Cisco CCNP 300-101 Exam Dumps 2018
Discussion in 'General Certification' started by deenjhon, Jul 11, 2018.
  1. deenjhon
    deenjhon Member
    Mar 26, 2018
    439
    139
    Now time cover all syllabus is not easy to learn you must need a valuable 300-101 dumps pdf including actual quality of Cisco 300-101 question answers. I found only Pass4surekey who make their name in market by providing quality 300-101 dumps. I share my 300-101 dumps pdf experience with you, I get 93% score in this exam i have no time to learn all topics i just learn this 300-101 dumps pdf file. I consult you this study material for your exam.
  2. Alexia Aurora
    Alexia Aurora Member
    May 16, 2018
    For Preparation of CCNP Routing and Switching Certification Exam i recommend you to prepare 300-101 Practice Exam Questions from Testcollection. Because i passed my Cisco CCNP 300-101 Exam in first attempt with the help of these
    . It was the reward of my practice through 300-101 Real Exam Questions that i succeeded, they helped me a lot.
    Zoe Tylor likes this.
  3. JimmyKong
    JimmyKong Member
    Jun 14, 2018
    238
    More New Braindump2go Cisco 300-101 Real Exam Questions:
    QUESTION 183
    An engineer is asked to monitor the availability of the next-hop IP address of 172.16.201.25 every 3 seconds using an ICMP echo packet via an ICMP echo probe.
    Which two commands accomplish this task? (Choose two.)
    A. router(config-ip-sla)#icmp-echo 172.16.201.25 source-interface FastEthernet 0/0
    B. router(config-ip-sla-echo)#timeout 3
    C. router(config-ip-sla)#icmp-jitter 172.16.201.25 interval 100
    D. router(config-ip-sla-echo)#frequency 3
    E. router(config-ip-sla)#udp-echo 172.16.201.25 source-port 23
    F. router(config-ip-sla-echo)#threshold 3
    QUESTION 184
    What command can you enter to configure an enable password that uses an encrypted password
    from another configuration?
    A. enable secret $abc%!e.Cd34$!ao0
    B. enable secret 7 Sabc%!e.Cd34$!ao0
    C. enable secret 0 Sabc%U*.Cd34$!ao0
    D. enable secret 5 $abc%!e.Cd34$!ao0
    E. enable secret 15 $abc%ie.Cd34$!ao0
    F. enable secret 6 $abc%!e.Cd34$!ao0
    QUESTION 185
    A network engineer receives reports about poor voice quality issues at a remote site.
    The network engineer does a packet capture and sees out-of-order packets being delivered.
    Which option can cause the VOIP quality to suffer?
    A. traffic over backup redundant links
    B. misconfigured voice vlan
    C. speed duplex link issues
    D. load balancing over redundant links
    In traditional packet forwarding systems, using different paths have varying latencies that cause out of order packets,
    eventually resulting in far lower performance for the network application. Also , if some packets are process switched quickly by the routing engine of the router while others are interrupt switched (which takes more time)
    then it could result in out of order packets. The other options would cause packet drops or latency, but not out of order packets.
    QUESTION 186
    What is the administrative distance for EBGP?
    A. 200
    B. 30
    C. 70
    D. 20
    QUESTION 187
    Considering the IPv6 address independence requirements, which process do you avoid when you use NPTv6 for translation?
    A. rewriting of higher layer information
    B. checksum verification
    C. ipv6 duplication and conservation
    D. IPSEC AH header modification
    The IPv6-to-IPv6 Network Prefix Translation (NPTv6) serves as a useful mechanism for implementing address independence in an IPv6 environment. A major benefit associated with NPTv6 is the fact that it avoids the requirement for an NPTv6 Translator to rewrite the transport layer headers which reduces the load on network devices
    QUESTION 188
    What is the optimal location from which to execute a debug command that produces an excessive
    amount of information?
    A. Vty lines
    B. SNMP commands
    C. A console port
    D. An AUX port
    associated-signaling-cas/10374-debug.html
    QUESTION 189
    A network engineer is configuring the router for NetFlow data exporting.
    What is required in order
    for NDE to begin exporting data?
    A. Source
    B. Flow mask
    C. Destination
    D. Interface type
    E. Traffic type
    F. NetFlow version
    NetFlow Multiple Export Destinations--To configure redundant NDE data streams, which improves the probability of receiving complete NetFlow data, you can enter the ip flow-export destination command twice and configure a different destination IP address in each command. Configuring two destinations increases the RP CPU utilization, as you are exporting the data records twice.
    QUESTION 190
    Refer to the exhibit. Router 1 cannot ping router 2 via the Frame Relay between them.
    Which two statements describe the problems? (Chooses two.)
    A. Encapsulation is mismatched.
    B. Frame Relay map is configured.
    C. DLCI is active.
    D. DLCI is inactive or deleted.
    E. An access list is needed to allow ping
    Frame Relay: Cannot ping Remote Router :
    1-Encapsulation mismatch has occurred.
    2-DLCI is inactive or has been deleted.
    3-DLCI is assigned to the wrong subinterface.
    4-An access list was misconfigured.
    5-The frame-relay map command is missing.
    6-No broadcast keyword is found in frame-relay map statements.
    QUESTION 191
    At which layer does Cisco Express Forwarding use adjacency tables to populate addressing
    information?
    A. Layer4
    B. Layer 2
    C. Layer 1
    D. Layer 3
    Adjacency table - Nodes in the network are said to be adjacent if they can reach each other with a single hop across a link layer. In addition to the FIB, CEF uses adjacency tables to prepend Layer 2 addressing information. The adjacency table maintains Layer 2 next-hop addresses for all FIB entries
    QUESTION 192
    A network engineer wants to ensure an optimal end-to-end delay bandwidth product. The delay is
    less than 64 KB. Which TCP feature ensures steady state throughput?
    A. Window scaling
    B. Network buffers
    C. Round-trip timers
    D. TCP acknowledgments
    options can be carried in a TCP header. Those relevant to TCP performance include Window-scale option : This option is intended to address the issue of the maximum window size in the face of paths that exhibit a high-delay bandwidth product. This option allows the window size advertisement to be right-shifted by the amount specified (in binary arithmetic, a right-shift corresponds to a multiplication by
    2). Without this option, the maximum window size that can be advertised is 65,535 bytes (the maximum value obtainable in a 16-bit field). The limit of TCP transfer speed is effectively one window size in transit between the sender and the receiver. For high-speed, long-delay networks, this performance limitation is a significant factor, because it limits the transfer rate to at most 65,535 bytes per round-trip interval, regardless of available network capacity. Use of the window-scale option allows the TCP sender to effectively adapt to high-band-width, high-delay network paths, by allowing more data to be held in flight.
    The maximum window size with this option
    ipj-archive/article09186a00800c8417.html
    QUESTION 193
    A network administrator creates a static route that points directly to a multi-access interface, instead of the next-hop IP address. The administrator notices that Cisco Express Forwarding ARP requests are being sent to all destinations. Which issue might this configuration create?
    A. Low bandwidth usage
    B. High memory usage
    C. Cisco Express Forwarding routing loop
    D. High bandwidth usage
    E. IP route interference
    1.|2018 Latest 300-101 Exam Dumps (PDF & VCE) 626Q&As Download:
    2.|2018 Latest 300-101 Exam Questions & Answers Download:
  4. markalan037
    markalan037 Member
    Sep 5, 2018
    1,130
    376
    Thanks deenjhon for sharing this valid study material. I only pass due to your shared practice material in your post. Thanks once again God bless you.
  • bairstrowjhon
    bairstrowjhon Member
    Sep 24, 2018
    377
    148
    Thank so much"deenjhon " for the real dumps pdf.
  • steve1050
    steve1050 Member
    Feb 13, 2018
    118
    My best wishes are for all who are going to appear in Cisco 300-101 exam and I suggest them to take help from Cisco 300-101 braindumps to bring the best possible result. I took help from this study material and aced my certification with high grades. Cisco
    material is an amazing service done by Cisco 300-101.
