Case Study A: Proseware, Inc.
Discussion in '70-246' started by metro, Jan 10, 2016.
  1. metro
    metro Well-Known Member
    Supplier Contributor Member
    228
    17
    Proseware, Inc. is a mechanical equipment manufacturer. Proseware has a research department and a manufacturing department.
    Network Infrastructure
    The network contains a single Active Directory domain named proseware.com. The domain contains 100 Hyper-V hosts that run Windows Server 2008 R2 Service Pack 1 (SP1). The Hyper-V hosts host 400 virtual machines.
    Sixty of the virtual machines have Microsoft SQL Server 2008 R2 deployed. Both the research department and the manufacturing department use the SQL Server virtual machines.
    The infrastructure contains two private clouds. One private cloud contains all of the resources used by the research department. The other private cloud contains all of the resources used by the manufacturing department.
    The following System Center 2012 components are installed on the network:
    - Orchestrator
    - Service Manager
    - Operations Manager
    - Configuration Manager
    - Data Protection Manager (DPM)
    - Virtual Machine Manager (VMM)
    All servers are backed up by using DPM. The system state of the servers is not backed up. Configuration Manager only manages client computers.
    Application Infrastructure
    Proseware uses a third-party help desk application to manage user incidents. The manufacturing department uses a Microsoft .NET application named App1 that is critical for business operations.
    The research department uses a Microsoft Server Application Virtualization (Server App-V) virtual application package named App2.
    Problem Statements
    Proseware identifies the following issues:
    - Administrators are NOT notified when a service on any server fails.
    - A virtual machine named VM2 has a service that stops and restarts often.
    - When an alert is generated in Operations Manager, a help desk user has to generate a ticket manually from the help desk application.
    - A Hyper-V host named Server1 contains a virtual machine named VM1 that is assigned a high amount of memory. Users who connect to VM1 report that it takes a long time to access the resources on VM1. You suspect that the memory assigned to VM1 spans more than one NUMA node.
    Planned Changes
    Proseware plans to implement the following changes:
    - Replace the help desk application with a new, centralized incident management solution.
    - Provide the users in the research department with an automated solution to provision virtual machines. The users will manage their respective virtual machine by using a self-service portal.
    Technical Requirements
    Proseware has identified the following technical requirements for the private cloud infrastructure:
    - The number of required virtual machine templates must be minimized.
    - A centralized automated task must restart failed services on the virtual machines.
    - Administrators must be notified by an SMS message when an alert on a manufacturing server is generated.
    - Servers that are out of compliance with the Payment Card Industry Data Security Standard (PCI DSS) must be identified.
    - Administrators must be able to perform a bare metal recovery of the Hyper-V hosts and the virtual machines by using DPM.
    - In a single operation, administrators must be able to perform a rollback of the updates applied to the servers that host App2.
    - Windows Server and SQL Server configurations that do NOT adhere to Microsoft best practices and are misconfigured must be identified.
    - All virtual machines created by self-service users must use Dynamic Memory. Administrators must be able to create virtual machines that do NOT use Dynamic Memory.
    - Administrators must be notified when an alert on a server in the research department is generated. Between 09:00 and 17:00, the administrators must be notified by email. After 17:00, the administrators must be notified by an SMS message.
    Monitoring Requirements
    App1 must be monitored to retrieve the following information:
    - The amount of time it takes to respond to user queries
    - The amount of time it takes to load a webpage
    - Debugging information
    If App2 fails to mount on a server, an administrator must receive an alert.
  2. metro
    228
    17
    You need to recommend which object must be monitored from Operations Manager to identify how the memory of VM1 is assigned.
    Which object should you include in the recommendation?
    A) Memory
    B) A Hyper-V Hypervisor Root Partition
    C) A Hyper-V Hypervisor Partition
    D) A Hyper-V VM Vid Partition
  3. metro
    228
    17
    You need to recommend an automated solution to resolve the ticket generation issue.
    What should you include in the recommendation?
    A) From Operations Manager, create diagnostic tasks.
    From Orchestrator, create runbooks that forward alerts to the help desk application.
    B) From Service Manager, create a connector.
    From Operations Manager, configure the connector.
    C) From Service Manager, create a connector.
    From Orchestrator, configure connectors.
    D) From Operations Manager, create diagnostic tasks.
  4. metro
    228
    17
    You need to ensure that the self-service users and the administrators can deploy virtual machines.
    The solution must meet the technical requirements.
    What should you create?
    A) Two VMM library shares
    B) One host profile
    C) Two application profiles
    D) One virtual machine template
  5. metro
    228
    17
    You need to recommend a solution to meet the monitoring requirements for App1.
    What should you recommend?
    A) Install the Management Pack for Operations Manager APM Web IIS 7, download and install the Internet Information Services (IIS) 7 Management Pack, and then run the .NET Application Performance Monitoring wizard.
    B) Configure a synthetic transaction, and then run the Process Monitoring wizard.
    C) Install the Management Pack for Operations Manager APM Web IIS 7, and then run the Process Monitoring wizard.
    D) Configure a synthetic transaction, and then run the .NET Application Performance Monitoring wizard.
  6. metro
    228
    17
    You need to recommend a solution to meet the technical requirements for identifying the Windows Server and SQL Server configuration issues.
    What should you include in the recommendation? (More than one answer choice may achieve the goal. Select the BEST answer.)
    A) Audit Collection Services (ACS)
    B) Windows Server Update Services (WSUS)
    C) Best Practices Analyzer (BPA)
    D) Microsoft System Center Advisor (SCA)
  7. metro
    228
    17
    You need to implement a notification solution to meet the technical requirements.
    What should you create from Operations Manager? (More than one answer choice may achieve the goal. Select the BEST answer.)
    A) Two channels and one subscriber
    B) One channel and one Subscriber
    C) One channel and two subscribers
    D) Two channels and two subscribers
  8. metro
    228
    17
    You discover that many incidents are generated for VM2.
    You need to resolve all of the incidents from Service Manager in one operation.
    What should you create? (More than one answer choice may achieve the goal. Select the BEST answer.)
    A) A configuration item
    B) An incident event workflow
    C) A dependent activity
    D) A problem
  9. metro
    228
    17
    You need to recommend changes to the System Center 2012 infrastructure to meet the technical requirements for bare metal recoveries.
    What should you include in the recommendation? (To answer, select the appropriate actions in the answer area.)
