solution: You set the memory-weight threshold value to High for each business-critical VM.
    B. No ( i choose yes in exam )
    Solution: You create an availability set and place each business-critical VM in the set.
    You manage a Hyper-V 2012 cluster by using system center Virtual machine manager 2012 SP1.
    You need to ensure high availability for business-critical virtual machines (VMs) that host business-critical SQL server databases.
    Solutions: You create a custom placement rule and apply it to all business-critical VMs.
    B. NO
    You need to recommend a monitoring solution to ensure that an administrator can review the availability information of Service1.
    Solution: From Virtual Machine Manager (VMM), you modify the properties of the service template.
    Solution: From Configuration Manager, you create a Collection and a Desired Configuration Management baseline.
    Solution: From Operations Manager, you create a Distributed Application and a Monitor Override.
    Solution: From Operations Manager, you create a Distributed Application and a Service Level Tracking object.
    You plan to allow users to run internal applications from outside the company's network.
    You have a Windows Server 2012 R2 that has the Active Directory Federation Services (AD FS) role installed.
    You must secure on-premises resources by using multi-factor authentication (MFA).
    You need to design a solution to enforce different access levels for users with personal Windows 8.1 or iOS 8 devices.
    Solution:You migrate the AD FS server to Microsoft Azure and connect it to the internal Active Directory instance on the network.
    Then, you use the Workplace Join process to configure access for personal devices to the on-premises resources.
    Solution: You install a local instance of the MFA Server.
    You connect the instance to the Microsoft Azure MFA provider and then you use Microsoft Intune to manage personal devices.
    Solution: You install a local instance of MFA Server and connect it your Microsoft Azure MFA provider.
    An organization uses an Active Directory Rights Management Services (AD RMS) cluster named RMS1 to protect content for a project. You uninstall AD RMS when the project is complete. You need to ensure that the protected content is still available after AD RMS is uninstalled. Solution: You run the following command from an administrative command prompt: Chiper /a/d/s: <…. >
    A. NO
    An organization uses an Active Directory Rights Management Services (AD RMS) cluster named RMS1 to protect content for a project . You uninstall AD RMS when the project is complete.
    A. NO
    Solution: You run the following Windows PowerShell command:
    Set-ItemProperty -Path <protected content>:\ -Name IsDecommissioned -Value $true EnableDecommission
    Solution: You add the backup service account to the SuperUsers group and back up the protected content.
    Then, you restore the content to a file server and apply the required NTFS permissions to the files.
    Your network contains an Active Directory domain named contoso.com. The network has an Active Directory Certificate Services (AD CS) infrastructure. You need to issue a certificate to users to meet the following requirements:
    Solution: You create a copy of the Basic EFS certificate template, and then you modify the validity period of the copy.
    Solution: From the properties of the Basic EFS template, you assign the Allow -Enroll permission to the Authenticated Users group.
    A. NO
    Solution: You create a copy of the User certificate template, and then you modify the extensions of the copy.
    Solution: From the properties of the User certificate template, you assign the Allow -Enroll permission to the Authenticated Users group.
    A. NO
  2. mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    QUESTION
    You manage a Hyper-V 2012 cluster by using System Center Virtual Machine Manager 2012 SP1. You need to ensure high availability for business-critical virtual machines (VMs) that host business-critical SQL Server databases.
    No
    QUESTION
    B. No (But i answer Yes)
    QUESTION
    QUESTION
    NO
    QUESTION
    Your network contains an Active Directory domain named contoso.com. The domain contains a Microsoft System Center 2012 infrastructure.
    You deploy a service named Service1 by using a service template.
    Service1 contains two virtual machines. The virtual machines are configured as shown in the following table.
    No
    QUESTION
    The domain contains a Microsoft System Center 2012 infrastructure. You deploy a service named Service1 by using a service template.
    QUESTION
    The domain contains a Microsoft System Center 2012 infrastructure. You deploy a service named Service1 by using a service template. Service1 contains two virtual machines. The virtual machines are configured as shown in the following table.
    QUESTION
    Your network contains an Active Directory domain named contoso.com. The domain contains a Microsoft System Center 2012 infrastructure. You deploy a service named Service1 by using a service template. Service1 contains two virtual machines. The virtual machines are configured as shown in the following table. You need to recommend a monitoring solution to ensure that an administrator can review the availability information of Service1.
    QUESTION
    You plan to allow users to run internal applications from outside the company’s network. You have a Windows Server 2012 R2 that has the Active Directory Federation Services (AD FS) role installed. You must secure on-premises resources by using multi-factor authentication (MFA).
    Solution: You migrate the AD FS server to Microsoft Azure and connect it to the internal Active Directory instance on the network. Then, you use the Workplace Join process to configure access for personal devices to the on-premises resources.
    QUESTION
    Solution: You install a local instance of the MFA Server. You connect the instance to the Microsoft Azure MFA provider and then you use Microsoft Intune to manage personal devices.
    QUESTION
    You plan to allow users to run internal applications from outside the company’s network. You have a Windows Server 2012 R2 that has the Active Directory Federation Services (AD FS) role installed. You must secure on-premises resources by using multi-factor authentication (MFA). You need to design a solution to enforce different access levels for users with personal Windows 8.1 or iOS 8 devices.
    Solution: You install a local instance of MFA Server and connect it your Microsoft Azure MFA provider. Then, you use the Workplace Join process to configure access for personal devices to the on-premises resources.
    Yes
    QUESTION
    cipher/a/d/s:
    QUESTION
    Solution: You add the backup service account to the SuperUsers group and back up the protected content. Then, you restore the content to a file server and apply the required NTFS permissions to the files.
    QUESTION
    Set-ItemProperty -Path <protected content>:\ -Name IsDecommissioned -Value $true -EnableDecommission
    B. YES
    QUESTION
    Your network contains five servers that run Windows Server 2012 R2. You install the Hyper-V server role on the servers. You create an external virtual network switch on each server. You plan to deploy five virtual machines to each Hyper-V server. Each virtual machine will have a virtual network adapter that is connected to the external virtual network switch and that has a VLAN identifier of 1. Each virtual machine will run Windows Server 2012 R2. All of the virtual machines will run the identical web application.
    You plan to install the Network Load Balancing (NLB) feature on each virtual machine and join each virtual machine to an NLB cluster. The cluster will be configured to use unicast only.
    You need to ensure that the NLB feature can distribute connections across all of the virtual machines.
    Solution: From the properties of each virtual machine, you enable MAC address spoofing for the existing virtual network adapter.
    QUESTION
    You plan to install the Network Load Balancing (NLB) feature on each virtual machine and join each virtual machine to an NLB cluster. The cluster will be configured to use unicast only. You need to ensure that the NLB feature can distribute connections across all of the virtual machines.
    Solution: On each Hyper-V server, you create a new external virtual network switch. From the properties of each virtual machine, you add a second virtual network adapter and connect the new virtual network adapters to the new external virtual network switches.
  3. mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    QUESTION
    Your network contains five servers that run Windows Server 2012 R2. You install the Hyper-V server role on the servers. You create an external virtual network switch on each server. You plan to deploy five virtual machines to each Hyper-V server. Each virtual machine will have a virtual network adapter that is connected to the external virtual network switch and that has a VLAN identifier of 1. Each virtual machine will run Windows Server 2012 R2. All of the virtual machines will run the identical web application. You plan to install the Network Load Balancing (NLB) feature on each virtual machine and join each virtual machine to an NLB cluster. The cluster will be configured to use unicast only.
    Solution: On each Hyper-V server, you create a new private virtual network switch. From the properties of each virtual machine, you add a second virtual network adapter and connect the new virtual network adapters to the new private virtual network switches.
    No
    QUESTION
    Solution: From the properties of each virtual machine, you add a second virtual network adapter. You connect the new virtual network adapters to the external virtual network switch and configure the new virtual network adapters to use a VLAN identifier of 2.
    No
    QUESTION
    Yes
    QUESTION
    No
    QUESTION
    QUESTION
    No
  4. mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    Q
    You need to automatically restart the appropriate web service on DETCRL01 and CHICRL01 if the web service is stopped.
    Solution: You create a recovery task in SCOM and configure it to start the World Wide Web publishing service.
    Yes
    Q
    Solution: You create a diagnostic task in SCOM and configure it to start the Server service.
