ArturWI
<div class="bbWrapper"><b><span style="color: rgb(184, 49, 47)">ATTENTION PLEASE!!! THE DP-200 EXAM UPDATED RECENTLY (</span><span style="color: rgb(0, 0, 0)"><u>Nov/2019</u></span><span style="color: rgb(184, 49, 47)">) WITH MANY NEW QUESTIONS!!!</span></b><br /> <br /> <span style="color: rgb(184, 49, 47)"><b>And, Pass Leader has updated its DP-200 dumps recently, all new questions available now!!!</b></span><br /> <br /> <span style="color: rgb(41, 105, 176)"><b>148Q NEW Version</b></span><span style="color: rgb(184, 49, 47)"><b>!!!</b></span><br /> <br /> <b><span style="color: rgb(184, 49, 47)">You can get the newest Pass Leader DP-200 exam questions in the </span><span style="color: rgb(41, 105, 176)">#5 of this thread</span><span style="color: rgb(184, 49, 47)">!!!</span></b><br /> <br /> ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br /> <br /> <b><span style="color: rgb(184, 49, 47)">The new DP-200 dumps (</span><span style="color: rgb(0, 0, 0)"><u>Oct/2019 Updated</u></span><span style="color: rgb(184, 49, 47)">) now are available, here are part of DP-200 exam questions (FYI):</span><br /> <br /> <span style="color: rgb(41, 105, 176)">[Get the download link at the end of this post]</span></b><br /> <br /> NEW QUESTION 108<br /> A company has a SaaS solution that uses Azure SQL Database with elastic pools. The solution will have a dedicated database for each customer organization. Customer organizations have peak usage at different periods during the year. Which two factors affect your costs when sizing the Azure SQL Database elastic pools? (Each correct answer presents a complete solution. Choose two.)<br /> <br /> A. maximum data size<br /> B. number of databases<br /> C. eDTUs consumption<br /> D. number of read operations<br /> E. number of transactions<br /> <br /> Answer: AC<br /> <br /> NEW QUESTION 109<br /> A company runs Microsoft SQL Server in an on-premises virtual machine (VM). You must migrate the database to Azure SQL Database. You synchronize users from Active Directory to Azure Active Directory (Azure AD). You need to configure Azure SQL Database to use an Azure AD user as administrator. What should you configure?<br /> <br /> A. For each Azure SQL Database, set the Access Control to administrator.<br /> B. For each Azure SQL Database server, set the Active Directory to administrator.<br /> C. For each Azure SQL Database, set the Active Directory administrator role.<br /> D. For each Azure SQL Database server, set the Access Control to administrator.<br /> <br /> Answer: C<br /> <br /> NEW QUESTION 113<br /> You plan to create a dimension table in Azure Data Warehouse that will be less than 1 GB. You need to create the table to meet the following requirements:<br /> <ul> <li data-xf-list-type="ul">Provide the fastest query time.</li> <li data-xf-list-type="ul">Minimize data movement.</li> </ul>Which type of table should you use?<br /> <br /> A. hash distributed<br /> B. heap<br /> C. replicated<br /> D. round-robin<br /> <br /> Answer: D<br /> <br /> NEW QUESTION 114<br /> You plan to implement an Azure Cosmos DB database that will write 100,000 JSON every 24 hours. The database will be replicated to three regions. Only one region will be writable. You need to select a consistency level for the database to meet the following requirements:<br /> <ul> <li data-xf-list-type="ul">Guarantee monotonic reads and writes within a session.</li> <li data-xf-list-type="ul">Provide the fastest throughput.</li> <li data-xf-list-type="ul">Provide the lowest latency.</li> </ul>Which consistency level should you select?<br /> <br /> A. Strong<br /> B. Bounded Staleness<br /> C. Eventual<br /> D. Session<br /> E. Consistent Prefix<br /> <br /> Answer: D<br /> Explanation:<br /> Session: Within a single client session reads are guaranteed to honor the consistent-prefix (assuming a single &quot;writer&quot; session), monotonic reads, monotonic writes, read-your-writes, and write-follows-reads guarantees. Clients outside of the session performing writes will see eventual consistency.<br /> <br /> NEW QUESTION 115<br /> You use Azure Stream Analytics to receive Twitter data from Azure Event Hubs and to output the data to an Azure Blob storage account. You need to output the count of tweets during the last five minutes every five minutes. Each tweet must only be counted once. Which windowing function should you use?<br /> <br /> A. a five-minute Session window<br /> B. a five-minute Sliding window<br /> C. a five-minute Tumbling window<br /> D. a five-minute Hopping window that has one-minute hop<br /> <br /> Answer: C<br /> Explanation:<br /> Tumbling window functions are used to segment a data stream into distinct time segments and perform a function against them, such as the example below. The key differentiators of a Tumbling window are that they repeat, do not overlap, and an event cannot belong to more than one tumbling window.<br /> <br /> NEW QUESTION 116<br /> You are developing a solution that will stream to Azure Stream Analytics. The solution will have both streaming data and reference data. Which input type should you use for the reference data?<br /> <br /> A. Azure Cosmos DB<br /> B. Azure Event Hubs<br /> C. Azure Blob storage<br /> D. Azure IoT Hub<br /> <br /> Answer: C<br /> Explanation:<br /> Stream Analytics supports Azure Blob storage and Azure SQL Database as the storage layer for Reference Data.<br /> <br /> NEW QUESTION 117<br /> You have an Azure Storage account and an Azure SQL data warehouse by using Azure Data Factory. The solution must meet the following requirements:<br /> <ul> <li data-xf-list-type="ul">Ensure that the data remains in the UK South region at all times.</li> <li data-xf-list-type="ul">Minimize administrative effort.</li> </ul>Which type of integration runtime should you use?<br /> <br /> A. Azure integration runtime<br /> B. Self-hosted integration runtime<br /> C. Azure-SSIS integration runtime<br /> <br /> Answer: A<br /> <br /> NEW QUESTION 118<br /> You plan to perform batch processing in Azure Databricks once daily. Which type of Databricks cluster should you use?<br /> <br /> A. job<br /> B. interactive<br /> C. high concurrency<br /> <br /> Answer: A<br /> Explanation:<br /> Example: Scheduled batch workloads (data engineers running ETL jobs) This scenario involves running batch job JARs and notebooks on a regular cadence through the Databricks platform.<br /> The suggested best practice is to launch a new cluster for each run of critical jobs. This helps avoid any issues (failures, missing SLA, and so on) due to an existing workload (noisy neighbor) on a shared cluster.<br /> Note: Azure Databricks has two types of clusters: interactive and automated. You use interactive clusters to analyze data collaboratively with interactive notebooks. You use automated clusters to run fast and robust automated jobs.<br /> <br /> NEW QUESTION 119<br /> You have an Azure SQL database that has masked columns. You need to identify when a user attempts to infer data from the masked columns. What should you use?<br /> <br /> A. Azure Advanced Threat Protection (ATP)<br /> B. custom masking rules<br /> C. Transparent Data Encryption (TDE)<br /> D. auditing<br /> <br /> Answer: D<br /> Explanation:<br /> Dynamic Data Masking is designed to simplify application development by limiting data exposure in a set of pre-defined queries used by the application. While Dynamic Data Masking can also be useful to prevent accidental exposure of sensitive data when accessing a production database directly, it is important to note that unprivileged users with ad-hoc query permissions can apply techniques to gain access to the actual data. If there is a need to grant such ad-hoc access, Auditing should be used to monitor all database activity and mitigate this scenario.<br /> <br /> NEW QUESTION 120<br /> Drag and Drop<br /> You have an Azure Data Lake Storage Gen2 account that contains JSON files for customers. The files contain two attributes named FirstName and LastName. You need to copy the data from the JSON files to an Azure SQL data Warehouse table by using Azure Databricks. A new column must be created that concatenates the FirstName and LastName values. You create the following components:<br /> <ul> <li data-xf-list-type="ul">A destination table in SQL Data Warehouse</li> <li data-xf-list-type="ul">An Azure Blob storage container</li> <li data-xf-list-type="ul">A service principal</li> </ul>Which five actions should you perform in sequence next in a Databricks notebook? (To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.)