Discussion regarding WDS Question
Discussion in '70-411' started by JohnnyT, May 16, 2018 at 2:35 AM.
  1. JohnnyT
    JohnnyT Member
    May 1, 2018
    You have a server named Server4 that runs Windows Server 2012 R2. Server4 has the Windows Deployment
    Services server role installed.
    Server4 is configured as shown in the exhibit. (Click the Exhibit button.)
    To answer, complete each statement according to the information presented in the exhibit. Each correct
    selection is worth one point.
    The dumps I see have part a = BootImage1, BootImage2, and BootImage3
    I agree as x64 clients will see both x86 and x64 boot images however x86 clients will only see x86 boot images.
    I disagree with the suggested answer for part b = BootImage2
    I have found the default boot image is determined by first priority, then filename. Therefore can't really determine correct answer. I have found once you select boot image and get to the OS image selection, it will only show architecture appropriate images (e.g. x64 client will not be presented with x86 OS image if present in WDS.
    I look forward to any input/discussion.
