Cisco 400-201 Exam- An Easy Guide
Discussion in 'General Certification' started by Gabriel357, Nov 8, 2018.
  1. Gabriel357
    Gabriel357 Member
    Mar 9, 2018
    128
    24
    We provide the best study material for passing Cisco 400-201 exam. Complex concepts are very well explained and all knowledge can be grabbed and understood easily. All you have to do is purchase 400-201 exam dumps from us . We offer it in a very reliable price. Please follow the link here
  2. cillemong
    cillemong Member
    Nov 29, 2018
    129
    Dumps4certs is success leading source if you want to get success in Cisco 400-201exam. Dumps4certs famous worldwide just because of 400-201Dumps pdf. Dumps4certs IT certified professionals are well skilled and they update each question of every exam on regular basis. Dumps4certs 400-201questions and answers created by the Cisco certified professors provide you with the experience of taking the real test. Dumps4certs take everything is to make suitability for candidates on their road to Cisco 400-201exam.There are 100% real chance that you would qualify Cisco 400-201exam in a very easy way. Every aspect of this Cisco 400-201exam will be covered with Cisco 400-201exam dumps. All those Cisco 400-201questions that will be asked from you in your real exam can be found at here
    A service provider is implementing Ethernet solutions for clients that are not being provisioned within the MPLS core network. Which solution allows the Service Provider to complete Ethernet circuit provisioning in this scenario?
    A. L2TPv3
    B. VPLS
    C. AToM
    D. PPPoE
    Which are the two purposes of the MPLS label value 1? (Choose two.)
    A. it is used for MPLS OAM packets.
    B. it indicates an implicit null label.
    C. it is used for VPNv6 packets.
    D. it is used to carry the QoS value in the label stack.
    E. it indicates an explicit null label.
    F. it indicates a router alert label.
    Correct Answer: CF
    Which are the three benefits of using the Yang model? (Choose three.)
    A. Reduce lab footprint
    B. Improve access to resources
    C. Support interoperability that provides a standard way to model management data
    D. Support simplified network management applications
    E. Provide a scale virtual lab environment
    F. Support programmatic interfaces
    Correct Answer: CDF
    Which Cisco IOS XR Virtualization technology provides full isolation between virtualized routing instances for extra control plane resources?
    A. HVR
    B. SVR
    C. SDR
    D. DRP