<br /> <div class="lbContainer lbContainer--inline " title="" data-xf-init="lightbox" data-lb-single-image="1" data-lb-container-zoom="1" data-lb-trigger=".js-lbImage-_xfUid-1-1582676277" data-lb-id="_xfUid-1-1582676277"> <div class="lbContainer-zoomer js-lbImage-_xfUid-1-1582676277" data-src="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1201.png" aria-label="Zoom"></div> <img src="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1201.png" data-url="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1201.png" class="bbImage" data-zoom-target="1" alt="" style="" /> </div> <br /> <br /> Answer:<br /> <div class="lbContainer lbContainer--inline " title="" data-xf-init="lightbox" data-lb-single-image="1" data-lb-container-zoom="1" data-lb-trigger=".js-lbImage-_xfUid-2-1582676277" data-lb-id="_xfUid-2-1582676277"> <div class="lbContainer-zoomer js-lbImage-_xfUid-2-1582676277" data-src="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1202.png" aria-label="Zoom"></div> <img src="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1202.png" data-url="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1202.png" class="bbImage" data-zoom-target="1" alt="" style="" /> </div> <br /> Explanation:<br /> Step 1: Read the file into a data frame. You can load the json files as a data frame in Azure Databricks.<br /> Step 2: Perform transformations on the data frame.<br /> Step 3:Specify a temporary folder to stage the data. Specify a temporary folder to use while moving data between Azure Databricks and Azure SQL Data Warehouse.<br /> Step 4: Write the results to a table in SQL Data Warehouse. You upload the transformed data frame into Azure SQL Data Warehouse. You use the Azure SQL Data Warehouse connector for Azure Databricks to directly upload a dataframe as a table in a SQL data warehouse.<br /> Step 5: Drop the data frame. Clean up resources. You can terminate the cluster. From the Azure Databricks workspace, select Clusters on the left. For the cluster to terminate, under Actions, point to the ellipsis (...) and select the Terminate icon.<br /> <br /> NEW QUESTION 121<br /> Hotspot<br /> You need to receive an alert when Azure SQL Data Warehouse consumes the maximum allotted resources. Which resource type and signal should you use to create the alert in Azure Monitor? (To answer, select the appropriate options in the answer area.)<br /> <div class="lbContainer lbContainer--inline " title="" data-xf-init="lightbox" data-lb-single-image="1" data-lb-container-zoom="1" data-lb-trigger=".js-lbImage-_xfUid-3-1582676277" data-lb-id="_xfUid-3-1582676277"> <div class="lbContainer-zoomer js-lbImage-_xfUid-3-1582676277" data-src="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1211.png" aria-label="Zoom"></div> <img src="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1211.png" data-url="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1211.png" class="bbImage" data-zoom-target="1" alt="" style="" /> </div> <br /> <br /> Answer:<br /> <div class="lbContainer lbContainer--inline " title="" data-xf-init="lightbox" data-lb-single-image="1" data-lb-container-zoom="1" data-lb-trigger=".js-lbImage-_xfUid-4-1582676277" data-lb-id="_xfUid-4-1582676277"> <div class="lbContainer-zoomer js-lbImage-_xfUid-4-1582676277" data-src="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1212.png" aria-label="Zoom"></div> <img src="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1212.png" data-url="http://examgod.com/plimages/DP-200_F06E/Pass-Leader-DP-200-dumps-1212.png" class="bbImage" data-zoom-target="1" alt="" style="" /> </div> <br /> Explanation:<br /> Resource type: SQL data warehouse. DWU limit belongs to the SQL data warehouse resource type.<br /> Signal: DWU limit. SQL Data Warehouse capacity limits are maximum values allowed for various components of Azure SQL Data Warehouse.<br /> <br /> NEW QUESTION 122<br /> ......<br /> <br /> <b>Download more NEW Pass Leader DP-200 PDF dumps from Google Drive here:</b><br /> <br /> <div class="bbCodeBlock bbCodeBlock--unfurl js-unfurl fauxBlockLink" data-unfurl="true" data-result-id="1815" data-url="https://drive.google.com/open?id=1CTHwJ44u5lT4tsb2qo8oThaQ5c_vwun1" data-host="drive.google.com" data-pending="false"> <div class="contentRow"> <div class="contentRow-main"> <h3 class="contentRow-header js-unfurl-title"> <a href="https://drive.google.com/open?id=1CTHwJ44u5lT4tsb2qo8oThaQ5c_vwun1" class="link link--external fauxBlockLink-blockLink" target="_blank" rel="noopener" data-proxy-href=""> PassLeader DP-200 Exam Dumps – Google Drive </a> </h3> <div class="contentRow-snippet js-unfurl-desc"></div> <div class="contentRow-minor contentRow-minor--hideLinks"> <span class="js-unfurl-favicon"> <img src="https://ssl.gstatic.com/docs/doclist/images/infinite_arrow_favicon_5.ico" alt="drive.google.com" class="bbCodeBlockUnfurl-icon" data-onerror="hide-parent"/> </span> drive.google.com </div> </div> </div> </div> <br /> OR<br /> <br /> <b>Read the newest Pass Leader DP-200 exam questions from this Blog:</b><br /> <br /> <div> <a href="http://www.microsoftbraindumps.com/?s=DP-200" class="link link--external" target="_blank" rel="noopener" data-proxy-href=""> DP-200 | Microsoft Exam Dumps from PassLeader - Azure, Data, Dynamics 365, Microsoft 365, MCSA, MCSD, MCSE ... Dumps VCE and PDF and Braindumps and Practice Tests </a> </div> <br /> Good Luck!!!</div>
Erika Jacobs
<div class="bbWrapper">Theexamcerts is a leading platform that provides you the most authentic and verified dumps of the Microsoft DP-200 exam. Theexamcerts have updated and latest dumps for Microsoft DP-200 exam that will be asked in the real DP-200 exam. Theexamcerts provides you both the PDF dumps and VCE files for the Microsoft DP-200 exam. If you prepare from the Theexamcerts then I guarantee you that you will pass your Microsoft DP-200 exam at first endeavour.<br /> <span style="font-size: 22px"><b>Strong Guarantee To Pass The Microsoft DP-200 Exam Theexamcerts</b></span><br /> We provide the customers with DP-200 Implementing an Azure Data Solution actual test latest version, the realest study materials. With the best price of Microsoft DP-200 , we also promise the high quality and 98%-100% passing rate for Microsoft DP-200 exam. There are the freshest learning information, faster update with test centre’s change and more warm online service.<br /> <br /> <b>Click Here And Get Actual Microsoft DP-200 Exam Questions - Pass Your Exam With 100% Success Guarantee<br /> <a href="https://www.theexamcerts.com/Microsoft/DP-200-pdf-exam-dumps" target="_blank" class="link link--external" rel="nofollow noopener">https://www.theexamcerts.com/Microsoft/DP-200-pdf-exam-dumps</a></b><br /> <a href="https://www.theexamcerts.com/Microsoft/DP-200-pdf-exam-dumps" target="_blank" class="link link--external" rel="nofollow noopener"><img src="http://certscollections.com/wp-content/uploads/2019/08/theexamcerts1.jpg" data-url="http://certscollections.com/wp-content/uploads/2019/08/theexamcerts1.jpg" class="bbImage " style="" alt="" title="" /></a><br /> If you have some Microsoft DP-200 questions, welcome to have conversations with our online service persons. Or you could send Microsoft DP-200 test questions to our after-sale email, to contact us via email. In general case, we will reply the customers' letter in 2 hours or quicker.<br /> <span style="font-size: 18px"><b>Get For The Communicating Region With Time To Spare</b></span><br /> Give yourself a minimum of five or ten minutes to gather your thoughts just before starting the communicating. This way, you will get settled in and have time to unwind just before the take a look at begins.<br /> <br /> Call for facilitate. If you are stuck on a topic, never be afraid to selection a devotee and evoke facilitate. If your pals can not facilitate, raise an educator for facilitate.<br /> <br /> If you might have got time just before your communicating and realize that you're not understanding material, raise if your teacher can think once again it with you.<br /> <span style="font-size: 18px"><b>DISCOUNT FOR EVERY PURCHASE:</b></span><br /> We allow discount to all the students on every purchase Microsoft DP-200 exam dumps. This very special for our honourable DP-200 customers that they purchase valid and factual material and get high marks in DP-200 Implementing an Azure Data Solution exam.<br /> <span style="font-size: 18px"><b>Security And Privacy For Microsoft DP-200 Exam User</b></span><br /> Your privacy is most important thing to us, we protect user’s data using 7 high security layers. That’s why we assure that your data is 100% secure with us.<br /> <br /> <b>There are some reasons why you should these “ Microsoft DP-200 latest exam dumps”:</b><br /> <ul> <li data-xf-list-type="ul">These Microsoft DP-200 Exam Dumps are authenticated, valid, new, up to dated &amp; also verified.</li> <li data-xf-list-type="ul">These Microsoft DP-200 dumps are so simple and very easy to understand them, because they are so simplified.</li> <li data-xf-list-type="ul">By reading them you can actually feel about the real time Microsoft DP-200 exam environment.</li> <li data-xf-list-type="ul">If you have interest in this Microsoft DP-200 certification then you should have mentioned this in your CV/Resume.</li> <li data-xf-list-type="ul">This “PDF Guide” will be very helpful to you to passing your Microsoft DP-200 exam.</li> <li data-xf-list-type="ul">Theexamcerts are also giving 3 months free up gradation without any charges.</li> <li data-xf-list-type="ul"><span style="font-size: 18px"><b>Customer Support For Microsoft DP-200 Exam</b></span><br /> In confusion, our support team is available 24/7 for your help, please feel free to contact us if any question or issue arise; Let us know I will happy to help.<br /> <b>Click Here And Get Actual Microsoft DP-200 Exam Questions - Pass Your Exam With 100% Success Guarantee<br /> <a href="https://www.theexamcerts.com/Microsoft/DP-200-pdf-exam-dumps" target="_blank" class="link link--external" rel="nofollow noopener">https://www.theexamcerts.com/Microsoft/DP-200-pdf-exam-dumps</a></b></li> </ul><a href="https://www.theexamcerts.com/Microsoft/DP-200-pdf-exam-dumps" target="_blank" class="link link--external" rel="nofollow noopener"><img src="http://certscollections.com/wp-content/uploads/2019/08/theexamcerts2.jpg" data-url="http://certscollections.com/wp-content/uploads/2019/08/theexamcerts2.jpg" class="bbImage " style="" alt="" title="" /></a></div>
Erika Jacobs
<div class="bbWrapper">To pass Microsoft DP-200 exam is no more dream. Now Microsoft students don’t need to burn midnight all to pass Microsoft DP-200 exam. Just visit Exams4Sale and get material from Microsoft DP-200 Expert.<b>Get 35% discount by using promocode 35%OFF</b>. Exams4Sale offers more relevant and upto date material for Microsoft exam dumps so the material is 100% accurate that’s why I recommend you this site for your Microsoft DP-200 exam on the basic of above mentioned qualities. <b>So light up your lamp of success by visiting the link below:</b><br /> <br /> <div> <a href="https://www.exams4sale.com/Microsoft/DP-200-exam-questions" class="link link--external" target="_blank" rel="noopener" data-proxy-href=""> https://www.exams4sale.com/Microsoft/DP-200-exam-questions </a> </div></div>
ArturWI
<div class="bbWrapper"><b><span style="color: rgb(184, 49, 47)">The new Data and AI DP-200 dumps (</span><span style="color: rgb(0, 0, 0)"><u>Nov/2019 Updated</u></span><span style="color: rgb(184, 49, 47)">) now are available, here are part of DP-200 exam questions (FYI):</span><br /> <br /> <span style="color: rgb(41, 105, 176)">[Get the download link at the end of this post]</span></b><br /> <br /> NEW QUESTION 137<br /> You have an Azure Storage account that contains 100 GB of files. The files contain text and numerical values. 75% of the rows contain description data that has an average length of 1.1 MB. You plan to copy the data from the storage account to an Azure SQL data warehouse. You need to prepare the files to ensure that the data copies quickly.<br /> Solution: You modify the files to ensure that each row is less than 1 MB.<br /> Does this meet the goal?<br /> <br /> A. Yes<br /> B. No<br /> <br /> Answer: A<br /> Explanation:<br /> When exporting data into an ORC File Format, you might get Java out-of-memory errors when there are large text columns. To work around this limitation, export only a subset of the columns.<br /> <br /> NEW QUESTION 138<br /> You have an Azure Storage account that contains 100 GB of files. The files contain text and numerical values. 75% of the rows contain description data that has an average length of 1.1 MB. You plan to copy the data from the storage account to an Azure SQL data warehouse. You need to prepare the files to ensure that the data copies quickly.