Case Study 4: Northwind Traders
Discussion in '70-414' started by enya, Nov 20, 2015.
  1. enya
    enya Well-Known Member
    Contributor Member
    254
    Overview
    Northwind Traders is an IT services and hosting provider.
    Northwind Traders has two main data centers in North America.
    The data centers are located in the same city.
    The data centers connect to each other by using high-bandwidth, low-latency WAN links.
    Each data center connects directly to the Internet.
    Northwind Traders also has a remote office in Asia that connects to both of the North American
    data centers by using a WAN link.
    The Asian office has 30 multipurpose servers.
    Each North American data center contains two separate network segments.
    One network segment is used to host the internal servers of Northwind Traders.
    The other network segment is used for the hosted customer environments.
    Existing Environment
    Active Directory
    The network contains an Active Directory forest named northwindtraders.com.
    The forest contains a single domain.
    All servers run Windows Server 2012 R2.
    Server Environment
    The network has the following technologies deployed:
    - Service Provider Foundation
    - Windows Azure Pack for Windows Server
    - System Center 2012 R2 Virtual Machine Manager (VMM)
    - An Active Directory Rights Management Services (AD RMS) cluster
    - An Active Directory Certificate Services (AD CS) enterprise
    certification authority (CA)
    All newly deployed servers will include the following components:
    - Dual 10-GbE Remote Direct Memory Access (RDMA)-capable network adapters
    - Dual 1-GbE network adapters
    - 128 GB of RAM
    Requirements
    Business Goals
    Northwind Traders will provide hosting services to two customers named Customer1 and
    Customer2.
    The network of each customer is configured as shown in the following table.
    infrasructure component customer 1 customer 2
    system center 2012 R2 VMM yes no
    system center 2012 R2 app controller yes no
    active directory certificate services ADCS no no
    active directory rights management services AD RMS yes yes
    Planned Changes
    Northwind Traders plans to implement the following changes:
    - Deploy System Center 2012 R2 Operations Manager.
    - Deploy Windows Server 2012 R2 iSCSI and SMB-based storage.
    - Implement Hyper-V Recovery Manager to protect virtual machines.
    - Deploy a certificate revocation list (CRL) distribution point (CDP) on
    the internal network.
    - For Customer 1, install server authentication certificates issued by
    the CA of Northwind Traders on the virtual machine in the hosting networks.
    General Requirements
    Northwind Traders identifies the following requirements:
    - Storage traffic must use dedicated adapters.
    - All storage and network traffic must be load balanced.
    - The amount of network traffic between the internal network and the
    hosting network must be minimized.
    - The publication of CRLs to CDPs must be automatic.
    - Each customer must use dedicated Hyper-V hosts.
    - Administrative effort must be minimized, whenever possible.
    - All servers and networks must be monitored by using Operations Manager.
    - Anonymous access to internal file shares from the hosting network must
    be prohibited.
    - All Hyper-V hosts must use Cluster Shared Volume (CSV) shared storage
    to host virtual machines.
    - All Hyper-V storage and network traffic must remain available if single
    network adapter fails.
    - The Hyper-V hosts connected to the SMB-based storage must be able to
    make use of the RDMA technology.
    - The number of servers and ports in the hosting environment to which the
    customer has access must be minimized.
    Customer1 Requirements
    Northwind Traders identifies the following requirements for Customer1:
    - Customer1 must use SMB-based storage exclusively.
    - Customer1 must use App Controller to manage hosted virtual machines.
    - The virtual machines of Customer1 must be recoverable if a single data
    center fails.
    - Customer1 must be able to delegate self-service roles in its hosted
    environment to its users.
    - Customer1 must be able to check for the revocation of certificates
    issued by the CA of Northwind Traders.
    - The users of Customer1 must be able to obtain use licenses for documents
    protected by the AD RMS of Northwind Traders.
    - Certificates issued to the virtual machines of Customer1 that reside on
    the hosted networks must be renewed automatically.
    Customer2 Requirements
    Northwind Traders identifies the following requirements for Customer2:
    - Customer2 must use iSCSI-based storage exclusively.
    - All of the virtual machines of Customer2 must be migrated by using a
    SAN transfer.
    - None of the metadata from the virtual machines of Customer2 must be
    stored in Windows Azure.
    - The network configuration of the Hyper-V hosts for Customer2 must be
    controlled by using logical switches.
    - The only VMM network port profiles and classifications allowed by
    Customer2 must be low-bandwidth, medium-bandwidth, or high-bandwidth.
    - The users at Northwind Traders must be able to obtain use licenses for
    documents protected by the AD RMS cluster of Customer2. Customer2 plans
    to decommission its AD RMS cluster during the next year.
  2. enya
    Contributor Member
    254
    You need to recommend a monitoring solution for Northwind Traders.
    What is the best approach to achieve the goal? More than one answer choice may achieve the
    goal. Select the BEST answer.
    A. Three Operations Manager management servers and two Operations Manager gateway
    servers
    B. One Operations Manager management server
    C. Two Operations Manager management servers and three Operations Manager gateway
    servers
    D. Five Operations Manager management servers
  3. enya
    Contributor Member
    254
    You plan to implement a solution that meets the certificate requirements of Customer1.
    You need to identify which role services must be deployed to the hosting environment.
    Which two role services should you identify? Each Answer presents part of the solution.
    A. Certification Authority Web Enrollment
    B. Online Responder
    C. Certificate Enrollment Policy Web Service
    D. Certificate Enrollment Web Service
  4. enya
    Contributor Member
    254
    You need to recommend changes to allow Customer1 to delegate permissions in its hosting
    Where should you recommend performing each task? To answer, select the appropriate location
    for each task in the answer area.
    Creating a client and a Stamp: Service Provider Foundation
    Creating a Client Administrator role: Virtual Machine Manager
    to create an application administrator (self-service user) user role : Virtual Machine Manager
    to create a mapping between the client and the Self-Service User Role : Service Provider Foundation
  5. enya
    Contributor Member
    254
    You need to recommend a solution that meets the AD RMS requirements of Customer1 and
    Customer2.
    Which actions should you recommend performing for each customer? To answer, select the
    appropriate customer for each action in the answer area.
    Configure a trusted publishing domain in the Active Directory Rights Management Services of northwind traders: Customer2
    configure a trusted user domain in the Active Directory Rights Management Services of norhtwind traders: Customer1
    modify the DNS record of the AD RMS cluster of customers: Customer2
    Allow communication to the AD-RMS licensing cluster of northwind traders: Customer1
  6. enya
    Contributor Member
    254
    You need to prepare for the migration of virtual machines across the Hyper-V hosts of Customer2.
    Which three actions should you perform in sequence? To answer, move the appropriate actions
    from the list of actions to the answer area and arrange them in the correct order.
    1-install the MPIO feature on the hyper V host
    2-from VMM console add iscsi array on the hyper V host
    3-from the VMM console add disks to the Hyper V host
  7. enya
    Contributor Member
    254
    You need to recommend a network configuration for the newly deployed Hyper-V hosts used by
    Customer1.
    On which network adapter should you recommend performing each configuration? To answer,
    select the appropriate network adapter for each configuration in the answer area.
    Creating a NIC Team : 1-GbE network adapters
    create a virtual switch and virtual network adapter: 1-GbE network adapters
    assign IP addresses to physical network adapters: 10-GbE network adapters
    assign IP addresses to virtual network adapters: 1-GbE network adapters
    #7 enya, Nov 20, 2015
  8. enya
    Contributor Member
    254
    You need to recommend which setting must be applied to the virtualization infrastructure of
    Northwind Traders to minimize the impact of multiple virtual machines starting concurrently.
    What command should you recommend running? To answer, select the appropriate options in the
    answer area.
    (Get-Cluster) .BlockCacheSize = 8192
    #8 enya, Nov 20, 2015
  9. enya
    Contributor Member
    254
    You need to prepare the required Hyper-V virtual network components for Customer2.
    Which four objects should you create and configure in sequence? To answer, move the appropriate
    objects from the list of objects to the answer area and arrange them in the correct order.
    a logical network
    a network site
    a virtual port profile
    a logical switch
    #9 enya, Nov 20, 2015
  10. enya
    Contributor Member
    254
    You need to implement a Hyper-V Recovery Manager solution in the hosting environment of
    Northwind Traders.
    Which four actions should you perform in sequence? To answer, move the appropriate actions from
    from windows azure management portal create a hyper v recovery manager vault
    from windows azure management portal upload a .cer file
    on the vmm server download and install the hyper v recovery manager provider
    from vmm console select the the synchronize cloud data with the vault option
    #10 enya, Nov 20, 2015
  11. enya
    Contributor Member
    254
    You need to recommend a configuration for the CA extensions of Northwind Traders that meets the certificate revocation requirement of Customer1.
    What should you recommend? To answer, select the appropriate prefix of the target location for the
    each extension settings in the answer area
    Publish CRLs to this location: file: //
    Include in the CDP extension of the issued certificate: http: //
    #11 enya, Nov 20, 2015
  12. Keyser_soze
    Keyser_soze Member
    Nov 24, 2015
    Great job, thanks ;)
  13. Martin138
    Martin138 Member
    Dec 1, 2015
    17
    a logical network
    a network site
    a logical switch
    Can you explain?
  • blackpinya
    blackpinya Member
    Dec 12, 2015
    21
    a logical network
    a network site
    a logical switch
    a logical network
    a network site
    an uplink port profile
    a logical switch
    The port profiles needed by customer2 are available out of the box when you install VMM.
    When you configure a logical switch, it asks for the uplink port to use.
  • dapenguin
    dapenguin Member
    Oct 30, 2015
    120
    a logical network
    a network site
    a logical switch
    confirmed? anyone?
  • techeart
    techeart Member
    Nov 6, 2015
    80
    confirmed? anyone?
    Anyone simulated this can help!
  • MarlinV
    MarlinV Member
    Nov 9, 2015
    16
    I don't have a VMM in lab so I can't confirm however latest premium exams denote the answer is
    1 - from VMM console add iscsi array on the hyper V hos
    2 - from the VMM console add disks to the Hyper V host
    3 - install the MPIO feature on the hyper V host
    also found a discussion on
    suggesting that is the answer and referencing
    where the MPIO is done last.
  • MarlinV
    MarlinV Member
    Nov 9, 2015
    16
    a logical network
    a network site
    a logical switch
    Again I don't have a VMM lab however premium test file and discussion at
    suggest the answer is
    logical network
    uplink port profile
    logical switch
    Using references to
  • techeart
    techeart Member
    Nov 6, 2015
    80
    MarlinV I am going with the same..will update!
  • sjoerdstefma
    sjoerdstefma Member
    Nov 17, 2015
    Why do we need three Operations Manager gateway servers?
