Azure Solutions 70-535 Dumps with VCE and PDF (2018 Version)
Discussion in 'Microsoft Certifications General' started by Warqaa Huriyyah Haik, Dec 29, 2017.
  1. Warqaa Huriyyah Haik
    Aug 24, 2016
    30
    ATTENTION PLEASE!!! THE 70-535 EXAM UPDATED RECENTLY (Dec/2018) WITH MANY NEW QUESTIONS!!!
    And, PassLeader has updated its 70-535 dumps recently, all new questions available now!!!
    426Q NEW Version!!!
    You can get the newest PassLeader 70-535 exam questions in the
    #88 of this topic!!!
    ATTENTION PLEASE!!! THE 70-535 EXAM UPDATED RECENTLY (Sep/2018) WITH MANY NEW QUESTIONS!!!
    You can get the newest PassLeader 70-535 exam questions in the #78 of this topic!!!
    ATTENTION PLEASE!!! THE 70-535 EXAM UPDATED RECENTLY (June/2018) WITH MANY NEW QUESTIONS!!!
    You can get the newest PassLeader 70-535 exam questions in the #67 of this topic!!!
    ATTENTION PLEASE!!! The 70-534 exam has been retired on 30/Nov/2017, the new exam is 70-535 now!!!
    And, PassLeader has published its new 70-535 dumps, new questions have been adde and wrong answers have been corrected now!!!
    Here you can get the newest PassLeader 70-535 dumps in VCE and PDF:
    Good Luck! Happy New Year!!!
    p.s.
    That PassLeader 70-535 dumps updated on 19/Jan/2018, now is 284q Version!!!
    Here you can get the latest 2018 version PassLeader 70-535 dumps:
    Or, reading the #3 of this post, good luck!!!
    Link of #3 -->
    #1 Warqaa Huriyyah Haik, Dec 29, 2017
  2. Laura Oakley
    Laura Oakley Member
    Aug 24, 2016
    67
    The new 2018 version (Jan/2018 Updated) 70-535 dumps now are available, here are part of 70-535 exam questions (FYI):
    NEW QUESTION 231
    You create an Ubuntu Linux virtual machine (VM) by using the Azure Portal. You do not specify a password when you create the VM. You need to connect to the terminal of the VM.
    Solution: You connect to the public IP address of the VM by using Secure Shell (SSH) and specify your private key.
    NEW QUESTION 232
    Solution: You use the Connect button on the Overview blade for the VM.
    NEW QUESTION 233
    You use Azure Resource Manager (ARM) templates to deploy resources. You need to ensure that storage resources defined in templates cannot be deleted.
    Solution: You define the following JSON in the temp:
    “resource”: [
    “name”: “[concat(parameters(‘lockedResource’), ‘/Microsoft.Authorization/myLock’)]”,
    “type”: “Microsoft.Authorzation/locks”,
    “apiVersion”: “2015-01-01”,
    “properties”: {
    “level”: “ReadOnly”
    NEW QUESTION 234
    Note: This question is part of a series of questions that present the same scenario. Each questions in the series contains a unique solution that might meet the stated goals. Some questions sets might have more than one correct solution, while others might not have a correct solution. After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
    Solution: You connect to the public IP address of the VM by using Secure Shell (SSH) and specify your public key.
    NEW QUESTION 235
    Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet the stated goals. Some question sets might have more than one correct solution, while others might not have a correct solution. After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
    You manage an Azure SQL Database. The database has weekly backups that are stored in an Azure Recovery Services vault. You create an Azure Recovery Services vault and download the backup agent installation file. You need to complete the installation of the backup agent. What should you do first?
    A. Configure network throttling.
    B. Set the storage replication option.
    C. Download the vault credentials file.
    D. Select the data to back up.
    NEW QUESTION 236
    You manage an Azure SQL Database. The database has weekly backups that are stored in an Azure Recovery Services vault. A company deploys Microsoft SQL Server on an Azure Standard_DS3 virtual machine (VM). You need to modify the disk caching policy. Which Azure PowerShell cmdlet should you run?
    A. Set-AzureRmVmOperatingSystem
    B. Set-AzureRmVmDataDisk
    C. Update-Disk
    D. Update-AzureDisk
    NEW QUESTION 237
    A company uses Azure to host virtual machines (VMS) and web apps. You have an app service named App1 that uses the Basic app service tier. You need to ensure that diagnostic data for App1 is permanently stored.
    Solution: You specify a storage account in the Diagnostics.xml file.
    NEW QUESTION 238
    You specify the storage account that you want to use in the ServiceConfiguration.cscfg. You use Azure to virtual machines (VMS) and web apps. You have an app service named App1 that uses the Basic app service tier. You need to ensure that diagnostic data for App1 is permanently stored.
    Solution: You scale the app service to the Standard tier.
    Answer: ......
