Exam 70-486: Developing ASP.NET MVC Web Applications
Discussion in 'Microsoft Developers Certifications' started by victoriagoze, Sep 4, 2018.
Tags:
  1. victoriagoze
    victoriagoze Member
    Jul 27, 2018
    134
    Are you preparing for your Microsoft 70-486 exam?It is highly recommended that you prepare your Microsoft real 70-486 exam by Passcert, which is created according to the real Microsoft certification 70-486 test question. Passcert is one of the best sources that provide you 70-486 online exam training same like the training institutes. Our highly certified professional staff works hard to make the Microsoft Visual Studio 70-486 study guide according to the latest updates.
    We absolutely protect the interests of consumers.
    provided by Passcert are very practical, and they are absolutely right for you. We 70-486 make you have a financial windfall.Passcert is website that 70-486 help a lot of IT people realize their dreams. If you have a IT dream then quickly click of Passcert. It has the best Microsoft Visual Studio 70-486 study guide, which is Passcert Microsoft Visual Studio 70-486 study guide.
    You need to display the "miles" unit description after the distance in the GetLog view.
    Which line of code should you use to replace line GL21? (Each correct answer presents a complete solution. Choose all that apply.)
    A. @log.Distance miles
    B. @Htrml.DisplayFor(model => log.Distance) miles
    C. @log.Distance.ToString() @Html.TextArea("miles")
    D. @Html.DisplayFor(model => log.Distance.ToString() + " miles")
    Answer: A, B
    You need to implement the business requirements for managing customer data.
    What should you do? (Each correct answer presents part of the solution. Choose all that apply.)
    A. Add a class named Customer-Controller to the Controllers folder. Then add a method named Edit to the class.
    B. Create a new controller named Administration in the Controllers folder. Add an action named EditCustomer to the controller.
    C. Add a folder named Customer to the Views folder. Then create a view inside this folder named Edit.aspx.
    D. Create a new folder named EditCustomer to the Views folder. In the new folder, create a new file named Administration.aspx.
    Answer: A, B
    You need to implement client-side animations according to the business requirements.
    Which line of code should you use? (Each correct answer presents a complete solution. Choose all that apply.)
    A. $ ("h1: first") .animate ({ opacity: 0 });
    B. $("h1:first").fadeIn(1000);
    C. $("h1:first").animate({ opacity: 1 });
    D. $("h1:first").fadeOut(1000);
    Answer: A, D
