full 1y0-311 - wrong answers -> help
Tomhvk
If anyone can share the new dumps, please let me know.
Jeff Mansour
Congratulations!
Just passed 1Y0-311 exam today!!!
A lot of new questions indeed, old version 1y0-311 dumps are NOT valid now.
I luckily got all new questions from forbiden 1Y0-311 dumps (updated recently)!
Thanks for sharing!
Good luck, all!
Brandon Isom
Congratulations!
Thanks for sharing!
Good luck, all!
Please kindly share that forbiden 1Y0-311 dumps with me.
Brandon Isom 1985 @ gmail com
robertdrozdz
could someone share forbiden 1Y0-311 dumps with me?
max3ds @ wp pl
testkinger1977
If anyone can share the forbiden dumps with me too, it would be much appreciated! ggd1978 @ yahoo com
Petorie
I think there are still a lot of wrong answers in the file. For example:
QUESTION 109
A Citrix Engineer plans to use versioning to update a vDisk, named win2016dev.vhdx, which
 currently located in the development Store.
What will the file name be when the engineer creates the new version of the vDisk?
A. win2016dev ?Copy.vhdx
B. win2016dev.1.avhdx
C. win2016dev. 1 vhdx
D. win2016dev.avhdx
If I follow the Citrix Documentation in this link https://docs.citrix.com/en-us/provisioning/current-release/architecture/infrastructure-components.html the correct answer should be B. Or do I oversee something here?
testkinger1977
Going through old questions. I've got one that I think is wrong:
What is the recommended configuration for deployment different versions of Microsoft Office?
A. Create a distinct layer for each version.
B. Install Microsoft Office in an Elastic Layer.
C. Create one image template from all layers that contain Microsoft Office.
D. Install the latest version on the OS Layer and other versions on App Layers.
I believe the answer is A or B. Kind of leaning towards A, but I saw on some other site they were thinking B. Thoughts?
testkinger1977
QUESTION 109
D. win2016dev.avhdx
I think you're right, I would guess B as well.
john gorena
Hello all,
What should be the ans for
A Citrix Engineer needs to implement Workspace Environment Management (WEM) in an existing XenDesktop environment. Which three software requirements should the engineer consider before implementing WEM
A minimum of .NET framework 4.0 for the Agent Host and Administration Console
B. The Windows Server 2008 R2 or later requirement for the Administrative Console
C. A minimum of Citrix License Server version 11.14
D. WEM implementation with any version of XenApp or XenDesktop
E. The Microsoft Sync Framework 2.1 requirement on all components
Should it be ACD or ACE ?
  1. Scenario: A Citrix Engineer installed and configured two Provisioning Services servers to guarantee high availability. One of the Provisioning Services servers experienced failure and now the write cache is no longer available for the target devices. Which write cache location is currently being used in this environment?
    1. On a fileshare connected to both Provisioning Services servers
      B. On the local disk of both provisioning Services servers
      C. On a persistent disk attached to the virtual desktop
      D. In the RAM of the virtual desktop
Should it be D or B
    • Scenario: A Citrix Engineer is managing a Provisioning Services Farm with the following specifications:
      – A single Farm with one Site, with two Provisioning Services servers deployed with 8 vCPU each, which are supporting a total of 500 target devices in production.
      -The ports and threads have been configured so that each server can stream concurrently to 250 devices each.
      -Due to an upcoming merger, 250 more target devices must be supported by the existing Provisioning Services farm.
      -The Provisioning Services servers must handle the extra capacity while aligning to Citrix leading practices for resiliency. Which step should the engineer perform to accomplish these requirements?
      1. A Isolate the Provisioning Services screaming traffic.
        B. Add two additional Provisioning Services servers to the Site.
        C. Maintain the existing configurations for the environment.
        D. Add one additional Provisioning Services server to the Site.
Should it be A or B
A
Hello all,
Should it be D or B
Should it be A or B
Correct C, D E
Answer C
Correct Answer D
john gorena
Answer B is wrong, right is D or C.
What do you all mean ?
QUESTION: 5
Which Citrix technology can a Citrix Engineer use to optimize the CPU or bandwidth consumption of HDX
sessions?
A. App Layering
B. Insight Services
C. Provisioning Services
D. Workspace Environment Management
Workspace Environment Management (WEM) is teh correct answer
nizo67
Are the real questions in Exam multiple choice? Or there is also a Simulation Questions?
saivinoth
Dear Team,
Today I passed this 1y0-311 exam with 72%
Please share your email ID
All the best
proeasyweb
I constantly confronted trouble in seeing a portion of the ideas however 1y0-311 dumps pdf made my work actually simple. Every one of the perplexities were rejected and the credit for this goes to the specialists who have structured this investigation material. 1y0-311 Citrix XenApp and XenDesktop 7.15 LTSR Advanced Administration dumps material was adorned by placing data as inquiries and answers. I deciphered the fundamental musings of every subject and illuminated last test in all respects unquestionably. Realexamcollection.com has completed an extremely incredible employment to assist the IT understudies and I express profound gratitude for helping me to get gone by the primary endeavor.
robertdrozdz
@saivinoth
are all questions from your exam come from this dump? If yes, it means that dump contains some errors? isn't it?
