Case Study 4: Northwind Traders
Discussion in '70-414' started by enya, Nov 20, 2015.
  1. sjoerdstefma
    sjoerdstefma Member
    Nov 17, 2015
    This Answer is wrong:
    I disagree. Uplink port configuration is absolutely necessary before the creation of a logical switch. In this case, the network site is probably unnecessary as Customer 2 would have its own, unique logical network. I believe the answer to be:
    logical network
    uplink port profile
    virtual port profile
    logical switch
  2. openbpart
    openbpart Member
    Dec 22, 2015
    68
    Please read the below as explained
    It should be:– a logical network (physical networks)
    – a network site (you need to configure IP subnets, there is no DHCP for)
    – a virtual port profile(Quality of Service (QoS) settings such as minimum and maximum bandwidth settings)-> The only VMM network port profiles and classifications allowed by Customer2 must be low-bandwidth, medium-bandwidth, or high-bandwidth.
    – a logical switch -> The network configuration of the Hyper-V hosts for Customer2 must be controlled by using logical switches
  3. Dms2701
    Dms2701 Member
    Feb 21, 2016
    Please can someone explain what is correct answer for this?
    Also - why do we need 3 Ops Mgr Gateway Servers and 2 Ops Mgr Mgmt servers?
    Thanks!
  4. Dms2701
    Dms2701 Member
    Feb 21, 2016
    Thanks!
    Anyone can confirm the above?
  • MrSkiaa
    MrSkiaa Member
    Feb 16, 2016
    32
    You need to recommend a monitoring solution for Northwind Traders.
    What is the best approach to achieve the goal? More than one answer choice may achieve the
    goal. Select the BEST answer.
    A. Three Operations Manager management servers and two Operations Manager gateway
    servers
    B. One Operations Manager management server
    C. Two Operations Manager management servers and three Operations Manager gateway
    servers
    D. Five Operations Manager management servers
    I think that the best solution is:
    one management server (north america) and 3 gateway(asia,cust1,cust2)
    But it isn't a choice so I think that in the exam I will chose C only for redundancy purposes.
    can someone tell me other reasons to have 2 management server?
  • elfreako
    elfreako Member
    Apr 18, 2016
    You need to prepare the required Hyper-V virtual network components for Customer2.
    Which four objects should you create and configure in sequence? To answer, move the appropriate
    objects from the list of objects to the answer area and arrange them in the correct order.
    a logical network
    a network site
    a logical switch
    I believe this to be wrong, according to video tutorials at PluralSight it should be;
    - logical network
    - network site
    - uplink port profile
    - virtual port profile
  • MrSkiaa
    MrSkiaa Member
    Feb 16, 2016
    32
    - logical network
    - network site
    can you explain why do you use "uplonk port profile"?
  • andry79
    andry79 Member
    Jul 15, 2016
    I tested on the virtual lab and when you create a new logical network automatically you create a network site.
    I'm not sure about the 3rd answer. Virtual port profile not exist, but if the answer is Hyper-V Port Profile is ok.. otherwise is Uplink port profile
    [​IMG]
  • Juliette
    Juliette Member
    Nov 12, 2015
    servers
    servers
    Can anyone explain please why A. is not the correct answer?
    Thanks.