    No
    Solution: you Create a Windows Events monitor SCOM and configure it to monitor even related to the http.sys Service.
    NO
  5. Queenb
    Queenb Member
    Dec 14, 2015
    22
    thank , it make life easier to have all y/n questions in one file.
    Hope all stands true
  6. dapenguin
    dapenguin Member
    Oct 30, 2015
    120
    looks like all answers here match new file, thanks mecbeau...u r da best
  7. ashfoo
    ashfoo Member
    Nov 23, 2015
    thx mecbeau is easy for me to study
  8. techeart
    techeart Member
    Nov 6, 2015
    80
    what about this? is it confirmed?
    QUESTION 15
    Solution: You enable the decommissioning service by using the AD RMS management console.
    You grant all users the Read & Execute permission to the decommission pipeline.
  9. dapenguin
    dapenguin Member
    Oct 30, 2015
    120
    QUESTION 15
    think so, thats what im going with
  • lucasg4
    lucasg4 Member
    Dec 16, 2015
    Another question
    QUESTION 23
    installed.
    Solution:You install a local instance of MFA Server.
    You connect the instance to the Microsoft Azure MFA provider, and then run the following Windows PowerShell cmdlet. Enable-AdfsDeviceRegistration
  • rwolf82
    rwolf82 Member
    Nov 19, 2015
    B. NO
    For all the above questions the answer is NO, but in the VCE dump (70-414 CC Th3Puck) there is a question that shows the following information:
    ATT: This question is one of a series of similar questions where only the 'Solution" changes. The answer to this one appears to always be "No" unless the Solution involves the following:
    - Adding the VM's to an Availability set
    - Modifying the preferred and possible owners
    - Configuring Custom Placement rules
    In all the above questions they talk about the three items mentioned above, shouldn't the answer be YES to all these questions then?
    #11 rwolf82, Jan 19, 2016
  • openbpart
    openbpart Member
    Dec 22, 2015
    68
    you are right in this file there are mistake and some answer are wrong which needs to check and verify .
    or better to build a new cc file if possible Mr. Admin :(
  • cupertinosucks
    Dec 22, 2015
    49
    So it looks like in the business-critical SQL server databases question series, all of the answers are No.
    Configure preferred and possible owner = No
    Custom placement rule = No
    Availability set = No
    Memory-Weight = No
    And all the MFA related questions are all Yes, except the one with enable-adfsdeviceregistration which is a No.
    Seems easy enough! Hope I don't get screwed with new questions lol
  • coodyscoops
    coodyscoops Member
    Dec 15, 2015
    132
    cupertinosucks, your name is freaking epic... :D
  • rwolf82
    rwolf82 Member
    Nov 19, 2015
    Memory-Weight = No
    In my opinion all the answers for the first three items should be YES, but in the dump the answer says NO.
    Configure preferred and possible owner = YES
    Custom placement rule = YES
    Availability set = YES
  • cupertinosucks
    Dec 22, 2015
    49
    thanks! I had this since I was a kid for 15years or so lol. I'm still debating if I should buy this domain name... but it wouldn't be very professional.. haha
  • openbpart
    openbpart Member
    Dec 22, 2015
    68
    Q You need to automatically restart the appropriate web service on DETCRL01 and CHICRL01 if the web service is stopped.
    Solution: you create a basic service monitor in SCOM and configure it to monitor the World Wide Web publishing service.
    A. YES
  • papoea
    papoea Member
    Apr 19, 2016
    Yes
    Note: As best practice using unicast, use 1 outward facing NIC (connected to external network switch) and 1 inward facing NIC (attached to private network switch) for internal communications between NLB nodes. Otherwise you have to spoof the MAC on the VM.
    Reference: CBT Nuggets 70-412 -Configuring NLB
  • stickerbush1970
    Jan 13, 2016
    125
    On the Yes/No questions, I went through and answered No on all, then I found the ones that were the Yes questions, about 9, and memorized those with key words. I had the Yes/No file memorized in about 20 mins.
  • phool4fool
    phool4fool Member
    Sep 5, 2016
    44
    In the Answer description, there is also mentioned that you select Yes when these are asked in solution but the answer in VCE is still NO
    anybody verify it please
