full 1y0-311 - wrong answers -> help
Mes
Ethan.51q is the same as others nothing new.
Any new questions other than the 85Q we know of????
LUJJ
I failed today.. I had all new questions. Example :
How does Citrix optimization script builder help to adjust OS Layer ?
It improves startup time...
It update drivers...
It configures desktops...
It automates the Windows setup...
Raj83
Hello all,
What should be the ans for
A Citrix Engineer needs to implement Workspace Environment Management (WEM) in an existing XenDesktop environment. Which three software requirements should the engineer consider before implementing WEM
A minimum of .NET framework 4.0 for the Agent Host and Administration Console
B. The Windows Server 2008 R2 or later requirement for the Administrative Console
C. A minimum of Citrix License Server version 11.14
D. WEM implementation with any version of XenApp or XenDesktop
E. The Microsoft Sync Framework 2.1 requirement on all components
Should it be ACD or ACE ?
  1. Scenario: A Citrix Engineer installed and configured two Provisioning Services servers to guarantee high availability. One of the Provisioning Services servers experienced failure and now the write cache is no longer available for the target devices. Which write cache location is currently being used in this environment?
    1. On a fileshare connected to both Provisioning Services servers
      B. On the local disk of both provisioning Services servers
      C. On a persistent disk attached to the virtual desktop
      D. In the RAM of the virtual desktop
Should it be D or B
  1. Scenario: A Citrix Engineer is managing a Provisioning Services Farm with the following specifications:
    – A single Farm with one Site, with two Provisioning Services servers deployed with 8 vCPU each, which are supporting a total of 500 target devices in production.
    -The ports and threads have been configured so that each server can stream concurrently to 250 devices each.
    -Due to an upcoming merger, 250 more target devices must be supported by the existing Provisioning Services farm.
    -The Provisioning Services servers must handle the extra capacity while aligning to Citrix leading practices for resiliency. Which step should the engineer perform to accomplish these requirements?
    1. A Isolate the Provisioning Services screaming traffic.
      B. Add two additional Provisioning Services servers to the Site.
      C. Maintain the existing configurations for the environment.
      D. Add one additional Provisioning Services server to the Site.
Should it be A or B
illwills30
SQL Server Compact 3.5 SP2 ‐ Installed on the Citrix Workspace Environment Management Infrastructure Services server, and is used to cache settings, primarily for use in offline mode. Additionally, the SQL Server Compact component can be installed on any (WEM) Agent Host to allow the Agent to cache settings and run when in offline mode. Microsoft Sync Framework 2.1 ‐ Is required for all Citrix Workspace Environment Management components. SQL Server 2008 R2 (or later) ‐ Used as the primary store for (WEM) persistent data. Citrix License Server ‐ (WEM) requires a minimum of Citrix License Server version 11.14. Citrix XenApp and XenDesktop ‐ A currently supported version of XenApp or XenDesktop. .NET Framework ‐ Required for all components. If the correct version is not used then installation will fail. The recommended versions to use are .NET 4.5.2 or 4.6.2.
Raj83
Should it be ACE
since WEM can be installed on any version for XenApp and Xendesktop.
Bhog
    1. A. On a fileshare connected to both Provisioning Services servers
Should it be D or B
I think the question is meant to be read as "considering the write cache is no longer available after the server failed, where must the write cache be running?" The answer would be B, the write cache is on the local disk of each PVS server, because the write cache of the failed server is no longer available. Any thoughts?
    • Scenario: A Citrix Engineer is managing a Provisioning Services Farm with the following specifications:
Should it be A or B
As the servers have been specifically configured with increased number of threads to support 250 devices each, the only option to support additional targets is to further increase the threads or add additional PVS servers. I don't see a reason to add more than one server, I think D is the correct answer.
asian
If anyone have the latest it will be great and thanks once again.
frio
Hi at all,
some of you found these questions in the 1y0-311 exam?
thanks
QUESTION: 1
Scenario: A Citrix Engineer needs to configure a baseline Citrix policy for a new user group in the XenApp
and XenDesktop environment. The users are connecting from branch offices over a WAN connection. The
NetScaler SD-WANs are supporting each of the WAN connections. The users are connecting to Windows
Server 2012 R2 published desktops. The primary objective of the policies is to utilize the WAN link
bandwidth as optimally as possible. Which two Citrix policy templates should the engineer use to accomplish
this scenario? (Choose two.)
A. High Server Scalability
B. Optimized for CloudBridge
C. Optimized for WAN-Legacy OS D. Optimized for WAN
E. High Server Scalability-Legacy OS
Answer: A, D
QUESTION: 2
When should a Citrix Engineer utilize the Processes White List feature of Workspace
Environment Management (WEM)?
A. If specific administrators should be provided access to specific application or program processes
B. If specific application or program processes should always be available for launch C. If specific users
should NOT be able to launch specific application or program processes
D. If specific application or program processes should NEVER be available for launching
QUESTION: 3
What is the recommended configuration for deployment different versions of Microsoft
Office?
A. Create a distinct layer for each version.
B. Install Microsoft Office in an Elastic Layer.
C. Create one image template from all layers that contain Microsoft Office.
D. Install the latest version on the OS Layer and other versions on App Layers.
QUESTION: 4
Scenario: A Citrix Engineer has implemented a multi-zone environment with the following characteristics: One Primary Zone in New York, one Satellite Zone in San Francisco and another in Singapore
-Microsoft Excel Application available in all zones
-Singapore zone configured as the App Home for Microsoft Excel
-San Francisco configured as the User Home for User1
User1 is currently located in the New York zone, and clicks the icon for Microsoft Excel in Receiver. User1
does NOT have any existing sessions in the environment.
Based on this scenario, a new session will be launched in
(Choose the correct option to
complete the sentence).
A. Singapore
B. San Francisco
C. The VDA with the lowest load index
D. New York
QUESTION: 5
Which Citrix technology can a Citrix Engineer use to optimize the CPU or bandwidth consumption of HDX
sessions?
A. App Layering
B. Insight Services
C. Provisioning Services
D. Workspace Environment Management
asian
I must it looks like this exam is very difficult to get dumps for .
asian
Thanks for the reply.
Do you perhaps have the File if possible.
asian
Can someone please tell me which is the best site to get Dumps.
I think i am going to buy it as i see that this exam Dump is difficult to get.
So does anyone know which will be the most updated to get.
Thanks all
orion2
why waste your money....
knowledge is the best currency
Torostamani
Definitely there are two set of questions. Most of the dumps that you can find online, or even purchasing ones are the same set of question (let's name it v.1). i had two failed attempt and i can say that in v.2 there maximum 5 or 6 question from v.1 and questions are really confusing. anyone who can provide with v.2 set of questions?
Torostamani
HI, did you find any dump for newer version of exam?
