Jonathan Li
2019 New Microsoft Exam MS-101 Exam Dumps been Updated, Following are some new MS-101 Exam Questions:
P.S.
These New MS-101 Exam Questions Demo are from https://www.braindump2go.com/ms-101.html, if the owner doesn't want them to be shared here, please contact me to delete this post, thanks!
NO.1 You have a Microsoft 365 subscription
All users are assigned a Microsoft 365 E3 License.
You enable auditing for your organization.
What is the maximum amount of time data will be retained in the Microsoft 365 audit log?
A. 30 days
B. 1 year
C. 90 days
D. 2 years
NO.2 You need to meet the technical requirement for large-volume document retrieval. What
should you create?
A. a data loss prevention (DLP) policy from the Security & Compliance admin center
B. a file policy from Microsoft Cloud App Security
C. an alert policy from the Security & Compliance admin center
D. an activity policy from Microsoft Cloud App Security
NO.3 You have Windows 10 Pro devices that are joined to an Active Directory domain.
You plan to create a Microsoft 365 tenant and to upgrade the devices to Windows 10 Enterprise.
You are evaluating whether to deploy Windows Hello for Business for SSO to Microsoft 365 services.
What are two prerequisites of the deployment? Each correct answer presents a complete solution.
NOTE: Each correct selection is worth one point.
A. smartcards
B. computers that have biometric hardware features
C. Microsoft Azure Active Directory (Azure AD)
D. Microsoft Intune enrollment
E. TPM-enabled devices
NO.4 Your company has a Microsoft 365 E3 subscription.
All devices run Windows 10 Pro and are joined to Microsoft Azure Active Directory (Azure AD).
You need to change the edition of Windows 10 to Enterprise the next time users sign in to their
computer. The solution must minimize downtime for the users.
What should you use?
A. Windows Update
B. an in-place upgrade
C. Windows Autopilot
D. Subscription Activation
Welcome more people to add more new MS-101 Exam Questions here:
elashlam48
No doubt about the authenticity or validity of CIMA E3 Dumps came into my mind when I was using this to prepare for my IT exam. The series of questions and answers defined everything well and I could pick the gist of each course content. I say thanks to them for fulfilling their guarantee for success with E3 questions and answers.
Kellyeperry
Some new MS-101 Exam Questions:
New Question
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet the stated goals- Some question sets might have more than one correct solution, while others might not have a correct solution. After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
You are deploying Microsoft Intune.
You successfully enroll Windows 10 devices in Intune. When you try to enroll an iOS device in Intune, you get an error. You need to ensure that you can enroll the iOS device in Intuen.
Solution: You configure the Mobility (MDM and MAM) settings.
New Question
Solution: You create an Apple Configurator enrollment profile.
New Question
Solution: You configure the Apple MDM Push certificate.
New Question
You have a Microsoft 365 subscription.
You discover that some external users accessed content on a Microsoft SharePoint site. You modify the SharePoint sharing policy to prevent sharing outside your organization. You need to be notified if the SharePoint sharing policy is modified in the future.
Solution: From the Security & Compliance admin center, you create a threat management policy.
New Question
You discover that some external users accessed content on a Microsoft SharePoint site. You modify the SharePoint shoring policy to prevent sharing outside your organization. You need to be notified if the SharePoint sharing policy is modified m the future.
Solution: From the SharePoint admin center, you modify the sharing settings.
New Question
Solution: From the SharePoint site, you create an alert.
New Question
Your network contains an Active Directory domain named contoso.com that is synced to Microsoft Azure Active Directory (Azure AD).
You manage Windows 10 devices by using Microsoft System Center Configuration Manager (Current Branch).
You configure pilot co-management
You add a new device named Device 1 to the domain. You install the Configuration Manager client on Device1.
You need to ensure that you can manage Device1 by using Microsoft Intune and Configuration Manager.
Solution: You add Device1 to a Configuration Manager device collection.
New Question
Solution: You unjoin Device1 from the Active Directory domain.
New Question
Solution: You create a device configuration profile from the Intune admin center.
New Question
You have a Microsoft 36S subscription.
Your company purchases a new financial application named App1. From Cloud Discovery in Microsoft Cloud App Security, you view the Discovered apps page and discover that many applications have a low score because they are missing information about domain registration and consumer popularity.
You need to prevent the missing information from affecting the score. What should you configure from the Cloud Discover settings?
A. Organization details
B. Default behavior
C. Score metrics
D. App tags
New Question
Your network contains an on premises Active Directory domain. Your company has a security policy that prevents additional software from txnrwj installed on domain controllers.
You need to monitor a domain controller by using Microsoft Azure Advanced Threat Protection (ATP).
What should you do? More than one answer choice may achieve the goal. Select the BEST answer.
A. Deploy an Azure ATP sensor, and then configure port mirroring.
B. Deploy an Azure ATP sensor, and then configure detections.
C. Deploy an Azure ATP standalone sensor, and then configure detections.
D. Deploy an Azure ATP standalone sensor, and then configure port mirroring.
New Questions
More at:
