How to create VCE Files with Visual Cert Exam
Discussion in 'Tutorials | How To' started by metro, Jan 22, 2016.
  1. metro
    metro Well-Known Member
    Supplier Contributor Member
    228
    Visual Cert Exam Designer
    Desktop software designed to create and edit your own professional practice exams. It is designed foremost for authors involved in practice exam development. The application supports most of the question types used in certification exams and allows you to work on an exam using an intuitive user interface. Further, the question preview feature lets the author see exactly how the question will appear during the examination.
    Download
    to download Visual Cert Exam
    You need to unzip this anywhere on your computer.
    This is the content of the zipped file
    Use Designer to edit or create VCE files.
    Use the Manager to play VCE files.
    How to open VCE Files with Visual CertExam Designer
    Open Visual CertExam Designer
    Click File / Open and locate your VCE file
    Once your file has been loaded, you can start editing the questions.
    How to open Password protected VCE Files
    Using the software i posted
    A) Open Visual CertExam Designer
    B) Go to File / Import
    C)Click Next and Choose: Visual CertExam Suite file (*.VCE)
    D)Browse and locate your file and then click next
    E) Use the below options and click Next
    Hit Import and you are done!
    This works with most of the premium files.
    Good luck!!
    This tutorial will be updated
    #1 metro, Jan 22, 2016
  2. gillbeast
    gillbeast Member
    Mar 9, 2016
    124
    25
    Good luck!!
    Does this really work? It doesn't work for me. I tried but it's still asking for password to import.
  • metro
    228
    Can you share the exam you were trying to edit so i can check it?
  • gillbeast
    gillbeast Member
    Mar 9, 2016
    124
    25
    Doesn't work with any of the password protected files I receive from my colleagues.
    Try this below link. I am unable to convert to pdf due to this restriction. If it works, then it will be highly helpful for the amount of vce files I receive and access.
  • Shurik
    Shurik Member
    Feb 17, 2016
    Hey! Doesn't work with the newer versions of .vce files. I tried to edit file from
    post and I got this picture:
    Is there anything I can do?
    Thanks.
  • andre2015
    andre2015 Member
    Nov 17, 2015
    23
    how can i edit new vce? please help
