MichaelBort
The new Microsoft 365 MS-100 dumps (Nov/2019 Updated) now are available, here are part of MS-100 exam questions (FYI):
NEW QUESTION 177
Your network contains an Active Directory domain. You deploy a Microsoft Azure Active Directory (Azure AD) tenant. Another administrator configures the domain to synchronize to Azure AD. You discover that 10 user accounts in an organizational unit (OU) are NOT synchronized to Azure AD. All the other user accounts synchronized successfully. You review Azure AD Connect Health and discover that all the user account synchronizations completed successfully. You need to ensure that the 10 user accounts are synchronized to Azure AD.
Solution: You run idfix.exe and report the 10 user accounts.
The question states that "all the user account synchronizations completed successfully". If there were problems with the 10 accounts that needed fixing with idfix.exe, there would have been synchronization errors in Azure AD Connect Health.
NEW QUESTION 178
Solution: From Azure AD Connect, you modify the Azure AD credentials.
NEW QUESTION 179
Solution: From Azure AD Connect, you modify the filtering settings.
NEW QUESTION 180
Your company has 3,000 users. All the users are assigned Microsoft 365 E3 licenses. Some users are assigned licenses for all Microsoft 365 services. Other users are assigned licenses for only certain Microsoft 365 services. You need to determine whether a user named User1 is licensed for Exchange Online only.
Solution: You run the Get-MsolUser cmdlet.
NEW QUESTION 181
Solution: You run the Get-MsolAccountSku cmdlet.
NEW QUESTION 182
Solution: You launch the Azure portal, and then review the Licenses blade.
NEW QUESTION 183
Your company plans to deploy several Microsoft Office 365 services. You need to design an authentication strategy for the planned deployment. The solution must meet the following requirements:
  • Users must be able to authenticate during business hours only.
  • Authentication requests must be processed successfully if a single server fails.
  • When the password for an on-premises user account expires, the new password must be enforced the next time the user signs in.
  • Users who connect to Office 365 services from domain-joined devices that are connected to the internal network must be signed in automatically.
Solution: You design an authentication strategy that uses password hash synchronization and seamless SSO. The solution contains two servers that have an Authentication Agent installed.
NEW QUESTION 184
You have a Microsoft 365 Enterprise E5 subscription. You need to enforce multi-factor authentication on all cloud-based applications for the users in the finance department. What should you do?
A. Create an activity policy.
B. Create a new app registration.
C. Create a conditional access policy.
D. Create a session policy.
NEW QUESTION 185
Solution: You design an authentication strategy that uses federation authentication by using Active Directory Federation Services (AD FS). The solution contains two AD FS servers and two Web Application Proxies.
NEW QUESTION 186
Your network contains an Active Directory domain. The domain contains a server named Server1 that runs Windows Server 2016. Server1 has a share named Share1. You have a hybrid deployment of Microsoft 365. You need to migrate the content in Share1 to Microsoft OneDrive. What should you use?
A. Windows Server Migration Tools
B. Microsoft SharePoint Migration Tool
C. Storage Migration Service
NEW QUESTION 187
Your company has a main office and three branch offices. All the branch offices connect to the main office by using a WAN link. The main office has a high-speed Internet connection. All the branch offices connect to the Internet by using the main office connections. Users use Microsoft Outlook 2016 to connect to a Microsoft Exchange Server mailbox hosted in the main office. The users report that when the WAN link in their office becomes unavailable, they cannot access their mailbox. You create a Microsoft 365 subscription, and then migrate all the user data to Microsoft 365. You need to ensure that all the users can continue to use Outlook to receive email messages if a WAN link fails.
Solution: You enable Cached Exchange Mode for all the Outlook profiles.
NEW QUESTION 188
Your network contains an Active Directory domain named contoso.com. You have a Microsoft 365 subscription. You have a Microsoft Azure Active Directory (Azure AD) tenant named contoso.onmicrosoft.com. You implement directory synchronization. The developers at your company plan to build an app named App1. App1 will connect to the Microsoft Graph API to provide access to several Microsoft Office 365 services. You need to provide the URL for the authorization endpoint that App1 must use. What should you provide?
A. https://login.microsoftonline.com/
B. https://contoso.com/contoso.onmicrosoft.com/app1
C. https://login.microsoftonline.com/contoso.onmicrosoft.com/
D. https://myapps.microsoft.com
NEW QUESTION 189
You have a Microsoft 365 subscription. You need to provide an administrator named Admin1 with the ability to place holds on mailboxes, SharePoint Online sites, and OneDrive for Business locations. The solution must use the principle of least privilege. What should you do? (To answer, select the appropriate options in the answer area.)
NEW QUESTION 190
Your company has a hybrid deployment of Azure Active Directory (Azure AD). You purchase a Microsoft 365 subscription. You plan to migrate the Home folder of each user to Microsoft 365 during several weeks. Each user has a device that runs Windows 10. You need to recommend a solution to migrate the Home folder of five administrative users as quickly as possible. Which three actions should you recommend be performed in sequence? (To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.)
NEW QUESTION 191
Download more NEW Pass Leader MS-100 PDF dumps from Google Drive here:
Read the newest Pass Leader MS-100 exam questions from this Blog:
AlyssaSavage
TheExamCerts is the best site which provides you with the necessary Microsoft MS-100 questions that will help you to get the MS-100 Microsoft 365 Identity and Services exam on the first attempt. The latest questions can be found here and that is the reason why this is the one that you need to use and I can tell you that there is no reason for you to fail when you will have valid Microsoft MS-100 braindumps from TheExamCerts. They have the guarantee that the Microsoft MS-100 questions that they have will be the ones that will make you pass your MS-100 exam in the very first go. You must try our Microsoft MS-100 free demo befor your successive purchase. Follow this link and get 20% discount offer [Limited Time]:
To pass Microsoft MS-100 exam is no more dream. Now Microsoft students don’t need to burn midnight all to pass Microsoft MS-100 exam. Just visit Exams4Sale and get material from Microsoft MS-100 Expert.Get 35% discount by using promocode 35%OFF. Exams4Sale offers more relevant and upto date material for Microsoft exam dumps so the material is 100% accurate that’s why I recommend you this site for your Microsoft MS-100 exam on the basic of above mentioned qualities. So light up your lamp of success by visiting the link below:
