Last Dumps - Premium and Actual Tests
Manikandan
Hello All,
I need latest 70-533 exam dump, can someone please help ?
loulouka
looks valid to me! did the exam yesterday.. these are all new questions!
But you need to study the old one to.. they Mix questions with new and old.
Which old one you recommend to study ?
Julko62
Hello , Could You reupload the file?
Sokratis
Hi all.. yes can someone reupload the file??? thank you!!
sheraz9212
Managed to pass my exam today with 811 score. The exam was not difficult with 20% of new questions that can be answered correctly if you have good experience, clear concepts and have studied well. I used forbiden, ExamCollections Premium and Jonathan's VCEs. 80 % of questions were from these dumps.
Sokratis
Can you upload them sheraz9212??? Thanks for sharing..!!
grubberz
zzmflz
excuse me, I have to give the exam, is there anyone who could pass me the new 2018 dump? in your forum I read that there are 270 new questions. thanks in advance
Guttikonda
The new 70-533 dumps (Mar/2018 Updated) now are available, here are part of 70-533 exam questions (FYI):
NEW QUESTION 279
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet the stated goals. Some questions sets might have more than one correct solution, while others might not have a correct solution. After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
A company plans to use Operations Management Suite (OMS) to track changes within virtual machines (VMs). The company required that data collection occur at least every 15 minutes. You need to recommend a solution to monitor VMs which ensures that data collection occurs at least every 15 minutes.
Solution: Monitors daemons on Linux VMs.
NEW QUESTION 280
Solution: Monitor files on Linux VMs.
NEW QUESTION 281
A company has an Azure subscription and plans to deploy virtual machines (VMs). The company needs to use an Azure Active Directory Domain Services (Azure AD DS) domain with the VMs. You need to ensure that you can join the VMs to the Azure AD DS domain. What should you do?
A. Place the VMs in the same resource group as a domain controller.
B. Place the VMs on the same virtual network as the Azure AD DS domain.
C. Create an AD DS domain controller on a VM.
D. Create a custom domain in the Azure subscription.
NEW QUESTION 282
You administer an Azure subscription for your company. You plan to deploy a virtual machine (VM) to Azure. The VM environment must provide 99.95% uptime. A single switch outage must not cause the VM environment to be unavailable VM must be offline due to installation of an update that requires a reboot. You need to configure the environment.
Solution: Create two availability sets. Place a VM in each availability set.
NEW QUESTION 283
Solution: Create an availability set and deploy two VMs in it. Ensure that the VMs are in different update and fault domains.
NEW QUESTION 284
Solution: Create an availability set with two VMs. Place the VMs in the same fault domain.
NEW QUESTION 285
Solution: Monitor registry keys on Windows VMs.
NEW QUESTION 286
You plan to implement shared storage policies. You need to apply a policy to the appropriate resource. What should you use?
A. Queues
B. Recovery Services Vault
C. Premium Disk Storage
D. Resource Group
NEW QUESTION 287
A company uses Azure to host virtual machines (VMs) and web apps. You have an app service named App1 that uses the Basic app service tier. You need to ensure that diagnostic data for App1 is permanently stored.
Solution: You specify a storage account in the ServiceConfiguration.cscfg file.
NEW QUESTION 288
Solution: You specify a storage account in the Diagnostics.xml file.
NEW QUESTION 289
A company has a hybrid environment. The public IP address of the on-premises environment is 40.84.199.233. The company deploys virtual machines (VMs) to Azure on different subnets. You need to ensure that the Azure VMs can communicate with the on-premises environment. What should you create?
A. An Internet rule for each subnet.
B. A user defined route to 255.255.255.0/0 with a VPN gateway.
C. A user defined route to 0.0.0.0/30 with a VPN gateway.
D. A Border Gateway Protocol (BGP) route by using ExpressRoute.
NEW QUESTION 290
You plan to use Azure Monitor with AutoScale Services. You create a URI to be used with the monitoring service. You need to configure an alert that specifies the URI. Which Azure Command Line Interface (CLI) command or Azure PowerShell cmdlet should you run?
A. New-AzureRmAlertRuleEmail
B. azure insights logprofile add
C. azure insights alerts actions webhook create
D. azure insights alerts rule list
NEW QUESTION 291
Get the newest forbiden 70-533 VCE dumps here:
bit.ly/2018-new-70-533-dumps-vce
Download more NEW forbiden 70-533 PDF dumps from Google Drive here:
j.mp/2018-new-70-533-dumps-pdf
Read the newest forbiden 70-533 exam questions from this Blog:
bit.ly/forbiden-latest-70-533-dumps
(p.s. Copy the upper red short link and open it in your browser.)
