Deploying Citrix XenDesctop 7.6 Solutions 1Y0-301
Discussion in 'App and Desktop Virtualization' started by Mouratov, Aug 11, 2016.
  1. Herbie
    Herbie Member
    Jan 12, 2016
    Did this exam this week, and passed! used the file from Joeke to test my skills, also corrected a few wrong answers (which I think where wrong) , and did a lot of testing with the product, in a home lab, and our production environment.
    11 D
    71 B,D High availability
    78 D
    you can better build a lab, it's not that hard, and it's well documented on the internet.
    Joeke likes this.
  2. nlefier
    nlefier Member
    Sep 5, 2016
    24
    passed today with 88% , easy sims and easy questions
    very easy and i builed my own lab it's not that hard you only need 32 gb ram or at least 16 gb ram and a decent cpu
    know pvs and mcs and roles in studio
    Joeke and KYUKIRO like this.
  3. Herbie
    Herbie Member
    Jan 12, 2016
    congrats nlefier!
  4. Brahm
    Brahm Member
    Dec 3, 2016
    In the PVS simulator where I set up the password of the new server to be changed every 7 days. In the exam I do not have access to GPO
  5. KYUKIRO
    KYUKIRO Member
    Apr 14, 2016
    11 D
    78 D
    According this site's below here you have to import the certifcate into the Trusted Personal.
    I checked on my lab I had also imported into the Trusted Personal, so which one is correct?
  • KYUKIRO
    KYUKIRO Member
    Apr 14, 2016
    congrats, well done :)
  • nlefier
    nlefier Member
    Sep 5, 2016
    24
    in "citrix xendesktop 7 cookbook" from packt publishing
    in chapter 2 -> "trusted people\registry"
  • Joeke
    Joeke Member
    Jan 11, 2016
    188
    46
    Congrats nlefier! :)
    . I think you still have a lot to learn.
    In the server properties (in the PVS console) you can set the amount of days when the password needs to be reset.
    nlefier likes this.
  • nlefier
    nlefier Member
    Sep 5, 2016
    24
    in the pvs console -> Create Device
    in the target device properties -> fill in the name of the device
    In the TAB "GENERAL"
    type : production
    boot from : Vdisk
    MAC : MAC Adres given by the sims
    Port : ehm standaard? or given by the sim
    In the TAB "VDISK"
    Select the Vdisk given the sim
    enter and OK.
    The the next step is to Create a Machine account :
    Active Directory -> Create Machine Account
    Select the Domain and THE OU
    and enable AD machine account passwor management
    in TAB "OPTIONS"
    Automatich computer account password updates "7 Days"
  • nlefier
    nlefier Member
    Sep 5, 2016
    24
    Thank you
    i had 7 sims
    2 MCS - 1 with personal vdisk (already default in the sim)and 1 with a random desktop each time they log on (Both Very simple)
    2 Creating Administrator Roles in Studio - 1 very simple | and 1 roles for director
    2 PVS - 1 for creating machine account and automatic password
    1 for storefront the hardest one , Create a external Store
    with 4 controllers to add
    communication with the controllers should take place over port 8080 using http (and not https...)
    configure remote acces through netscaler (NO VPN Tunnel)
    and domain authentication (trusted domains only)
    Joeke likes this.
  • Brahm
    Brahm Member
    Dec 3, 2016
    In the MCS sim when I run the MCS create wizard I do not know where to configure the network0 device.
    any ideas?
  • KYUKIRO
    KYUKIRO Member
    Apr 14, 2016
    any ideas?
    Yes,
    you have to add second NIC on the VM on your lab, then you will be able to choice a NIC .
    See below.
    [​IMG][​IMG]
    Joeke likes this.
  • Brahm
    Brahm Member
    Dec 3, 2016
    Good Morning,
    Today I took the exam and I did not pass it, 65%. The simulations are the same discussed here but I have not approved, how can I send you the simulators? by mail....
    On the other hand, are the answers of the tests correct?
    Thk
  • Sergio Varea
    Sergio Varea Member
    Jan 11, 2017
    Good, I'm new here and I have a question with the StoreFront SIM.
    Do you have to leave this authentication?
  • Joeke
    Joeke Member
    Jan 11, 2016
    188
    46
    , No, I believe you had to deactivate Username and Password and activate Domain Pass-Through.
    (correct me if i'm wrong... anyone.... :) )
  • Brahm
    Brahm Member
    Dec 3, 2016
    I think the 3: user name and password - domain pass.thorough and pass - through from netscaler gateway must be enabled
  • Joeke
    Joeke Member
    Jan 11, 2016
    188
    46
    This is the Scenario from the PDF File:
    Scenario: A Citrix Engineer at CCH needs to create a StoreFront store. The new store must support
    authentication and must be accessible through NetScaler Gateway. Users should be allowed to access resources
    from the store by logging in with their usernames and passwords or through pass-through authentication from
    NetScaler Gateway.
    All Active Directory users should be able to access the store from remote locations outside
    of the corporate network. The secure access plug-in will NOT be used in this environment. VPN tunnel should
    be disabled
    The way I see it, your screenshot is the right one Sergio.
    - Username and Password
    - Pass-Through from NetScaler
  • Brahm
    Brahm Member
    Dec 3, 2016
    Thank you very much for the information.
    In the same sim would you have to configure "Trusted domain any" ?. I did the exam a week ago and did not have access to any trusted .....
  • Brahm
    Brahm Member
    Dec 3, 2016
    In the Role Sim ... how do I provide the permissions: "Perform any tasks within Citrix Director"?
    A greeting.
  • Sergio Varea
    Sergio Varea Member
    Jan 11, 2017
    You have to check this option.
    Joeke likes this.
