Azure Solutions 70-535 Dumps with VCE and PDF (2018 Version)
BobThomas
Thanks for sharing the latest 70-535 dumps!
I just passed the 70-535 exam few hours ago with a good score.
All questions were from that forbiden 70-535 dumps, stable and still valid enough for passing!
Good luck, all!!!
vinoth
Good luck, all!!!
Hi Bob,
Could you please share the dump if you are okay to share. Everyone here are sharing forbiden or other website links only which are again payable, not the exact dumps. Could you if don't mind, it will be helpful for many people. Thanks
PranB1
Good luck, all!!!
Congratulations Bob! Would like to talk to regarding this exam. Would you please share your email address? or just send Test email to my emailid - [email protected]?
PranB1
Good luck, all!!!
Hello Bob,
Would you please share the dumps? my emailid is [email protected]
Dannykoh
Good luck, all!!!
@BobThomas
Congratulations!!!
Please kindly upload that premium forbiden 70-535 dumps!!!
riyan
@BobThomas
Congratulations!!!
Please kindly upload that premium forbiden 70-535 dumps!!! please. i failed today not sure which dumps i am using.
MichaelBort
Please share that forbiden 70-535 dumps with us.
Thanks all in advance!!!
aacevedo38
Please share that forbiden 70-535 dumps with me. My email id is [email protected]
I am planning to take this exam in 2 weeks.
riyan
@MalicGeedy
Share some 10 sample questions from the dump which are not present in other dumps. i will buy based on that. i already took my exam and failed using old dumps. if you can share sample i will validate and buy immediately
PranB1
Can someone give correct answers of these questions with an explanation?
1. A company hosts virtual machines (VMs) in an on-premises datacenter and in Azure. The on-premises and Azure-based VMs communicate using ExpressRoute. The company wants to be able to continue regular operations if the ExpressRoute connection fails. Failover connections must use the internet and must not require Multiprotocol Label Switching (MPLS) support.
You need to recommend a solution that provides continued operations. What should you recommend.
A. Set up a second ExpressRoute Connection.
B. Set up a VPN connection
C. Increase the bandwidth for the on-premises internet connection.
D. increase the bandwidth of the existing ExpressRoute connection.
2. You have business services that run on an on-premises mainframe server.
You must provide an intermediary configuration to support existing business services and Azure. The
business services cannot be rewritten. The business services are not exposed externally.
You need to recommend an approach for accessing the business services. What should you recommend?
A. Connect to the on-premises server by using a custom service in Azure.
B. Expose the business services to the Azure Service Bus by using a custom service that uses relay binding.
C. Expose the business services externally.
D. Move all business service functionality to Azure.
3. You are designing an Azure web application that includes many static content files.
The application is accessed from locations all over the world by using a custom domain name.
You need to recommend an approach for providing access to the static content with the least amount of latency.
A. Place the static content in Azure Table storage.
B. Configure a CNAME DNS record for the Azure Content Delivery Network (CDN) domain.
C. Place the static content in Azure Blob.
D. Configure a custom domain name that is an alias for the Azure Storage domain.
4. You administer a virtual machine (VM) that is deployed to Azure. You configure a rule to generate an alert
when the average availability of a web service on your VM drops below 95 percent for 15 minutes. The
development team schedules a one-hour maintenance period. You have the following requirements:
* No alerts are created during the maintenance period.
* Alerts can be restored when the maintenance is complete.
You want to achieve this goal by using the least amount of administrative effort. What should you do from the Management Portal?
A. Select and disable the rule from the Dashboard page of the virtual machine.
B. Select and delete the rule from the Configure page of the virtual machine.
C. Select and disable the rule from the Monitor page of the virtual machine.
D. Select and disable the rule on the Configure page of the virtual machine.
5. You manage an Azure subscription with virtual machines (VMs) that are running in Standard mode. You
need to reduce the storage costs associated with the VMs. What should you do?
A. Locate and remove orphaned disks
B. Add the VMs to an affinity group.
C. Change VMs to the Basic tier.
D. Delete the VHD container
MalicGeedy
I never thought that I would be able to pass the Microsoft 70-535 certification exam in few simple steps.one of my senior advise me to prepare this exam with BrainDumpsKey provided up to date 70-535 question answer pdf file. I really liked the way it worked for me, all I do just practice exam questions and pass my exam.