<br /> Solution: You modify the files to ensure that each row is more than 1 MB.<br /> Does this meet the goal?<br /> <br /> A. Yes<br /> B. No<br /> <br /> Answer: B<br /> Explanation:<br /> Instead modify the files to ensure that each row is less than 1 MB.<br /> <br /> NEW QUESTION 139<br /> You plan to deploy an Azure Cosmos DB database that supports multi-master replication. You need to select a consistency level for the database to meet the following requirements:<br /> <ul> <li data-xf-list-type="ul">Provide a recovery point objective (RPO) of less than 15 minutes.</li> <li data-xf-list-type="ul">Provide a recovery time objective (RTO) of zero minutes.</li> </ul>What are three possible consistency levels that you can select? (Each correct answer presents a complete solution. Choose three.)<br /> <br /> A. Strong<br /> B. Bounded Staleness<br /> C. Eventual<br /> D. Session<br /> E. Consistent Prefix<br /> <br /> Answer: CDE<br /> <br /> NEW QUESTION 140<br /> You plan to create an Azure Databricks workspace that has a tiered structure. The workspace will contain the following three workloads:<br /> <ul> <li data-xf-list-type="ul">A workload for data engineers who will use Python and SQL.</li> <li data-xf-list-type="ul">A workload for jobs that will run notebooks that use Python, Spark, Scala, and SQL.</li> <li data-xf-list-type="ul">A workload that data scientists will use to perform ad hoc analysis in Scala and R.</li> </ul>The enterprise architecture team at your company identifies the following standards for Databricks environments:<br /> <ul> <li data-xf-list-type="ul">The data engineers must share a cluster.</li> <li data-xf-list-type="ul">The job cluster will be managed by using a request process whereby data scientists and data engineers provide packaged notebooks for deployment to the cluster.</li> <li data-xf-list-type="ul">All the data scientists must be assigned their own cluster that terminates automatically after 120 minutes of inactivity. Currently, there are three data scientists.</li> </ul>You need to create the Databrick clusters for the workloads.<br /> Solution: You create a Standard cluster for each data scientist, a High Concurrency cluster for the data engineers, and a Standard cluster for the jobs.<br /> Does this meet the goal?<br /> <br /> A. Yes<br /> B. No<br /> <br /> Answer: B<br /> Explanation:<br /> We would need a High Concurrency cluster for the jobs. Note: Standard clusters are recommended for a single user. Standard can run workloads developed in any language: Python, R, Scala, and SQL. A high concurrency cluster is a managed cloud resource. The key benefits of high concurrency clusters are that they provide Apache Spark-native fine-grained sharing for maximum resource utilization and minimum query latencies.<br /> <br /> NEW QUESTION 141<br /> You plan to create an Azure Databricks workspace that has a tiered structure. The workspace will contain the following three workloads:<br /> <ul> <li data-xf-list-type="ul">A workload for data engineers who will use Python and SQL.</li> <li data-xf-list-type="ul">A workload for jobs that will run notebooks that use Python, Spark, Scala, and SQL.</li> <li data-xf-list-type="ul">A workload that data scientists will use to perform ad hoc analysis in Scala and R.</li> </ul>The enterprise architecture team at your company identifies the following standards for Databricks environments:<br /> <ul> <li data-xf-list-type="ul">The data engineers must share a cluster.</li> <li data-xf-list-type="ul">The job cluster will be managed by using a request process whereby data scientists and data engineers provide packaged notebooks for deployment to the cluster.</li> <li data-xf-list-type="ul">All the data scientists must be assigned their own cluster that terminates automatically after 120 minutes of inactivity. Currently, there are three data scientists.</li> </ul>You need to create the Databrick clusters for the workloads.<br /> Solution: You create a Standard cluster for each data scientist, a High Concurrency cluster for the data engineers, and a High Concurrency cluster for the jobs.<br /> Does this meet the goal?<br /> <br /> A. Yes<br /> B. No<br /> <br /> Answer: A<br /> Explanation:<br /> We need a High Concurrency cluster for the data engineers and the jobs. Note: Standard clusters are recommended for a single user. Standard can run workloads developed in any language: Python, R, Scala, and SQL. A high concurrency cluster is a managed cloud resource. The key benefits of high concurrency clusters are that they provide Apache Spark-native fine-grained sharing for maximum resource utilization and minimum query latencies.<br /> <br /> NEW QUESTION 142<br /> You have an Azure Stream Analytics query. The query returns a result set that contains 10,000 distinct values for a column named clusterID. You monitor the Stream Analytics job and discover high latency. You need to reduce the latency. Which two actions should you perform? (Each correct answer presents a complete solution. Choose two.)<br /> <br /> A. Add a pass-through query.<br /> B. Add a temporal analytic function.<br /> C. Scale out the query by using PARTITION BY.<br /> D. Convert the query to a reference query.<br /> E. Increase the number of streaming units.<br /> <br /> Answer: CE<br /> <br /> NEW QUESTION 143<br /> A company uses Azure Data Lake Gen 1 Storage to store big data related to consumer behavior. You need to implement logging.<br /> Solution: Create an Azure Automation runbook to copy events.<br /> Does the solution meet the goal?<br /> <br /> A. Yes<br /> B. No<br /> <br /> Answer: B<br /> Explanation:<br /> Instead configure Azure Data Lake Storage diagnostics to store logs and metrics in a storage account.<br /> <br /> NEW QUESTION 144<br /> You have an Azure data solution that contains an Azure SQL data warehouse named DW1. Several users execute adhoc queries to DW1 concurrently. You regularly perform automated data loads to DW1. You need to ensure that the automated data loads have enough memory available to complete quickly and successfully when the adhoc queries run. What should you do?<br /> <br /> A. Hash distribute the large fact tables in DW1 before performing the automated data loads.<br /> B. Assign a larger resource class to the automated data load queries.<br /> C. Create sampled statistics for every column in each table of DW1.<br /> D. Assign a smaller resource class to the automated data load queries.<br /> <br /> Answer: B<br /> Explanation:<br /> To ensure the loading user has enough memory to achieve maximum compression rates, use loading users that are a member of a medium or large resource class.<br /> <br /> NEW QUESTION 145<br /> Drag and Drop<br /> You deploy an Azure SQL database named DB1 to an Azure SQL server named SQL1. Currently, only the server admin has access to DB1. An Azure Active Directory (Azure AD) group named Analysts contains all the users who must have access to DB1. You have the following data security requirements:<br /> <ul> <li data-xf-list-type="ul">The Analysts group must have read-only access to all the views and tables in the Sales schema of DB1.</li> <li data-xf-list-type="ul">A manager will decide who can access DB1. The manager will not interact directly with DB1.</li> <li data-xf-list-type="ul">Users must not have to manage a separate password solely to access DB1.</li> </ul>Which four actions should you perform in sequence to meet the data security requirements? (To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.)<br /> <div class="lbContainer lbContainer--inline " title="" data-xf-init="lightbox" data-lb-single-image="1" data-lb-container-zoom="1" data-lb-trigger=".js-lbImage-_xfUid-5-1582676277" data-lb-id="_xfUid-5-1582676277"> <div class="lbContainer-zoomer js-lbImage-_xfUid-5-1582676277" data-src="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1451.png" aria-label="Zoom"></div> <img src="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1451.png" data-url="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1451.png" class="bbImage" data-zoom-target="1" alt="" style="" /> </div> <br /> <br /> Answer:<br /> <div class="lbContainer lbContainer--inline " title="" data-xf-init="lightbox" data-lb-single-image="1" data-lb-container-zoom="1" data-lb-trigger=".js-lbImage-_xfUid-6-1582676277" data-lb-id="_xfUid-6-1582676277"> <div class="lbContainer-zoomer js-lbImage-_xfUid-6-1582676277" data-src="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1452.png" aria-label="Zoom"></div> <img src="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1452.png" data-url="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1452.png" class="bbImage" data-zoom-target="1" alt="" style="" /> </div> <br /> <br /> NEW QUESTION 146<br /> Drag and Drop<br /> You have an Azure subscription that contains an Azure Databricks environment and an Azure Storage account. You need to implement secure communication between Databricks and the storage account. You create an Azure key vault. Which four actions should you perform in sequence? (To answer, move the actions from the list of actions to the answer area and arrange them in the correct order.)<br /> <div class="lbContainer lbContainer--inline " title="" data-xf-init="lightbox" data-lb-single-image="1" data-lb-container-zoom="1" data-lb-trigger=".js-lbImage-_xfUid-7-1582676277" data-lb-id="_xfUid-7-1582676277"> <div class="lbContainer-zoomer js-lbImage-_xfUid-7-1582676277" data-src="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1461.png" aria-label="Zoom"></div> <img src="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1461.png" data-url="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1461.png" class="bbImage" data-zoom-target="1" alt="" style="" /> </div> <br /> <br /> Answer:<br /> <div class="lbContainer lbContainer--inline " title="" data-xf-init="lightbox" data-lb-single-image="1" data-lb-container-zoom="1" data-lb-trigger=".js-lbImage-_xfUid-8-1582676277" data-lb-id="_xfUid-8-1582676277"> <div class="lbContainer-zoomer js-lbImage-_xfUid-8-1582676277" data-src="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1462.png" aria-label="Zoom"></div> <img src="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1462.png" data-url="http://www.microsoftbraindumps.com/wp-content/uploads/2019/11/Pass-Leader-DP-200-dumps-1462.png" class="bbImage" data-zoom-target="1" alt="" style="" /> </div> <br /> Explanation:<br /> Managing secrets begins with creating a secret scope. To reference secrets stored in an Azure Key Vault, you can create a secret scope backed by Azure Key Vault.<br /> <br /> NEW QUESTION 147<br /> ......<br /> <br /> <b>Download more NEW Pass Leader DP-200 PDF dumps from Google Drive here:</b><br /> <br /> <div class="bbCodeBlock bbCodeBlock--unfurl js-unfurl fauxBlockLink" data-unfurl="true" data-result-id="1815" data-url="https://drive.google.com/open?id=1CTHwJ44u5lT4tsb2qo8oThaQ5c_vwun1" data-host="drive.google.com" data-pending="false"> <div class="contentRow"> <div class="contentRow-main"> <h3 class="contentRow-header js-unfurl-title"> <a href="https://drive.google.com/open?id=1CTHwJ44u5lT4tsb2qo8oThaQ5c_vwun1" class="link link--external fauxBlockLink-blockLink" target="_blank" rel="noopener" data-proxy-href=""> PassLeader DP-200 Exam Dumps – Google Drive </a> </h3> <div class="contentRow-snippet js-unfurl-desc"></div> <div class="contentRow-minor contentRow-minor--hideLinks"> <span class="js-unfurl-favicon"> <img src="https://ssl.gstatic.com/docs/doclist/images/infinite_arrow_favicon_5.ico" alt="drive.google.com" class="bbCodeBlockUnfurl-icon" data-onerror="hide-parent"/> </span> drive.google.com </div> </div> </div> </div> <br /> OR<br /> <br /> <b>Read the newest Pass Leader DP-200 exam questions from this Blog:</b><br /> <br /> <div> <a href="http://www.microsoftbraindumps.com/?s=DP-200" class="link link--external" target="_blank" rel="noopener" data-proxy-href=""> DP-200 | Microsoft Exam Dumps from PassLeader - Azure, Data, Dynamics 365, Microsoft 365, MCSA, MCSD, MCSE ... Dumps VCE and PDF and Braindumps and Practice Tests </a> </div> <br /> Good Luck!!!</div>
adolfjhon
<div class="bbWrapper">In this world of ever developing Technology, an IT-Based Certification is a basic demand of the organizations and you’ll need a certification such as Azure Data Engineer Associate to land your dream job with a promising future. Apply for Microsoft Exam and leave the preparation for Implementing an Azure Data Solution to Dumpspedia. We have the best <a href="https://www.dumpspedia.co/DP-200-dumps.html" target="_blank" class="link link--external" rel="nofollow noopener">DP-200 Exam Braindumps</a> to draw satisfactory grades in just one attempt. Our DP-200 Practice Questions leave no room for the failure. Even the Professionals claimed that after testing Practice Exam Questions themselves.</div>
