Case Study : Humongous Insurance
metro
Supplier
Supplier
Overview
Existing Environment
Active Directory Environment
Humongous Insurance has a single-domain Active Directory forest named humongousinsurance.com.
The functional level of the forest is Windows Server 2012.
You recently provisioned an Azure Active Directory (Azure AD) tenant.
Network Infrastructure
Each office has a local data center that contains all the servers for that office. Each office has a
dedicated connection to the Internet.
Each office has several link load balancers that provide access to the servers.
Active Directory Issue
Several users in humongousinsurance.com have UPNs that contain special characters.
You suspect that some of the characters are unsupported in Azure AD.
Licensing Issue
You attempt to assign a license in Azure to several users and receive the following error message:
"Licenses not assigned. License agreement failed for one user."
You verify that the Azure subscription has the available licenses.
Requirements
Planned Changes
Humongous Insurance plans to open a new office in Paris. The Paris office will contain 1,000 users
who will be hired during the next 12 months. All the resources used by the Paris office users will be
hosted in Azure.
Planned Azure AD Infrastructure
The on-premises Active Directory domain will be synchronized to Azure AD.
All client computers in the Paris office will be joined to an Azure AD domain.
Planned Azure Networking Infrastructure
You plan to create the following networking resources in a resource group named All_Resources:
Default Azure system routes that will be the only routes used to route traffic
A virtual network named Paris-VNet that will contain two subnets named Subnet1 and Subnet2
A virtual network named ClientResources-VNet that will contain one subnet named
Client Subnet
A virtual network named AllOffices-VNet that will contain two subnets named Subnet3 and Subnet4
You plan to enable peering between Paris-VNet and AllOffices-VNet. You will enable the Use remote
gateways setting for the Paris-VNet peerings.
You plan to create a private DNS zone named humongousinsurance.local and set the registration
network to the ClientResources-VNet virtual network.
Planned Azure Computer Infrastructure
Each subnet will contain several virtual machines that will run either Windows Server 2012 R2,
Windows Server 2016, or Red Hat Linux.
Department Requirements
Humongous Insurance identifies the following requirements for the company's departments:
Web administrators will deploy Azure web apps for the marketing department. Each web app
will be added to a separate resource group. The initial configuration of the web apps will be
identical. The web administrators have permission to deploy web apps to resource groups.
During the testing phase, auditors in the finance department must be able to review all
Azure costs from the past week.
Authentication Requirements
Users in the Miami office must use Azure Active Directory Seamless Single Sign-on (Azure AD
Seamless SSO) when accessing resources in Azure.
metro
Supplier
Supplier
DRAG DROP
You need to prepare the environment to ensure that the web administrators can deploy the web apps
as quickly as possible.
Which three actions should you perform in sequence? To answer, move the appropriate actions from
the list of actions to the answer area and arrange them in the correct order.
1120
1121
metro
Supplier
Supplier
Which blade should you instruct the finance department auditors to use?
Partner information
Overview
Payment methods
Invoices
You can opt in and configure additional recipients to receive your Azure invoice in an email. This feature may not be available for certain subscriptions such as support offers, Enterprise Agreements, or Azure in Open.
?Select your subscription from the Subscriptions page. Opt-in for each subscription you own. Click Invoices then Email my invoice.
metro
Supplier
Supplier
You need to prepare the environment to meet the authentication requirements.
Which two actions should you perform? Each correct answer presents part of the solution. NOTE Each correct selection is worth one point.
Azure Active Directory (AD) Identity Protection and an Azure policy
a Recovery Services vault and a backup policy
an Azure Key Vault and an access policy
an Azure Storage account and an access policy
Answer: B,D
D: Seamless SSO works with any method of cloud authentication - Password Hash Synchronization or Pass-through Authentication, and can be enabled via Azure AD Connect.
B: You can gradually roll out Seamless SSO to your users. You start by adding the following Azure AD URL to all or selected users' Intranet zone settings by using Group Policy in Active Directory: https://autologon.microsoftazuread-sso.com Incorrect Answers:
A: Seamless SSO needs the user's device to be domain-joined, but doesn't need for the device to be Azure AD Joined.
C: Azure AD connect does not port 8080. It uses port 443.
E: Seamless SSO is not applicable to Active Directory Federation Services (ADFS).
metro
Supplier
Supplier
You need to define a custom domain name for Azure AD to support the planned infrastructure. Which domain name should you use?
Join the client computers in the Miami office to Azure AD.
Add http://autologon.microsoftazuread-sso.com to the intranet zone of each client computer in the Miami office.
Allow inbound TCP port 8080 to the domain controllers in the Miami office.
Install Azure AD Connect on a server in the Miami office and enable Pass-through Authentication E. Install the Active Directory Federation Services (AD FS) role on a domain controller in the Miami office.
Answer: B,D
Every Azure AD directory comes with an initial domain name in the form of domainname.onmicrosoft.com. The initial domain name cannot be changed or deleted, but you can add your corporate domain name to Azure AD as well. For example, your organization probably has other domain names used to do business and users who sign in using your corporate domain name. Adding custom domain names to Azure AD allows you to assign user names in the directory that are familiar to your users, such as ‘[email protected].’ instead of '[email protected] name.onmicrosoft.com'. Scenario:
Network Infrastructure: Each office has a local data center that contains all the servers for that office. Each office has a dedicated connection to the Internet.
Humongous Insurance has a single-domain Active Directory forest named humongousinsurance.com Planned Azure AD Infrastructure: The on-premises Active Directory domain will be synchronized to Azure AD.
References: https://docs.microsoft.com/en-us/azure/active-directory/fundamentals/add-customdomain
metro
Supplier
Supplier
invoices
partner information
cost analysis
External services
metro
Supplier
Supplier
ad.humongousinsurance.com
humongousinsurance.onmicrosoft.com
