Azure Solutions 70-535 Dumps with VCE and PDF (2018 Version)
Warqaa Huriyyah Haik
The new 2018 version (June/2018 Updated) 70-535 dumps now are available, here are part of 70-535 exam questions (FYI):
NEW Case Study 11 - Trey Research D (Question 297 – Question 314)
Background
You are a software architect for Trey Research Inc., a Software-as-a-Service (SaaS) company that provides text analysis services. Trey Research Inc. has a service that scans text documents and analyzes the content to determine content similarities. These similarities are referred to as categories, and indicate groupings on authorship, opinions, and group affiliation.
NEW QUESTION 322
You are designing an Azure solution. The solution must meet the following requirements:
- Distribute traffic to different pools of dedicated virtual machines (VMs) based on rules.
- Provide SSL offloading capabilities.
You need to recommend a solution to distribute network traffic. Which technology should you recommend?
A. Azure Load Balancer
B. Server-level Firewall Rules
C. Azure Application Gateway
D. Azure Traffic Manager
NEW QUESTION 323
You are developing a hybrid solution for a video editing company. Videos are currently edited on-premises and stored in Server Message Block (SMB) protocol share. Due to legal regulations, videos must be stored on-premises. You must distribute videos by using Azure Media Services. You need to recommend a storage solution for the videos. What should you recommend?
A. Azure StorSimple
B. Azure Blob storage
C. Azure Table storage
D. Azure Cosmos DB
NEW QUESTION 324
You manage a large number of on-premises applications. You plan to migrate the applications to Azure. You need to implement Azure Storage for each type of data that the applications use. For each type of data, which storage mechanism should you use? (To answer, drag the appropriate storage mechanism to the correct type of data. Each storage mechanism may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/06/forbiden-70-535-dumps-3241.jpg
http://www.microsoftbraindumps.com/wp-content/uploads/2018/06/forbiden-70-535-dumps-3242.jpg
NEW QUESTION 325
You are designing a solution that uses Azure Storage. The solution will store the following information:
http://www.microsoftbraindumps.com/wp-content/uploads/2018/06/forbiden-70-535-dumps-3251.jpg
You need to recommend storage technologies for the solution. What should you recommend? (To answer, select the appropriate options in the answer area.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/06/forbiden-70-535-dumps-3252.jpg
http://www.microsoftbraindumps.com/wp-content/uploads/2018/06/forbiden-70-535-dumps-3253.jpg
NEW QUESTION 326
A company plans to use Azure Cosmos DB as the document store for an application. You need to estimate the request units required for the application. Which variable should you include when calculating the estimate?
A. item size
B. consistency level
C. cache size
D. number of regions
When using data consistency levels of Strong or Bounded Staleness, additional units are consumed to read items.
NEW QUESTION 327
NEW QUESTION 332
You are planning to create a virtual network that has a scale set that contains six virtual machines (VMs). A monitoring solution on a different network will need access to the VMs inside the scale set. You need to define public access to the VMs.
Solution: Implement an Azure Load Balancer.
Public IP addresses are necessary because they provide the load balanced entry point for the virtual machines in the scale set. The public IP address will route traffic to the appropriate virtual machines in the scale set.
NEW QUESTION 333
Solution: Design a scale set to automatically assign public IP addresses to all VMs.
All VMs do not need public IP addresses. Public IP addresses are necessary because they provide the load balanced entry point for the virtual machines in the scale set. The public IP address will route traffic to the appropriate virtual machines in the scale set.
NEW QUESTION 334
Solution: Deploy a standalone VM that has a public IP address to the virtual network.
NEW QUESTION 335
NEW QUESTION 343
You manage an Azure environment for a company. The environment has over 25,000 licensed users and 100 mission-critical applications. You need to recommend a solution that provides advanced endpoint threat detection and remediation strategies. What should you recommend?
A. Azure Active Directory Federation Services (AD FS)
B. Microsoft Identity Manager
C. Azure Active Directory (Azure AD) Identity Protection
D. Azure Active Directory (Azure AD) Connect
E. Azure Active Directory (Azure AD) authentication
Azure Active Directory Identity Protection is a feature of the Azure AD Premium P2 edition that enables you to: ......
NEW QUESTION 344
You manage a solution in Azure. You must collect usage data including MAC addresses from all devices on the network. You need to recommend a monitoring solution. What should you recommend?
A. Activity Log Analytics
B. Azure Wire Data
C. Azure Application Gateway Analytics
D. Azure Network Security Group Analytics
E. Network Performance Monitor
Wire data is consolidated network and performance data collected from Windows-connected and Linux-connected computers with the OMS agent, including those monitored by Operations Manager in your environment. Network data is combined with your other log data to help you correlate data. When you search using wire data, you can filter and group data to view information about the top agents and top protocols. Or you can view when certain computers (IP addresses/MAC addresses) communicated with each other, for how long, and how much data was sent.
NEW QUESTION 345
NEW QUESTION 352
You are responsible for mobile app development for a company. The company develops apps on Windows Mobile, iOS, and Android. You plan to integrate push notifications into every app. You need to be able to send users alerts from a backend server. Which two options can you use to achieve this goal? (Each correct answer presents a complete solution. Choose two.)
A. Azure Mobile App Service
B. Azure SQL Database
C. Azure Notification Hubs
D. Azure Web App
E. A virtual machine
A: With the release of Social Cloud we got to use many different features of Windows Azure Mobile Services including Push Notifications. As a long time developer of mobile apps, leveraging push notifications is a great way to stay connected and engaged with your customers and Azure Mobile Services makes it really easy to implement without having the headache of deploying server infrastructure.
C: The Mobile Apps feature of Azure App Service uses Azure Notification Hubs to send pushes, so you will be configuring a notification hub for your mobile app.
NEW QUESTION 353
You are designing two Azure HDInsight clusters for a bank. The clusters will process millions of transactions each day. The storage solution for the clusters must meet the following requirements:
- Ensure optimum performance of processing transactions.
- Store transactions in a hierarchical file system.
- Use the minimal number of storage accounts.
A. Create only an Azure Blob storage account for both clusters.
B. Create only an Azure Data Lake Store account for both clusters.
C. Create separate Azure Data Lake Store accounts and Azure Blob storage accounts for each cluster.
D. Create one Azure Data Lake Store account and one Azure Blob storage account.
Use the accounts for both clusters.
Azure Data Lake uses an Hierarchical file system.
Incorrect:
Not A: Azure Blob storage uses an object store with flat namespace.
NEW QUESTION 354
Get the newest forbiden 70-535 VCE dumps here: https://www.forbiden.com/70-535.html
Download more NEW forbiden 70-535 PDF dumps from Google Drive here:
https://drive.google.com/open?id=1Tqc3nKkqLq3RuEdZ4qV-ddYyN5SwbSNB
Read the newest forbiden 70-535 exam questions from this Blog:
http://www.microsoftbraindumps.com/?s=70-535
AlinaJay
Recently pass MCSA exam, I don't really remember who advised me this website and this 70-535 pdf file, but really thankful. Before actual exam because 70-535 practice questions offers you to appear in in the computerized test that is similar to the actual test .This rehearsal is the best way to evaluate your preparation. I think this is the best way to prepare your exam in short time. Best of luck.
Steve Pike
Background
NEW QUESTION 322
NEW QUESTION 323
A. Azure StorSimple
D. Azure Cosmos DB
NEW QUESTION 324
NEW QUESTION 325
NEW QUESTION 326
A. item size
C. cache size
NEW QUESTION 327
NEW QUESTION 332
NEW QUESTION 333
NEW QUESTION 334
NEW QUESTION 335
NEW QUESTION 343
NEW QUESTION 344
B. Azure Wire Data
NEW QUESTION 345
NEW QUESTION 352
D. Azure Web App
NEW QUESTION 353
Incorrect:
NEW QUESTION 354
GREAT!!!
Would you like to upload that full version forbiden 70-535 dumps with 354q (new version)???
Scot Wills
I passed the 70-535 exam recently and I was very thankful to braindumpspdf. I got 92% marks. I prepare this exam from latest 70-535 practice exam questions. This rehearsal is the best way to evaluate your preparation. I am sure you will pass your exam on the first attempt. Best of luck.
AdelmoRichard
I think I have spent my money at the right place. I feel like I have an asset now after using 70-535 dumps because I have gained so much knowledge and information. I must say my confidence is boosted manifolds. I have never seen such teaching method before. It makes you creative and makes you think about studying course with creativity.
phu
I passed 70-535 yesterday with 57q.
Very very difficult @@
All dump invalid, about 20% exactly
The new 2018 version (Sep/2018 Updated) 70-535 dumps now are available, here are part of 70-535 exam questions (FYI):
NEW QUESTION 367
You are developing a web application that provides streaming video to users. You configure the application to use continuous integration and deployment. The app must be highly available and provide a continuous streaming experience for users. You need to recommend a solution that allows the application to store data in a geographical location that is closest to the user. What should you recommend?
A. Azure Content Delivery Network (CDN)
B. Azure App Service Isolated
C. Azure Redis Cache
D. Azure App Service Web Apps
A content delivery network (CDN) is a distributed network of servers that can efficiently deliver web content to users. CDNs store cached content on edge servers in point-of-presence (POP) locations that are close to end users, to minimize latency.
NEW QUESTION 368
You are designing a security solution for a company's Azure Active Directory (Azure AD). The company currently uses Azure AD Premium for all employees. Contractors will periodically access the corporate network based on demand. You must ensure that all employees and contractors are required to log on by using two-factor authentication. The solution must minimize costs. You need to recommend a solution. What should you recommend?
A. Use the Multi-Factor Authentication provider in Azure and configure the usage model for each authentication type.
B. Purchase Azure Multi-Factor Authentication licenses for the employees and the contractors.
C. Use the Multi-Factor Authentication provider in Azure and configure the usage model for each enabled user.
D. Purchase Azure Multi-Factor Authentication licenses for the contractors only.
If you have Azure AD Premium or a license bundle that includes Azure AD Premium, you already have Azure MFA. Your organization doesn't need anything additional to extend the two-step verification capability to all users. You only need to assign a license to a user, and then you can turn on MFA.
NEW QUESTION 369
You are designing a solution for a company to deploy software for testing and production. The solutions must meet the following requirements:
-- Applications must be deployed to several different environments and must run without installation of dependences.
-- Existing published applications must be ported to the new solution. Application developers must be given flexibility when architecting their code.
You need to recommend a solution for hosting applications. What should you select?
A. Azure Batch
B. Azure worker role
C. Azure Functions
D. Azure Container Service
Container service is a pre-configured environment for scalable deployment and management of containerized workloads. Azure Container Service (ACS) provides a way to simplify the creation, configuration, and management of a cluster of virtual machines that are preconfigured to run containerized applications.
NEW QUESTION 370
NEW QUESTION 380
Your company has an on-premises Active Directory Domain Services (AD DS) domain and an established Azure Active Directory (Azure AD) environment. Your company would like users to be automatically signed in when they are on their corporate desktops that are connected to the corporate network. You need to enable single sign-on (SSO) for company users.
Solution: Install and configure an Azure AD Connect server to use pass-through authentication and select the "Enable single sign-on" option.
Single sign on (SSO) can be enabled via Azure AD Connect.
NEW QUESTION 381
You are migrating an on-premises application to Azure. One component of the application is a legacy Windows native executable that performs image processing. The image processing application must run every hour. During times that the image processing application is not running, it should not be consuming any Azure compute resources. You need to ensure that the image processing application runs correctly every hour.
Solution: Use Azure Scheduler to run the image processing application runs correctly every hour.
It is better to run the legacy application in an VM.
NEW QUESTION 382
Solution: Create an Azure WebJob that runs the image processing application every hour.
Azure Web Job is focusing on doing background job for Azure Website. It's working daemon web server farm in cloud. Instead use the Azure Scheduler.
NEW QUESTION 383
Solution: F Batch application that runs the image processing application every hour.
Use a VM to run the legacy application as a batch job. The F-Series VMs are an excellent choice for gaming servers, web servers and batch processing.
NEW QUESTION 384
You are designing an Internet-of-Things (IoT) solution for a company. The project will deploy thousands of sensors that measure noise levels in the company's manufacturing plants. The design must meet the following requirements:
-- Data from the IoT devices must be monitored in near real-time. If the noise levels exceed certain thresholds, a notification must be sent alerting the appropriate people.
-- Different people may be notified based on the severity of the threshold that has been exceeded.
-- A mobile app will be distributed to those who receive notifications.
-- The solution must allow configuration changes to be pushed to the IoT devices.
You need to design the flow of data from the IoT devices to the sending of the notification. Which five services should you use to process the data in sequence from input to output? (To answer, move the appropriate service from the list of services to the answer area and arrange them in the correct order.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-535-Exam-Dumps-3841.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-535-Exam-Dumps-3842.png
Steps 2-3:
-- Create a Service Bus namespace, using the Azure portal.
-- Create a Service Bus topic, using the Azure portal.
-- Create a Service Bus subscription to that topic, using the Azure portal.
NEW QUESTION 385
A company runs multiple Windows virtual machines (VMs) in Azure. The IT operations departments wants to apply the same policies as they have for on-premises VMs to the VMs running in Azure, including domain administrator permissions and schema extensions. You need to recommend a solution for the hybrid scenario that minimizes the amount of maintenance required. What should you recommend? (To answer, select the appropriate options in the answer area.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-535-Exam-Dumps-3851.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-535-Exam-Dumps-3852.png
Box 1: AD DS is used to authenticate user, computer, application, or other identities that are included in a security domain. It can be hosted on-premises, but if your application is hosted partly on-premises and partly in Azure, it may be more efficient to replicate this functionality in Azure. This can reduce the latency caused by sending authentication and local authorization requests from the cloud back to AD DS running on-premises.
Box 2: The Azure Relay service facilitates hybrid applications by enabling you to securely expose services that reside within a corporate enterprise network to the public cloud, without having to open a firewall connection, or require intrusive changes to a corporate network infrastructure.
NEW QUESTION 386
Greek Smi
I have heard about a lot of websites which offer dumps and study material but I was not satisfied with their services. BraindumpsPDF.com offers a wide range of benefits like regular updates , beautiful presentation and 24/7 support. I passed my 70-535 exam after purchasing 70-535 dumps from them. This website is superb.
Alexandrajhon
Hello guys, I pass 70-535 exam today with 94% and I’m very happy. Friends I prepare exam from 70-535 dumps PDF that are available on www.pass4surekey.com. Here is Complete information is available on every certification material and also 70-535 question & answers. There is less chances to fail in exam so it’s a suggestion to review the Microsoft 70-535 dumps PDF. If you want good result just follow this link
https://www.pass4surekey.com/exam/70-535.html
That same questions are in following.
You need to select Azure components to meet site performance and availability requirements for the Tailspin Toys e-commerce site.
Which components should you use?
A. Azure Batch and Azure Traffic Manager
B. Virtual Machine Scale Set and Azure Load Balancer
C. Azure App Service and Azure Traffic Manager
D. Azure Virtual Machines and Azure Load Balancer
E. Azure App Service and Azure Load Balancer
https://www.gratisexam.com/
You need to select an Azure compute provider for the Tailspin Toys Customer Analyzer app.
What should you use?
A. Virtual Machine Scale Sets (VMSS)
B. Azure Virtual Machines
C. Azure Logic Apps
D. Azure Functions
You need to select an Azure identity provider for the Tailspin Toys e-commerce website.
A. Azure AD business-to-consumer (B2C)
B. Azure AD business-to-business (B2B)
C. Microsoft account
D. Azure AD
You need to ensure that the repository runs the script when new software is released.
Which technology should you use?
A. Azure Function
B. Azure App Service Logic App
C. Azure App Service API App
D. Azure WebJob
charlotteava
RealExamCollection became the reason for this moment of happiness by helping me pass my IT exam 70-535 dumps. At some time I could not imagine to pass this IT certification but this reliable and valid study material made it possible for me. I think anybody can go through this exam by seeing help from the expert on this platform and learning from 70-535 questions and answers.
danijons
Thanks "Emma Robbie", for sharing this valid study source. Comprehensive and exam-oriented exam practice questions pdf.
The new 2018 version (Dec/2018 Updated) 70-535 dumps now are available, here are part of 70-535 exam questions (FYI):
NEW QUESTION 401
Your company has deployed several virtual machines (VMs) on-premises and to Azure. Azure Express Route has been deployed and configured for on-premises to Azure connectivity. Several VMs are exhibiting network connectivity issues. You need to analyze the network traffic to determine whether packets are being allowed or denied to the VMs.
Solution: Use Azure Network Watcher to run IP flow verify to analyze the network traffic.
NEW QUESTION 402
Solution: Create an Azure Function to run the image processing application every hour.
It is better to run the legacy application in a VM.
NEW QUESTION 403
Your company uses Azure Active Directory (Azure AD) to secure several Azure App Service Web and API applications. The applications are used by company employees and allow single sign-on (SSO). The applications must allow external users to sign-in. The external users must be managed the same way as employees and allow the external users to be added to the same employee user groups. You need to enable the external user sign-in. What should you do?
A. Install and configure an Azure AD Connect server to use password hash synchronization and select the "Enable single sign on" option.
B. Install and configure an Azure AD Connect server to use pass-through authentication and select the "Enable single sign-on" option.
C. Enable and configure Azure AD business-to-consumer (B2C) Multi-Factor Authentication.
D. Enable and configure Azure AD business-to-business (B2B) collaboration.
NEW QUESTION 404
A company runs virtual machines (VMs) in Azure. Some VMs are hosted in a virtual network in the West Central US region. Other VMs are hosted in a virtual network in the West US 2 region. Each virtual network has its own IP address range. The virtual networks are not integrated. You need to ensure that databases in the virtual networks can replicate data from one region to the other. The solution must minimize effort required. Which two actions should you recommend? (Each correct answer presents part of the solution. Choose two.)
A. Implement virtual network peering.
B. Migrate the database to Azure SQL Database.
C. Create ExpressRoute connections to each virtual network.
D. Configure database replication for the databases.
NEW QUESTION 405
You are designing a live streaming event by using Azure Media Services. The delivery of the video will use HTTP Live Streaming (HLS) to an Azure Content Delivery Network (CDN) streaming endpoint. Viewers of the content may not be a trusted party and you require the highest level of security. You must secure the media delivery by using dynamic encryption.
Solution: Use AES-128 dynamic encryption and the key delivery service to encrypt all assets with an associated encryption key and authorization policy. Configure the assert's delivery policy to deliver by using Advanced Encryption Standard (AES).
NEW QUESTION 406
A company has 100 Web servers running Windows Server on virtual machines (VMs) in Azure. All servers have IIS enabled. Each server runs a unique combination of web apps. Servers must not run unnecessary services. The servers must be checked every 30 minutes to remove any additional Windows features and correct exceptions. You need to design the solution with the least amount of effort and without downtime.
Solution: Design a solution based on VM scale sets.
Instead use Azure Automation State Configuration.
NEW QUESTION 407
Solution: Design a solution that deploys a unique Azure Resource Manager template for each VM and copy the appropriate web apps. Create the required number of VMs.
NEW QUESTION 408
Solution: Use Azure Automation DSC.
NEW QUESTION 409
Your company is developing an e-commerce Azure App Service Web App to support hundreds of restaurant locations around the world. You are designing the messaging solution architecture to support the e-commerce transactions and messages. The e-commerce application has the following features and requirements:
http://www.microsoftbraindumps.com/wp-content/uploads/2018/12/forbiden-70-535-dumps-4091.jpg
You need to design a solution for the Inventory Distribution feature. Which Azure service should you use?
A. Azure Event Hub
B. Azure Service Bus
C. Azure Event Grid
D. Azure Relay
NEW QUESTION 410
A company uses Microsoft Operations Management Suite (OMS) to manage 1,000 virtual machines (VMs) in Azure. The security officer reports that VMs often are not updated. You recommend to the company that they implement the OMS Update Management solution. You need to describe the OMS Update Management solution to the company. Which functionality does the OMS Update Management solution provide?
A. assessment of Windows and Linux updates on the VMs
B. alerts regarding VM issues
C. overview of network activity on the VMs
D. deployment of required updates to VMs
NEW QUESTION 411
You manage an application instance. The application consumes data from multiple databases. Application code references database tables using a combination of the server, database, and table name. You need to migrate the application instance to Azure. What are two possible ways to achieve this goal? (Each correct answer presents a complete solution. Choose two.)
A. SQL Server Stretch Database
B. SQL Server in an Azure virtual machine
C. SQL Managed Instance
D. Azure SQL Database
NEW QUESTION 412
You are designing a security solution for a company's web application. You need to secure the web application by using Web Application Firewall (WAF). For which three types of attacks will the solution protect? (Each correct answer presents part of the solution. Choose three.)
A. zero-day exploits
B. SQL injection
C. DOS attacks
D. cross-site scripting attacks
E. DDOS attacks
Answer: BCD
NEW QUESTION 413
Solution: Use Azure Storage Service Encryption to encrypt all assets with an encryption key and authorization policy. Configure the asset's delivery policy to deliver by using Advanced Encryption Standard (AES).
NEW QUESTION 414
A company deploys Azure Active Directory (Azure AD) Connect to synchronize identity information from their on-premises Active Directory Domain Services (AD DS) directory to their Azure AD tenant. The identity information that is synchronized includes user accounts, credential hashes for authentication (password sync), and group memberships. The company plans to deploy several Windows and Linux virtual machines (VMs) to support their applications. The VMs have the following requirements:
- Support domain join, LDAP read, LDAP bind, NTLM and Kerberos authentication, and Group Policy.
- Allow users to sign in to the domain using their corporate credentials and connect remotely to the VM by using Remote Desktop.
You need to support the VM deployment. Which service should you use?
A. Active Directory Federation Services (AS FS)
B. Azure AD Privileged Identity Management
C. Azure AD Domain Services
D. Azure AD Managed Service Identity
NEW QUESTION 415
