DanielAcker
The new CompTIA Linux+ XK0-004 dumps (Nov/2019 Updated) now are available, here are part of XK0-004 exam questions (FYI):
A systems administrator wants to deploy several applications to the same server quickly. Each application should be abstracted from the host with its own dependencies and libraries and utilize a minimal footprint. Which of the following would be BEST in this scenario?
A. Virtual machines
B. Type 2 hypervisor
C. Chroot jails
D. Containers
A Linux administrator wants to fetch a Git repository from a remote Git server. Which of the following is the BEST command to perform this task?
A. git checkout
B. git clone
C. git merge
D. git config
Which of the following will provide a list of all flash, external, internal, and SSD drives?
A. lspci
B. lsmod
C. lsblk
D. lsusb
Which of the following information is stored within the BIOS? (Choose two.)
A. Boot device order.
B. Linux kernel version.
C. Timezone.
D. Hardware configuration.
E. The system's hostname.
Which of the following is a difference between YAML and JSON?
A. Users can comment in YAML but not in JSON.
B. JSON only curly brackets, while YAML only uses square brackets.
C. JSON is used in web development, while YAML is used solely in back-end systems.
D. YAML has been deprecated for JSON.
Which of the following is the purpose of the vmlinux file on a Linux system?
A. To prevent a Linux kernel panic.
B. To start a Linux virtual machine.
C. To provide the executable kernel for the system.
D. To enable resource access to the network.
Which of the following commands would show the default printer on a Linux system?
A. lpr
B. lpq
C. lpstat
D. lspci
Which of the following is the device file name for the second partition on the only SCSI drive?
A. /dev/hda1
B. /dev/sda2
C. /dev/sd0a2
D. /dev/sd1p2
Which of the following would be the BEST solution for a systems administrator to access the graphical user environment of a Linux machine remotely?
A. VNC
B. KDE
C. X11
D. RPC
Which of the following can be used to boot a DVD from a remote device to initialize a Linux system setup on bare metal hardware as if it is a local DVD?
A. UEFI
B. PXE
C. NFS
D. GRUB
A Linux administrator needs to switch from text mode to GUI. Which of the following runlevels will start the GUI by default?
A. Runlevel 3
B. Runlevel 4
C. Runlevel 5
D. Runlevel 6
Which of the following BEST describes the purpose of the X11 system?
A. X11 provides graphical display capabilities
B. X11 provides command line capabilities
C. X11 provides networking capabilities
D. X11 provides telephony capabilities.
NEW QUESTION 14
Which run levels should never be declared as the default run level when using SysV init? (Choose two.)
A. 0
B. 1
C. 3
D. 5
E. 6
NEW QUESTION 15
A junior administrator needs to unload an older video kernel module. Which of the following commands would BEST accomplish this task?
A. modprobe
B. insmod
C. rmmod
D. chmod
NEW QUESTION 16
Download more NEW Pass Leader XK0-004 PDF dumps from Google Drive here:
Read the newest Pass Leader XK0-004 exam questions from this Blog:
