corrected questions
Discussion in '70-410 Exam files' started by ciscozel, Dec 1, 2015.
  1. ciscozel
    ciscozel Supplier
    Supplier Member
    85
    Which two configurations should you identify?
    Your network contains an Active Directory forest named contoso.com. All domain controllers currently run
    Windows Server 2008 R2.
    You plan to install a new domain controller named DC4 that runs Windows Server 2012 R2.
    The new domain controller will have the following configurations:
    Schema master
    Global catalog server
    DNS Server server role
    Active Directory Certificate Services server role
    You need to identify which configurations cannot befulfilled by using the Active Directory
    Domain Services Configuration Wizard.
    Which two configurations should you identify? (Eachcorrect answer presents part of the solution. Choose two.)
    A.
    Enable the global catalog server.
    B.
    Transfer the schema master.
    C.
    Install the Active Directory Certificate Servicesrole.
    D.
    Install the DNS Server role.
    BA
    in the exam the only require on answers
    AD Installation Wizard will automatically install DNS and allows for the option to set it as a global catalog server.
    ADCS and schema must be done separately.
    which is A