    Get the newest PassLeader 70-535 VCE dumps here:
    Download more NEW PassLeader 70-535 PDF dumps from Google Drive here:
    Read the newest PassLeader 70-535 exam questions from this Blog:
  3. Warqaa Huriyyah Haik
    Aug 24, 2016
    30
    NEW QUESTION 265
    A company runs multiple line-of-business applications in a Kubernetes container cluster. Source code for the applications resides in a version control repository which is a part of a continuous integration/continuous deployment (CI/CD) solution. You must be able to upgrade containerized applications without downtime after all tests and reviews have completed successfully. You need to recommend steps to go from source code to updated applications so that they can be automated in the CI/CD solution. Which four actions should you recommend be performed in sequence? (To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.)
    [​IMG]
    [​IMG]
    NEW QUESTION 266
    You are designing a solution that consist of Internet of Things (IoT) devices and external streams of data. You need to provide near real-time functionality. Which technologies should you implement? (To answer, configure the appropriate options in the dialog box in the answer area. NOTE: Each correct selection is worth one point.)
    [​IMG]
    [​IMG]
    NEW QUESTION 267
    You are managing the automation of your company's Azure resources. You need to choose the appropriate tool to automate specific use cases. Which tool should you choose for each use case? (To answer, select the appropriate tool from each list in the answer area. NOTE: Each correct selection is worth one point.)
    [​IMG]
    [​IMG]
    NEW QUESTION 268
    You are designing a solution that ingests, transforms, and stores streams of data from Internet of Things (IoT) devices. The solution has the following requirements:
    - Business users must be able to discover, understand, consume, and contribute to data creation.
    - Transform data by using Spark.
    - Data analysis must be performed by using a hub-and-spoke business intelligence model.
    You need to choose the appropriate products for the solution. Which technologies should you recommend? (To answer, drag the appropriate technologies to the correct requirements. Each technology may be used once, more than one, or not at all. You may need to drag the split bar between panes or scroll to view content. NOTE: Each correct selection is worth one point.)
    [​IMG]
    [​IMG]
    NEW QUESTION 269
    You are designing an Azure storage solution for a company. The company has the following storage requirements:
    - An app named App1 uses data analytics on stored data.
    - App1 must store data on a hierarchical file system that uses Azure Active Directory (Azure AD) access control lists.
    - An app named App2 must have access to object-based storage.
    - The storage must support role-based access control and use shared access signature keys.
    You need to design the storage solution. Which storage solution should you use for each app? (To answer, drag the appropriate storage solutions to the correct apps. Each storage solution may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content. NOTE: Each correct selection is worth one point.)
    [​IMG]
    [​IMG]
    NEW QUESTION 270
    Case Study 9 - Trey Research Inc. (NEW QUESTION 271 - NEW QUESTION 276)
    Background
    You are an architect for Trey Research Inc., a software as a service (SaaS) company. The company is developing a new product named Tailspin for consumer and small business financial monitoring. The product will be offered as an API to banks and financial instructions. Banks and financial institutions will integrate Tailspin into their own online banking offerings. All employees of Trey Research are members of an Active Directory Domain Services (AD DS) group named TREY.
    More ......
    NEW QUESTION 271
    You need to ensure that authentication requirements are met. What should you do?
    A. Enable multi-factor authentication.
    B. Enable Azure AD Identity Protection.
    C. Require users to authenticate by using Windows Hello for Business.
    D. Require users to authenticate by using certificate-based authentication.
    NEW QUESTION 272
    You are developing the application security review document. You need to ensure that application data security requirements are met. What should you verify?
    A. Azure SQL connections use an account that does have administrative access.
    B. Connection strings use encryption and not trust server certificates.
    C. Azure SQL connections use Azure Key Vault certificates for TLS.
    D. Connection strings are not stored in application code.
    NEW QUESTION 273
    You need to design the multi-tenant model for storing application and customer data. Which pattern should you recommend?
    A. Shared database-single
    B. Database-per-tenant with elastic pools
    C. Database-per-tenant without elastic pools
    D. Shared database-shared
    NEW QUESTION 274
    Case Study 10 - Tailspin Toys (NEW QUESTION 277 - NEW QUESTION 284)
    Background
    Security
    The security team at Tailspin Toys plans to eliminate legacy authentication methods that are in use, including NTLM and Windows pass-through authentication. Tailspin Toys needs to share resources with several business partners. You are investigating options to securely share corporate data. Tailspin Toys has several databases that contain personally identifiable information (PII). User access PII only through the Tailspin Toys e-commerce website. You secure apps by using on-premises Active Directory Domain Services (AD DS) credentials or Microsoft SQL Server logins.
    More ......
    NEW QUESTION 277
    You need to recommend a solution architecture for the Tailspin Toys e-commerce website for app tier, data tier, and user authentication.
    Solution:
    - Web site based on Azure App Service.
    - App data stored in Azure SQL Database.
    - Authentication provided through Azure AD business-to-consumer (B2C).
    - Solution deployed to multiple Azure regional datacenters.
    - Load balancing with Azure Traffic Manager.
    NEW QUESTION 278
    Solution:
    - Web App hosted in Azure virtual machines.
    - App data stored in Azure SQL Server 2016, hosted in Azure virtual machines.
    NEW QUESTION 279
    #3 Warqaa Huriyyah Haik, Jan 19, 2018
    Alexey Henko and Rowerland like this.
  4. Rowerland
    Rowerland Member
    May 9, 2017
    Thanks for sharing!
    You done a great job!
    That PassLeader 70-535 dumps are indeed the newest!
    Thanks!
  5. Alexey Henko
    Alexey Henko Member
    Oct 21, 2017
    21
    Anyone kindly upload that NEW PassLeader 70-535 dumps???
    We need that new PassLeader 70-535 dumps URGENTLY!!!
    VCE or PDF file, thanks in advance!!!
  6. AjayThakur
    AjayThakur Member
    Jan 24, 2018
    Congrats!
    I just cleared the 70-535 exam few hours ago, passed with a good score!
    I mainly learned that NEW PassLeader 70-535 dumps updated recently, all new questions including Drag and Drop and Case Studies, were from that NEW PassLeader 70-535 dumps, 100% valid for passing now.
    Good luck!!!
    p.s. Pay close attention to the new objectives of 70-535!!!
    P R A J U likes this.
  7. finbalor
    finbalor Member
    Jul 28, 2017
    95
    Students are always worried about their Microsoft because of broad syllabus contents and difficult and diverse concepts. They take it as a very difficult task to search different topics from different sites and most of the topics are even not in appropriate form. Information is to be filtered from broaden data. But now you need not to worry about this because you can simply find this full syllabus at Dumps4Download.com.
    are very suitable for this course. All the topics have been covered in it.
    danijons likes this.
  8. Emma Robbie
    Emma Robbie Member
    Jan 18, 2018
    All the Azure Updates
    that are released day-to-day, you know a lot has changed in Azure since the 70-534 exam was released. It’s not easy to pass 70-535 exam today but reading different study materials and books about architecting infrastructure, storage solutions, networking and up to date dumps are helpful to pass this exam in short time.
    . If you prepare well then you will passed with a good score of 80-90%.Best of luck.
    danijons, StevenKheel and AlinaJay like this.
  9. mh1143
    mh1143 Member
    Feb 28, 2017
    Congrats!
    Good luck!!!
    Just took the 70-535 exam a few days ago and the passleader guide is not accurate anymore. Only about 15 questions on my exam were from the passleader guide. The rest were brand new
  • arun1485
    arun1485 Member
    Jan 29, 2018
    Congrats!
    Good luck!!!
    Please share that PassLeader 70-535 dumps with me. My email id is
    I am planning to take this exam next week.
  • P R A J U
    P R A J U Member
    Feb 26, 2018
    Congrats!
    Good luck!!!
    Congrats ,Could you help me with the 70-535 ,i have done my 70-533 .You may send me the details in
  • arun1485
    arun1485 Member
    Jan 29, 2018
    Hi Praju,
    Could you please help me with 70-533 dumps and your experience with using these dumps.
    You may send the details on
    Thanks you in advance!
    Regards,
    Arun
  • arun1485
    arun1485 Member
    Jan 29, 2018
    Congrats!
    Good luck!!!
    Congrats!
    Could you please help with 70-535 dumps as I am planning to appear for this exam soon?
    You may send me details on
    Thanks in advance!
    Regards,
    Arun
  • Nothemba
    Nothemba Member
    Feb 27, 2018
    Congrats!
    Just passed the 70-535 exam yesterday (Feb/26/2018)!!!
    All questions are available in that premium PassLeader 70-535 dumps, still valid for passing.
    Good luck.
  • sagarcloudguru
    Jan 30, 2018
    Congrats!
    Thanks in advance!
    Regards,
    Arun[/Q
    Congrats!
    Good luck!!!
    Hi Ajay,
    Can you share the dumps on
  • Karthipkk87
    Karthipkk87 Member
    Feb 28, 2018
    Congrats! Could you please help 70-535 exam dumps.I am planning to appear for this exam soon?
    Please send 70-535 valid exam dumps
  • Karthipkk87
    Karthipkk87 Member
    Feb 28, 2018
    Congrats!
    Good luck!!!
  • Karthipkk87
    Karthipkk87 Member
    Feb 28, 2018
  • ReneMoeller
    ReneMoeller Member
    Mar 6, 2018
    Thanks for sharing the latest 70-535 exam questions!
    I confirmed that the questions in PassLeader 70-535 dumps are valid.
    Yesterday (5/Mar/2018) I passed the 70-535 exam.
  • Karthipkk87
    Karthipkk87 Member
    Feb 28, 2018
    Please share 70-533 dumps to mail ID.
    Please help
    #20 Karthipkk87, Mar 6, 2018
